Old 01-16-2013, 08:05 AM   #46
rade OP
Oddometer: 185
Originally Posted by MortimerSickle View Post
Will you have some way to vent between the sections, to release the air trapped by the frame-relief indentations? so the tank can filled completely?
Very good point!!! I have some solution, but still hesitating, if it is the best one cost/saved volume.
So far I have in plan to into the "square" areas you see on the attrappe, not "T fitting" but "L" fittings collected into one tube, that will be wired under the seat, along the airbox and it will end next to the tripple clapms.
Do you have any tips - pictures for inspiration?
Rade
创创创创创创创创创创创创创创创创创创创创创
complete portfolio at: radegarage.com
rade screwed with this post 01-16-2013 at 08:32 AM
rade is offline   Reply With Quote
Old 01-16-2013, 08:19 AM   #47
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,487
Originally Posted by rade View Post
..."L" fittings collected into one tube, that will be wired under the seat, along the airbox and it will end next to the tripple clapms.
It looks like that routing would take the line below the level of any air pocket, and so be unable to vent?
Maybe better to connect to the rear (highest) chamber? That would solve the filling problem, but might present another problem, that of venting the cap without having gas slosh out while riding rough ground with a full tank.
I'm not helping much, am I.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 01-16-2013, 10:01 AM   #48
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Can I ask some dumb questions?
Where is filler going to be?
Also will this replace the existing plastic under the seat or will that need to be cut?
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema screwed with this post 01-16-2013 at 09:44 PM
ciedema is offline   Reply With Quote
Old 01-16-2013, 10:22 AM   #49
MrSandman818
INaVANdownBYtheRIVER
MrSandman818's Avatar
Oddometer: 849
Yes you can. Haha.
Also will this replace the existing plastic in the seat or will that need to be cut?
-Chrome don't getcha home, but carbon fiber sure is fancy
2005 KTM 950 Adventure - back from the dead, Was totaled.
2005 Yamaha YZ250F - low compression, because race bike
1989 Yamaha TW200 - clapped out from a tweaker
1978 Batavus 48 - back from the dead. Parked since 83'
MrSandman818 is offline   Reply With Quote
Old 01-16-2013, 09:46 PM   #50
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Originally Posted by MrSandman818 View Post
Yes you can. Haha.
Hahaha - I can't even write what I mean.
Old 01-17-2013, 12:05 PM   #51
KarimADV
Oddometer: 67
This could be really interesting, for people like me looking for a small tank to be used in short distance enduro riding: i never found something that fits the needs of my 990 with ABS :)
KarimADV is offline   Reply With Quote
Old 01-17-2013, 03:31 PM   #52
rade OP
Oddometer: 185
Sorry Karim, but this one wont work for models with ABS:-(
But if this one project has pay back, I have some ideas about the auxiliary tank for models with ABS. So x-fingers pls :-)
Rade
Old 01-17-2013, 03:59 PM   #53
rade OP
Oddometer: 185
The filler placement was under discussion too. You can see the considered options on the pix. The winner is the yellow spot. Itm. it will be under the seat, because:
- i dont have to solve the lock
- it will be low, so NOT needed to cut the seat it self
- more backward would be better because of the air chamber, but you would have to cut the ALU rack and you would have to more the ludgage when refilling...
So the decision is the yellow spot - you have 2-3 days to convice me other way before the final form 3D model is final
Rade
rade screwed with this post 01-20-2013 at 02:07 AM
Old 01-17-2013, 09:28 PM   #54
craigincali
Just hanging around
craigincali's Avatar
Oddometer: 2,170
make it so you can use a vented cap???? no gas sloshing out, no tubes to run.
Me
I am usually drunk when I post so dont take it personally !
2010 KTM 990
craigincali is offline   Reply With Quote
Old 01-17-2013, 09:44 PM   #55
Oz Nutter
Oddometer: 1,275
Dry Break???
What about those "race type" fillers, zero spillage no?
I guess you could have a dry break funnel attachment that you stash on bike , be great if it matched up with Rotopac (dimension wise) container mouthpeice for maximum versatilaty...
Hide the filler under false standard cap?/through side?
Oz Nutter screwed with this post 01-17-2013 at 09:54 PM
Oz Nutter is offline   Reply With Quote
Old 01-17-2013, 10:00 PM   #56
two trackin fool
two trackin fool's Avatar
Oddometer: 1,312
Stay Patient and Trust your Journey
'10 990 in White
two trackin fool is offline   Reply With Quote
Old 01-18-2013, 02:01 PM   #57
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,412
If you vent the tank properly, you won't need a filler. It will fill when you add fuel to your main tanks as long as the valves are open. I've had this setup on my Husaberg and it works well and fills quickly...
~ Ken
www.powercellperformance.com
PowerCell is online now   Reply With Quote
Old 01-18-2013, 03:07 PM   #58
WelshLAMB
border raider
WelshLAMB's Avatar
Location: monmouth, hereford and the roads between (UK)
Oddometer: 73
I assume vent for rear tanks is lower than front tanks fuel level and level in fronttanks higher than rear filler when full. So does petcock have to be turned off until front tanks empty a bit?
I guess there are many raer racks out ther ...many different designs so hard to plan best location on rack. On other hand Unless your globe trotting then most likely need for extra fuel is a long days offroading (low mpg) when its unlikely you have luggage on. Then tank filler in rear rackis the 'cleanest solutio, and being higher than underseat might help with issues above?
Underseat is not so bad.... OH OK I don't know the answer!!
Very nice work though
Welshlamb
990Adv, little talent
WelshLAMB is offline   Reply With Quote
Old 01-18-2013, 05:13 PM   #59
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,055
Under seat cap could be a pain if luggage is strapped over seat. I can see manufacturing wise it is the best place.
rossguzzi is offline   Reply With Quote
Old 01-20-2013, 02:11 AM   #60
rade OP
Oddometer: 185
Hmm, sorry, what you mean by "race type" filler? This? Where would you place? It is too deep so it would decrease the tank capacity...
And what is "dry break funnel attachment that you stash on bike" Could you post a picture pls.? (sorry english is not my native...)
Rade
Times are GMT -7.   It's 07:59 AM.
