Old 01-15-2013, 10:22 AM   #91
JimRidesThis OP
Local celebrity
JimRidesThis's Avatar
Oddometer: 267
Originally Posted by Moparmanpete View Post
When one door closes another door opens
Hang in there!
I though it was 'when one door close another slams in your face'?
Originally Posted by Ivanych View Post
Hold on!
Whatever you do, you do for the best!!!
Excuse me, I want to seize the moment.
You can do two measurements for me?
I
I'll get back to you with some measurements Ivan.
Originally Posted by Homerb View Post
Hang on a second Jim, I have a feeling the balance shaft drive gear is a press fit onto the crankshaft, and you may be able to get a gear from a buggered crank fitted to your crankshaft. Need to talk to a crankshaft rebuilder to be sure.
Or it may be cheaper to fit a used crank if you can find one. Lots on ebay.com
Yep, there's a crank on ebay(UK) at the moment for a not unreasonable 50 UKP. I'll have to check it out first, but that's probably the way to go I suspect. I'm sulking with the XL at the moment though and I have a bathroom to install at home so it'll have to wait.
JimRidesThis...
1985 XL600R "Tamworth"
1992 TDM850 "Ivy"
1995 R1100GS "Herr Flick"
JimRidesThis screwed with this post 01-15-2013 at 10:28 AM
JimRidesThis is offline   Reply With Quote
Old 01-15-2013, 10:58 AM   #92
Ivanych
Ivanych
Ivanych's Avatar
Oddometer: 239
thanks!
Look crankshaft here -http://www.hondaxl.de/shop/XL-600-R/...rbelwelle.html
Ivanych is offline   Reply With Quote
Old 01-15-2013, 01:16 PM   #93
JimRidesThis OP
Local celebrity
Oddometer: 267
Talking
Here you go Ivan,
Let me know if there are any other measurements you need (or photo's of XL6 components).
Jim
Hold on!
1. Which thickness (size) of the left crankcase a XL600? (from the main connectors to cover the stator) - 74.5mm
2.What size (depth) in the cover the stator (of connectors up to supports the stator)? - 22.0mm
Thank you!
JimRidesThis...
1992 TDM850 "Ivy"
Old 01-15-2013, 01:30 PM   #94
Ivanych
Ivanych
Ivanych's Avatar
Oddometer: 239
Here you go Ivan,
Jim
Many thanks Jim!
These two measurements are the principal for me today.
I'm looking for a place for an additional 6 mm. at the tail end of the crankshaft (the stator). I think 600 stator cover more than 500 cover by 6 mm. Thanks for the offer, I would think.
Old 01-15-2013, 02:00 PM   #95
JimRidesThis OP
Local celebrity
Oddometer: 267
Many thanks Jim!
You're welcome Ivan.
I've just been reading your XL500 revival thread - I have an easy time with my bike in comparison. St Petersburg looks amazing; when my XL is finished I will ride out to visit
JimRidesThis...
1992 TDM850 "Ivy"
JimRidesThis screwed with this post 01-15-2013 at 06:09 PM
Old 01-17-2013, 08:06 AM   #96
Ivanych
Ivanych
Ivanych's Avatar
Oddometer: 239
Welcome Jim, I will be glad to meet you.
Many thanks for your measurements, I went to see it cover starter yesterday, 500 cover less than 600 cover by 6 mm.
Сrafty Japanese engineers - Hooray!
Old 02-07-2013, 12:53 PM   #97
JimRidesThis OP
Local celebrity
Oddometer: 267
Question End float?
OK, I've stopped sulking now and ordered that replacement crank off ebay. Too far away to go and see, but I had a good chat with the seller beforehand and have to trust his promise of my money back if the part's no good. Fingers crossed it's a good un.
When I stripped the engine cases first time round, I think the gearbox was missing some spacers/shims on either end of the output shaft (the one the drive sprocket sits on) - there seemed to be a lot of end float - about 5mm I guessed at the time.
When I rebuilt the box, I put a 3mm shim on the output side which seemed to centralise the pinions and the gearbox shifted OK when the cases were bolted up. There is still just over 1.2 mm of end float. Is that normal or do I need to shim the 'other' end too?
I'll have the cases split again when the replacement crank arrives, so I'll do some photo's of what I've got so far.
Jim
JimRidesThis...
1992 TDM850 "Ivy"
JimRidesThis screwed with this post 02-07-2013 at 01:27 PM
Old 03-04-2013, 03:37 PM   #98
JimRidesThis OP
Local celebrity
Oddometer: 267
Wicked Competition time!
Spot the difference...
XL600R
...here you go
XL600R
The offending chip out of the balancer shaft drive gear. I can't believe I missed it!
JimRidesThis...
1992 TDM850 "Ivy"
Old 03-04-2013, 03:49 PM   #99
JimRidesThis OP
Local celebrity
Oddometer: 267
Thumb Back to the future...
With the new crank inspected thoroughly I set about rebuilding the bottom end. Again.
XL600R
It's too cold outside in the garage so I'm working on the kitchen table. Luckily I have an understanding wife . Either that or she's just used to it after 28 years!
XL600R
Transmission in with the layshaft (output shaft) shimmed to take out most of the end float I mentioned in a previous post. It's now down to slightly less than 0.10 thou, hopefully that'll do.
XL600R
'New' crankshaft installed along with the balancer shaft. Looking good
XL600R
et voila! Back to the same point I was at 6 weeks ago, except this time the crank turns nice a smoothly with no 'rough spot'.
Now it's on to the top-end. The piston is fine but I've got new rings, cam chain and guides to go into a freshly honed barrel. I've also built the head and cam cover back up so we should (hopefully) be good to go on the next stage.
JimRidesThis...
1992 TDM850 "Ivy"
Old 03-04-2013, 07:20 PM   #100
Moparmanpete
Support all riders
Moparmanpete's Avatar
Oddometer: 294
"The reward is in the doing of it" "If you don't go when you to want to go, when you do go you'll find you've gone" BM
08 Wildfire 150 Scoot "The Virus"
The Virus's RR http://advrider.com/forums/showthread.php?t=826703
87 XL600R "The Cracken" deceased till further notice
Moparmanpete is offline   Reply With Quote
Old 03-06-2013, 06:59 AM   #101
brucifer
brucifer's Avatar
Oddometer: 2,380
Way to go, Jim!
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
For sale--1996 Honda XR600R--
brucifer is online now   Reply With Quote
Old 03-27-2013, 03:02 PM   #102
JimRidesThis OP
Local celebrity
Oddometer: 267
It's an engine Jim...
Well, I finally managed get the bathroom finished (almost) and that meant I got an evening to play with the XL engine.
This is where I'd got to...
XL600R
So, next it was on with the piston, rings and barrel, but not before I had removed the crank pinion to fit the new camchain which wouldn't fit in between that and the oil pump
XL600R
...then, on with the camchain guides, head, tensioner and cam
XL600R
ALL STOP!
When I took the engine apart the cam sprocket bolts didn't match each other. One is the OEM M7(!) bolt while the other looks like it's of a bicycle brake system (just a guess) - chromed, domed allen screw.
I guess this might not be a problem, but for the sake of a few pence, I'll get a couple of M7 bolts from the local engineering supplies shop.
More to follow!
JimRidesThis...
1992 TDM850 "Ivy"
Old 04-01-2013, 03:03 PM   #103
JimRidesThis OP
Local celebrity
Oddometer: 267
Talking Made some progress today...
XL600R Rebuild
XL600R Rebuild
XL600R Rebuild
XL600R Rebuild
XL600R Rebuild
XL600R Rebuild
JimRidesThis...
1992 TDM850 "Ivy"
Old 04-01-2013, 04:24 PM   #104
Moparmanpete
Support all riders
Oddometer: 294
Looking Good Jim!!!!
Old 04-07-2013, 02:46 PM   #105
JimRidesThis OP
Local celebrity
Oddometer: 267
Talking
DSC_0018
JimRidesThis...
1992 TDM850 "Ivy"
Times are GMT -7.   It's 04:08 PM.
