Old 01-13-2013, 12:13 AM   #226
oregoncoast
Racing Like a Noob
oregoncoast's Avatar
Oddometer: 4,507
Looking fantastic!
Old 01-13-2013, 02:35 PM   #227
DRjoe
DRjoe's Avatar
Oddometer: 5,115
So first test run will be Friday then?
I may have asked this already but where did you get your fork brace from?
Old 01-13-2013, 03:05 PM   #228
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,184
Not this friday. Maybe the next. There's still an airbox, electrical system, exhaust, fuel tank mount, seat, clutch cable, rear brake to make before it's really rideable.
The fork brace is a Superbrace brand that I bought from procycle.us I obviously don't know how well it works, but it does fit perfectly and has lips so that it won't work its way down into the tire. It might take up a half inch of suspension travel though. I'd need to pull the fork springs and test it to be sure.
Luke is offline   Reply With Quote
Old 01-13-2013, 04:50 PM   #229
DRjoe
DRjoe's Avatar
Oddometer: 5,115
Old 01-13-2013, 06:56 PM   #230
Loud Al
Loud Al's Avatar
Oddometer: 3,912
The morning started out chilly
Making progress
Purty
Still cold
Measure
Cut
Well that was unexpected
Precision
debris
A Quick Trip to Big Sur
Allan
Loud Al is offline   Reply With Quote
Old 01-13-2013, 10:30 PM   #231
DustyRags
Idiot
DustyRags's Avatar
Oddometer: 680
Your photos leave me in awe.
DustyRags is offline   Reply With Quote
Old 01-16-2013, 07:08 PM   #232
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,184
One step backwards, two big steps forward
I tried to come up with a way of not undoing some of the work I'd done and failed. At least, failed to find a way that was easier.
So out comes the cutting wheel.
And back on it goes. Similar, but not the same.
With the top mounts in the right place, it was time to fix the bottom mounts.
First, clear up a lingering problem with the swingarm.
Welding in the cross brace distorted the swingarm, which narrowed it up and twisted the pivot tube so that the bushing was slightly binding. Cutting, inserting a spacer in the slice and then welding it back up fixed it.
Then it was time to attach the lower shock mounts.
First measure then clamp then measure some more:
Then weld weld weld.
It's on its feet now.
Old 01-16-2013, 07:21 PM   #233
Loud Al
Loud Al's Avatar
Oddometer: 3,912
Wow great progress
Allan
Old 01-16-2013, 07:25 PM   #234
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,152
Looks really good. That rear suspension should be plush. Nice work, I am looking forward to seeing it in person.
I also like the tank, where did you find it?
-John
An Elefant never forgets.
www.Raceforthewounded.com
azcagiva is offline   Reply With Quote
Old 01-16-2013, 07:47 PM   #235
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
wow, I am worried about the shock mounts. I thought they would be welded inside a hole drilled inside the side of the swing-arm. I know you are the engineery type and know where the force is applied and how it is safe and stuff. It just seems weird and risky to me. Maybe you can explain how welding two small cylinders to the bottom of the swing-arm is sturdy enough!
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 01-16-2013, 07:48 PM   #236
oregoncoast
Racing Like a Noob
Oddometer: 4,507
Fantastic progress!!!
The tank was one that I bought at the 2011 AHRMA race in Chehalis. It almost made it onto our SL350, but didn't. It is a clark tank. I think it looks great on Luke's monster bike!!
Old 01-16-2013, 07:52 PM   #237
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 11,088
It's starting to look like a motorcycle.
Ladybug0048 is offline   Reply With Quote
Old 01-16-2013, 08:14 PM   #238
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,184
This is just for testing. If the handling seems ok then I'll add some gussets up the side of the swingarm and then box those in.
Old 01-16-2013, 08:30 PM   #239
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,184
-John
Thanks! I'm looking forward to seeing you.
It certainly _should_ be plush. Bouncing on the bike I can say that it's very ....uh..... resistant to bottoming.
Among the things to do: revalve the suspension.
Old 01-18-2013, 11:30 AM   #240
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 737
Air Box Stuff
Last night I came home and Luke was in the shop making air filter mock-ups that were similar to dimensions found in some air filter guide books. Here are two of them;
Big one in projected air box intake area;
Small one in projected air box intake area;
Conclusion; we need Goldilocks to find us one that is "just right"!
Luke took additional pictures of other bits he was working on yesterday, I'm sure he will post those soon with more commentary.
"Nothing can stop us but fear and common sense”
LC Garage is offline   Reply With Quote
Times are GMT -7.   It's 12:55 AM.
