Thread Tools Rating: Thread Rating: 1212 votes, 4.98 average. Display Modes
Old 01-14-2013, 06:37 AM   #28186
MN_Smurf
Capt_Confusion
MN_Smurf's Avatar
Oddometer: 2,736
Originally Posted by 4Skins View Post
Or perhaps you prefer a tank
Point of order....those are self-propelled artillery pieces, not tanks......
'09 Kawi Versys
"A life is like a garden. Perfect moments can be had, but not preserved, except in memory. LLAP" - Leonard Nimoy
MN_Smurf is online now   Reply With Quote
Old 01-14-2013, 06:41 AM   #28187
andy29847
Dirt Road Rider
andy29847's Avatar
Oddometer: 2,356
Not sure
From AlanCT: Regarding the sights, from what I have read DO NOT try to drift the rear sight or you can damage the slide cover. Instead, it seems that you are supposed to drift the front sight only for windage.
I'll have to look when I get home but I thought the front sight slides in from front to back. Thanks for the warning.
Andy Simons
ABC#8350
IBA#7647,
Trenton, SC
Smugmug coupon code = bQItjZEfrqLkI
MOAB Ride Report
andy29847 is offline   Reply With Quote
Old 01-14-2013, 07:01 AM   #28188
ttpete
Rectum Non Bustibus
Oddometer: 6,068
There's a tool to do that. If you must use a hammer, use a brass or aluminum drift so you don't mark anything.
ttpete is online now   Reply With Quote
Old 01-14-2013, 07:07 AM   #28189
FPGT72
Oddometer: 6,129
True you move the front site.....and nothing more than 115 grain bullet in the P1.
There was a recall years ago, there should be a steel pin by the slide release...other wise the gun will pound itself to death and the frame will crack sooner or later.
[FONT='Arial','sans-serif']Calling an illegal alien an 'undocumented immigrant'
is like calling a drug dealer an 'unlicensed pharmacist
[/FONT]
FPGT72 is offline   Reply With Quote
Old 01-14-2013, 07:14 AM   #28190
andy29847
Dirt Road Rider
andy29847's Avatar
Oddometer: 2,356
Here's mine
Andy Simons
ABC#8350
IBA#7647,
Trenton, SC
MOAB Ride Report
Old 01-14-2013, 07:32 AM   #28191
FPGT72
Oddometer: 6,129
Not sure if mine came in before or after, but mine has Centruy's import markings on the underside of the barrel....I like it there better.
[/FONT]
Old 01-14-2013, 07:43 AM   #28192
TheOtherBart
TheOtherBart's Avatar
Oddometer: 1,993
Does anyone know if it's possible to put a shorter barrel on a Winchester 1200 that's marked for 2 3/4" shells? I found a blurb on MidwestGunWorks that said "Barrels for the 1300 will fit most 1200 models. They are not intended for use on Model 1200 Shotguns that were originally chambered for 2-3/4" shells only." Are there other options?
TheOtherBart is online now   Reply With Quote
Old 01-14-2013, 11:21 AM   #28193
AlanCT
The Byronic Man
AlanCT's Avatar
Oddometer: 3,637
Looks like you have the fat slide and reinforcing hex pin in the frame, which are the best ones to get.
The one I am looking at has the fat slide, but no reinforcing pin. That means 115 grain, and no hot ammo (fine by me).
I am considering a CZ 82 too, but I like the idea of widely available, cheap ammo. The 9x18 Mak for the CZ would probably have to be ordered.
"You wouldn't be riding a motorcycle if you weren't an optimist."
- Matthew Crawford
2005 Ural Tourist, 2000 Kawasaki W650
IBA #23064
AlanCT is offline   Reply With Quote
Old 01-14-2013, 11:37 AM   #28194
FPGT72
Oddometer: 6,129
They (internet experts) say that all of them you should not do anything over 115....but who knows.
I also have the 82 and like that a great deal, our local cabelas has it on stock....before the nuttyness....as well as one of the local little gun shops....so it is not THAT hard to find around here....at least it use to not be, now you can't find anything. They are very well made, and mine shoots very well.
[/FONT]
Old 01-14-2013, 11:45 AM   #28195
AlanCT
The Byronic Man
AlanCT's Avatar
Oddometer: 3,637
Which would you get first of the two, if you were buying now, and if your only other handgun was a .22?
- Matthew Crawford
IBA #23064
Old 01-14-2013, 12:01 PM   #28196
Manuel Garcia O'Kely
Back at last
Manuel Garcia O'Kely's Avatar
Oddometer: 13,454
Originally Posted by mikegc View Post
You can do it yourself. Go to http://forums.1911forum.com/showthread.php?t=133740 and see how it's done. I did it to my Hi Power several years ago. As for loading mags, you might try an Uplula loader, http://www.maglula.com/PistolMagLoad...45ACPmags.aspx. They're fast and you won't have a sore thumb at the end of the day.
I hope this helps.
Mike
Thanks Mike.
I'm not confident with my fine motor skills to do the necessary on the pistol, although it LOOKS simple enough. I found a guy 'locally' and am going to have him do it - the right tools for the job and all that bullshit, right?
I got a loader for the HP, and it's a lot nicer to use that. I was whining about the Ruger Mark I mags that have a tiny little round button and a narrow throat - right pain in der thumbs those - I had a slider that helped but my bud broke it last trip to the range - need to make a new one out of lexan sheet.
UPS Delivered my ammo order last week, now if I can kick this cold and get out to the range! That and it was minus Eleven this AM.
Never ascribe to Evil that which is more resonably explained by Ignorance and Stupidity
There's casting, then there's running into the stream with a baseball bat trying to club the fish to death. - Jim Moore
Manuel Garcia O'Kely is offline   Reply With Quote
Old 01-14-2013, 12:06 PM   #28197
Back at last
Oddometer: 13,454
Originally Posted by MiamiMotorcyclist View Post
My shooting buddy got one of those - and it's great fun to shoot and good size for the kids too - get lots of mags! His is very unfinicky in ammo - we fed all sorts of cast-offs including those stupid tuncated cone bullets and no problem!
When I shot it the first time I had to adjust to the trigger pull which I found light enough to give me a few wild shots.
Old 01-14-2013, 12:09 PM   #28198
guns_equal_freedom
Oddometer: 5,596
guns_equal_freedom is offline   Reply With Quote
Old 01-14-2013, 01:06 PM   #28199
East Coast Rider
Just Me...
East Coast Rider's Avatar
Oddometer: 4,025
I have a nice Windham Weaponry upper receiver assembly coming my way...can anybody point me to a supplier/FFL who hasn't gone completely insane with regard to a quality stripped lower receiver?? I'm in the South Carolina area...
Txt msg with Dan right after he was paralyzed:
Me: Hey Dan-O. Just wanted to say howdy and Love ya!
Dan: Howdy and Love you too. Doin' good and feeling good.
Me: Give 'em hell, little Bro!
Dan: Roger that.
East Coast Rider is offline   Reply With Quote
Old 01-14-2013, 03:02 PM   #28200
ImaPoser
adventure imposter
ImaPoser's Avatar
Oddometer: 15,886
Funny.
ImaPoser
Save 20% when you open your own smugmug account. Just go here...
ImaPoser is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 08:49 AM.
