01-12-2013, 08:04 AM
#1 |
Does Own Stunts
Oddometer: 494
Oil Leak Help
![]() Anyone have a leak from here before? If do what did you do? About to get in the fische to figure out what it is, guessing the neutral indicator switch. Thanks fellas. |
01-12-2013, 08:29 AM
#2 |
Does Own Stunts
Oddometer: 494
Answered my own questions, gear position sensor, has a 39 cent o-ring behind it. Aft bolt was a bit loose as well so hopefully that will fix it in itself. Carry on.
01-12-2013, 08:49 AM
#3 |
Long way to go
Oddometer: 1,112
I've seen that problem before on here. Easy fix.
Everybody's on the run |
01-12-2013, 08:55 AM
#4 |
Oddometer: 273
This just happened to me. One of my bolts was stripped out. I taped the holes and put in slightly longer bolts.
01-12-2013, 12:35 PM
#5 |
Oddometer: 2,707
Don't over tighten those small bolts. Like 6nm.
I find your lack of faith disturbing. |
01-13-2013, 06:59 PM
#6 |
Oddometer: 329
Had the same problem. Overfilled oil level seems to be the culprit.
01-18-2013, 07:57 AM
#7 |
Oddometer: 711
Just discovered mine leaking as well. Can I pull it out with out having to drain the oil first?
Eating_goat_with_the_Cartel , Never_ventured_never_gained oncostaricantime , boundlessbooger , 1998xr400buildwithe-start Good judgment comes from experience. Experience comes from bad judgment - Mark_Twain . |
01-18-2013, 08:04 AM
#8 |
Where fun goes to die....
Oddometer: 3,235
Another idea, replace those bolts with studs, less likely hood of stripping if they are not going in and out too often.
DSM8 - A different kind of mean SQL > SELECT finger FROM hand WHERE id=3 WWW.DSM8.whereamiriding.com |
01-18-2013, 09:26 AM
#9 | |
Miles of Smiles
Oddometer: 678
13 TRIUMPH TIGER 800XC . . the new kitty in the litterbox 04 KTM 950 Adventure . . . . Farkelization Completed - soon to be up for adoption 00 SUZUKI DRZ-400E. . . . . . DS Plated |
01-18-2013, 11:26 AM
#10 |
Oddometer: 711
Went ahead and pulled it out while on center stand, leaked some oil but not bad. Soaked o-ring in some ATF for about 20 min. and reinstalled verifing no nicks in the o-ring. Been sitting for about 2 hours and see no more oil leaking, the real test will be getting it up to operating temp and riding it. Somtime this weekend I'll do that, but so far so good.
01-19-2013, 02:27 AM
#11 |
Oddometer: 1,045
