Old 01-17-2013, 01:24 AM   #1
Andy_unaventurous OP
Lost but not fearful
Andy_unaventurous's Avatar
Oddometer: 76
Totally worn out rear hub
Greetings knowers of more than me!
My R80G/S has a totally worn out rear hub, brakes dragging or being ridden on I suspect. Anyway , gotta do something about it for rego. The great guys at BM Ringwood talk of machining out the hub and pressing in a sleeve internal diameter ( when surfaced down) same as a stocky. They are pretty straight guys , but I'm just checking what else is out there? Must have happened to other 31 year old bikes I guess
Anyone hear about this or have any knowledge of any other way, or indeed (ha ha ha ) have a second hand 3 bolt hub for sale?
Andy
For a hundred, a girl would lend you her Bartok records, have dinner, and then let you watch while she had an anxiety attack.
Andy_unaventurous is offline   Reply With Quote
Old 01-17-2013, 01:34 AM   #2
8jest
Oddometer: 18
Man. How many miles you have on it?
There is some bidding going on here on eBay:
http://bit.ly/10B4Ir9
8jest is offline   Reply With Quote
Old 01-17-2013, 01:54 AM   #3
TEXASYETI
Call me "thread killer!"
TEXASYETI's Avatar
Oddometer: 1,920
Went through this myself recently. Ended up getting a wheel from Germany and it was not cheap. Someone did a modification where they put a 4-lug monolever reardrive on a G/S. They took a GS paralever rear wheel (4 lug and spoked) and machined some metal off on the inside and popped it on.
Problem is, paralever rear wheels seem to be just as rare as g/s monolever wheels. I hope that BMW is hearing the increasingly numberous and loud cries for these rear hubs and does something about it.
BobFV1 to Putts: "Congrats on the bike. Also, congrats on having a dog with a perfectly heart-shaped asshole."
1981 R80G/S
1991 R100 GSPD
FIRST TIME RIFF RAFF - Go Jonah!
TEXASYETI is offline   Reply With Quote
Old 01-17-2013, 01:57 AM   #4
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,776
I didn't think you could sleeve out the GS wheel. the steel drum is cast in below the level of the aluminium around it. Be nice if you could but I don't see how they could fit a new one without chopping out a lot of aluminium.
Rob Farmer is offline   Reply With Quote
Old 01-17-2013, 02:44 AM   #5
Oddometer: 76
Hi Mate, Impossible to say how many miles, there are some areas where its really tight and you think , wow, low miles, but then I took off the rear wheel and the drum is so worn you have to adjust the brakes up before you can remove the wheel, such is the lip on the drum itself? That there auction is for a diff/final drive, that seems ok on mine
maybe we'll be able to 3d print one soon :-)
Andy
Old 01-17-2013, 02:46 AM   #6
Oddometer: 76
Hi Rob, please clarify mate, are you saying the 'level' of the brake hub is below the outer cast alloy of the hub? If so is it normal to have to adjust the shoes in to be able to remove the wheel?
thanks for your thoughts
Andy
Old 01-17-2013, 04:19 AM   #7
bikerfish
flyfishandride
Oddometer: 1,640
I always have to adjust the brakes to remove the rear wheel on my airheads, G/S included. before jumping to conclusions, take measurements to see if it is truly worn out, I'm sure someone here has the specs.
bikerfish is offline   Reply With Quote
Old 01-17-2013, 04:28 AM   #8
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,776
Andy,
I didn't word that too well.
When the wheels are new there isn't a lip. What I was trying to say is the steel liner is cast into the wheel. I cannot see how you could remove it or fit a replacement in there as the outer diameter of the replacement liner would need to be smaller than the worn original drum to fit it through the gap in the aluminium casting...hope that makes sense...I have a g/s wheel in my spares I'll dig it out and take a picture if needed.
Old 01-17-2013, 05:09 AM   #9
mendoje
Oddometer: 240
Originally Posted by Andy_unaventurous View Post
...I took off the rear wheel and the drum is so worn you have to adjust the brakes up before you can remove the wheel,
Rather than mileage, what is the measured diameter of the drum? I cant recall the number from memory, but the max acceptable diameter is cast on the hub somewhere. As others have said, it's normal to readjust the brakes when R&R'ing the wheel.
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1993 Suzuki RMX250 / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike )
mendoje is offline   Reply With Quote
Old 01-17-2013, 06:16 AM   #10
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,752
I'd be interested in what you find out. I purchased an extra rear wheel from Germany, used and at a pretty good price and was glad to get it. At the time he had one other wheel for sale. I checked and he no longer has it.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-17-2013, 06:34 AM   #11
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,278
The rear hub from my R100R is similarly shot, probably from maladjustment. It is worn with a curve dug into the center of the drum face. I'd love to find a solution for that, also. We have a local machine shop that does some very trick stuff, so maybe I'll ask them one day.
At least for that bike I can still buy a new hub, but it's not cheap.
AntonLargiader is online now   Reply With Quote
Old 01-17-2013, 07:06 AM   #12
_cy_
Oddometer: 6,357
not cheap is an understatement on top of extremely hard to find!
it's worth noting that original BMW brake shoe material can get extremely hard. either from age and/or very hard to begin with. while it's normal for brake drums to wear a little. most of the wear needs to come from brake shoe materials.
assuming your drum is still within tolerances... to save what left of your G/S drum. take your drum and old shoes to a local brake/clutch repair shop. find one that will custom fit shoe to drum. if there's wear on drum, thickness for shoes needs to be slightly thicker. reason is max braking occurs at beginning of brake rod travel. when brake cam is in optimal position.
new shoe material will be much softer than OEM. much rather brake shoe wear vs drum. had no clue just how hard shoe material had become. until I tore into my G/S drum to track down why my rear brakes were so underpowered. getting brake shoes relined with slightly thicker/softer brake shoe lining fixed problems of excessive drum wear and lack of braking power.
_cy_ screwed with this post 01-17-2013 at 07:18 AM
_cy_ is online now   Reply With Quote
Old 01-17-2013, 07:59 AM   #13
jackd
Oddometer: 3,049
That is a very good suggestion - I'll be following that route when the time comes for my rear wheel to be dealt with.
Old 01-17-2013, 10:57 AM   #14
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
For building up spent brake drums I've been curious about trying a thermal spraying process aka "flamespray" or "plasma coating". I've seen various mention of people using this to build up spent wear surfaces before.
http://en.wikipedia.org/wiki/Thermal_spraying
These guys even mention using it on clutch plates and brake drums. Some of the coatings can be finish ground after application as well. Looks very promising to me:
http://www.plasma-group.co.uk/therma...-coatings.html
Hmmmmmm. My only concern would be that the heat might separate the cast-in drum from the outer aluminum casting due to the difference in coefficient of thermal expansion of the two materials. The flame spray process is much lower temp than welding though, so maybe it wouldn't be a problem. Who wants to be the guinea pig?
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-17-2013, 11:20 AM   #15
supershaft
because I can
Oddometer: 9,116
Brake drums are a problem for us. Too bad every airhead ever sold didn't have the brake shoe lining replaced with a lining that actually wears versus the drum! Those linings don't get old and hard. They come brand new like that. The drum wear isn't necessarily from high miles or maladjusted brakes. It's from the linings. A curve dug into the center of the drum? I call that a glaciated drum. The same basic U shape as a glaciated valley. It's from those rock hard stock brake shoes. I see it ALL the time on all the beemers I have been around.
Times are GMT -7.   It's 04:01 PM.
