Old 01-14-2013, 02:43 PM   #72841
CDHMotorsports
CDHMotorsports's Avatar
Oddometer: 154
Hot Start Problem ??????????
Hey guys, I just got my 01 DR650 about 12 weeks aga and everything is great with it except on a couple of rides we have stopped for a few minutes and the bike wont start. I can roll it off and it will pop-start though. any ideas? Thanks
CDHMotorsports
CDHMotorsports is offline   Reply With Quote
Old 01-14-2013, 02:59 PM   #72842
procycle
procycle's Avatar
Oddometer: 2,412
You'll have to give us some more info. Cranks fine but won't start? Cranks slow? Button does nothing? Backfires?
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 01-14-2013, 03:15 PM   #72843
godaddygo
drdude
godaddygo's Avatar
Oddometer: 362
Stock head light questions
This a quote from the "Short way around the world"
http://shortwayround.co.uk/suzuki/
Wondering if anyone has given this a try?
Headlight Not riding at night is one of the golden rules of overland travel by motorcycle and I avoid it most of the time. There have been occasions though where I’ve been caught out and where I would really have benefitted from better lighting. However, as these times are few and far between I didn’t want to spend any money on expensive additional/replacement lights. The solution (though I’ll have to wait to prove it) seems to have come simply and cheaply in the form of a simple relay circuit and a better bulb. The theory: The stock headlight circuit uses small gauge wire connected through the switch to supply the headlight. This modification uses the OEM wiring to switch one of two relays (1 High beam, 1 Low) which in turn connect the headlight direct to the battery via larger gauge wires and an inline fuse. This system reduces the voltage drop to 0.1v; a drop of 1.0v can equate to a 25% reduction in the headlights ‘output. I also added a Phillips X-Treme headlight bulb of the OEM rating 60/55w.
godaddygo is offline   Reply With Quote
Old 01-14-2013, 04:40 PM   #72844
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,818
Originally Posted by Adv Grifter View Post
I disagree. Although nothing can really be proved definitively YET ... I feel that the Euro goes further in China and better quality will be the result. If the basic design is sound then with precise manufacture and top quality components it's a Win Win for BMW (and Husky) After all ... BMW make cars in China too.
What's been hurting BMW the last 10 years or so has been some dodgy Eastern European parts suppliers ... and some slip shod QA (quality assurance) in Berlin. Even former BMW designer David Robb admitted to this.
Based on some experience with the DR I feel it may not be the top end that will be in need of service. If the gear box lets go ... well
But I'm sure a fresh top end couldn't hurt if you tend to over rev and hold the bike at high RPM's for long periods. Mine's at 50K now ... still good compression, no oil use and good power!
Look after the oil, valve adjustments and filters and it may surprise you.
The problem with manufacturing in China is being able to stay on top of them. They love to start subbing unapproved materials any chance they get to save a few pennies.
I am pretty religious on maintenance on my bikes, but I also ride the piss out of them
Old 01-14-2013, 04:49 PM   #72845
BergDonk
BergDonk's Avatar
Oddometer: 3,820
Standard upgrade for me:
http://www.advrider.com/forums/showp...&postcount=379
http://www.advrider.com/forums/showp...&postcount=381
http://www.advrider.com/forums/showp...&postcount=383
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 01-14-2013, 05:02 PM   #72846
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,826
The suspension on my F800 was utter garbage. The forks being the worst. Both shock and fork internals were thrown in the trash. Had to spend some bucks to replace them with decent suspenders it should have come with. No chain guide either was a clue to the cost cutting by BMW. I can tell you the DR suspension as low end as it is, is still better then the stock F800. And the top shock mount on the F8 is another eye opener.
Ill keep the DR myself.
The GSA is all together different. Better build quality and components then the smaller cousin.
This is just my opinion though but I have owned them all.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot screwed with this post 01-15-2013 at 04:54 AM
DockingPilot is offline   Reply With Quote
Old 01-14-2013, 06:41 PM   #72847
CDHMotorsports
Oddometer: 154
it cranks, but doesnt fire. it will not start unless you let it sit for a while and or, pop start it.
CDHMotorsports
Old 01-14-2013, 08:03 PM   #72848
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,279
I had a short in my wire harness, and instead of fixing it I ran this setup and the lights are much brighter.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 01-15-2013, 01:29 AM   #72849
Tyrepower
Tyrepower's Avatar
Oddometer: 151
Battery could be on the way out. Get it looked at by someone that knows how to test them. Or try a battery from a friends bike. Same thing happened to a mates bike. We went through everything including the stator and stuff connected to that. And it turned out to be the battery had enough power to crank but not enough to fire.
My biggest fear is when I die, my wife will sell all my bikes for what I "told her" they cost!!!
It's all good fun until someone gets hurt......... then it's hilarious!!!
Tyrepower is offline   Reply With Quote
Old 01-15-2013, 05:28 AM   #72850
thetable
thetable's Avatar
Oddometer: 1,462
Sounds like it would be a good place to start. I know on my DR, the high beam indicator puts out more light than the high beam itself. I'd also replace the headlight connector itself to a higher grade unit, as I have seen issues in other Suzuki's that I've owned. More food for thought: http://www.danielsternlighting.com/t...ys/relays.html
thetable is offline   Reply With Quote
Old 01-15-2013, 06:33 AM   #72851
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,545
Try laying the bike on it's side for 10 seconds, pick it up and see if it starts. If so, I suspect it is the float assy o-rings. That was my trouble twice in 7 years of owning mine. (so far)
parts 15 & 16:
http://www.ronayers.com/Fiche/TypeID...oup/CARBURETOR
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 01-15-2013, 07:40 AM   #72852
Anklyne
Anklyne's Avatar
Oddometer: 87
Wicked
Finally got a mid-pipe so I could do the GSXR can mod. Using a x40f1x (Aussie x40f0x) and a mid-pipe made by a bloke over in QLD (AU$175 + shipping - much cheaper for me than the other pre-fabbed options). It's not as smooth of a bend and such as the other options, but considering I haven't done any mods to the intake and probably won't do more than remove the snorkel (yes, the snorkel is still in there atm), it's not going to be an issue
Just have a quick prototype/unfinished bracket currently because I was eager to mount it all up and test it out. I need to do some tweaking of fasteners to make sure it's all honky-dory, but from the quick ride I did earlier tonight, it's going great.
Previously the bike seemed to labour when giving it throttle while cruising, which I had just put down to the BST carb. I need to do some more riding to make sure (), but I'm pretty sure that is now gone with the new exhaust.
Anyway, some photos:
Anklyne is offline   Reply With Quote
Old 01-15-2013, 07:44 AM   #72853
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,219
That pipe looks great!! I don't see any problem with it over the expensive pre-fabbed options!!
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is online now   Reply With Quote
Old 01-15-2013, 08:13 AM   #72854
blackcap
blackcap's Avatar
Oddometer: 548
Very well done Video!
Is that your work? Or from another source? And of course I have to ask ...
do you know what Camera was used? Great image quality throughout!
Some Hellish mud there mate and some knarly tracks for the DR650.
Good going.
yeah all original from me in the past 12 months or so. still learning a lot about movies. the on bike camer is a VIO POV HD, the roadside is mostly a Canon EOS 5D and then there is a couple of shots from some point and shoot cameras (theres been a couple now after a sacrifice had to be made to the gods of soul capturing devices). all the tracks so far in the movie have been pretty easy with a couple of tough sections. the good mud will be in the next installment if i ever get round to finishing it.
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Old 01-15-2013, 09:19 AM   #72855
motolab
motolab's Avatar
Oddometer: 2,777
It is likely to either be dirty, have worn out/damaged parts, or was/is just not jetted correctly.
Regards,
Derek
motolab is offline   Reply With Quote
Times are GMT -7.   It's 05:45 PM.
