Old 01-16-2013, 11:40 PM   #72901
Magnum Noel
Magnum Noel's Avatar
Oddometer: 189
Dear Procycle and motolab. I have a dyno jet needle and main jet with an opened air box and my bike runs like a charm with no detramental side affects that I can detect, Runs way better than it did in its standard configuration.
Just my two bobs worth.
regards Noel
Magnum Noel is offline   Reply With Quote
Old 01-16-2013, 11:49 PM   #72902
Chill
Chill's Avatar
Oddometer: 326
Thanks for the braking info LucasLeader and Adv Grifter. I think I'll start with new fluid, braided lines and new pads and take it from there. I'm not looking for huge gains, just a bit more bite and feel after a few "moments" commuting.
Thanks.
Chill is offline   Reply With Quote
Old 01-17-2013, 12:07 AM   #72903
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Originally Posted by Carl Childers View Post
Thanks! Mine was even more restricted than your before shot. Judging by your after picture I think I'll stop where I'm at I've got it cleaned out to that point but don't want to weaken the joint.
Mine cracked from a mis-aligned mid-pipe but not near the weld...
NordieBoy is offline   Reply With Quote
Old 01-17-2013, 04:23 AM   #72904
Anklyne
Anklyne's Avatar
Oddometer: 87
Originally Posted by motolab View Post
How many miles are there on the carburetor? Was the bike ever parked for an extended period?
Regards,
Derek
25,000Km (~15,500 miles). Not sure really. It's had 2 previous owners that I know of and the guy I bought it off said he mainly ended up using it for trips down to the shops (he was in a rural area so it was a decent ride).
Probably is a damn good idea I give the internals a check I guess...
Anklyne is offline   Reply With Quote
Old 01-17-2013, 07:18 AM   #72905
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,292
There's another DR thread for folks who are extra sensitive
How is it I can sit at a bar with a guy, have a heated debate, tell eachother "awe bullschmitty and flippover" then buy each other beers talking about the hottie that just walked in the door all without any hard feelings?
But on the interwebz forum, folks get their mangina all dry and chaffed.
Relax already!
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 01-17-2013, 07:45 AM   #72906
neo1piv014
ADV in training
Oddometer: 621
Originally Posted by TinkerinWstuff View Post
New topic anyone?
Is that the 790 kit or the high compression piston?
Sent from my LG-P999 using Tapatalk 2
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 01-17-2013, 07:59 AM   #72907
TinkerinWstuff
Take it apart
Oddometer: 1,292
standard bore high comp
1999 Suzuki DR650
Old 01-17-2013, 08:19 AM   #72908
Escaped
Escaped's Avatar
Oddometer: 488
Brisk Commute
I had a nice brisk commute n the Sacramento CA Area this morning on my 2006 DR650!
27 degrees fahrenheit @ 80 miles per hour actual = wind chill effective temp of 4 degrees F - burrrr!
No electric gear I might add.
Done on my dr bought new in 06 with about 40,000 miles and with DynoJet Kit, slide drilled and side cover removed, installed and working great for 35,000 miles or so (still power only wheelies and gets an avg 46 mpg)
2006 DR650 54,407 miles
DR650 - Eyes open all of the time
Escaped is offline   Reply With Quote
Old 01-17-2013, 09:21 AM   #72909
motolab
motolab's Avatar
Oddometer: 2,777
I would pay particularly close attention to:
The float needle's tip: Check with and without magnification for a witness line where it has been contacting the seat. If one is found, the float valve either leaks or will begin leaking soon, causing a high fuel level or overflowing.
The needle seat o-ring: Make sure it fits snugly and is not cracked/hardened/deformed/shrunken/otherwise damaged. If it's not in good shape, it will leak, causing overflowing.
The slide guide: Make sure that the indentations concentric with the bore in the bottom corners adjacent to where the slide bottoms are still .010" (.25mm) deep or more. If they are not, the emulsion tube is at risk for wear. See http://www.moto-lab.com/gallery/view?itemid=300, http://www.moto-lab.com/gallery/view?itemid=301, http://www.moto-lab.com/gallery/view?itemid=298, http://www.moto-lab.com/gallery/view?itemid=299, and http://www.advrider.com/forums/showp...ostcount=68638.
The slide: Make sure there is no vertical grooving on the downstream side and that the lift hole area has not been increased by drilling. Drilling causes excessive slide guide and slide wear, which in turn accelerates emulsion tube wear. See http://www.moto-lab.com/gallery/view?itemid=304, http://www.moto-lab.com/gallery/view?itemid=302, http://www.moto-lab.com/gallery/view?itemid=303
The emulsion tube: If the outlet has ovaled, the mixture will become overly rich at low rpm at all openings. The wear can sometimes be hard to see, but keep in mind that .0004" (.01mm) of wear will be discernible on the dyno as an approximately 1 percentage point change in CO (i.e. it the CO was 4% before the wear, it would now be 5%). Sometimes spinning the tube between your fingers can help you see the wear, as can inserting something known to be round, however if the slide guide is worn more than .010" (.25mm), you can pretty much be assured that the emulsion tube is worn. See http://www.moto-lab.com/gallery/view?itemid=305, and http://www.advrider.com/forums/showp...ostcount=33350.
The pilot jet: I recommend replacing it as a matter of course.
The float height: Using a float height setting tool, set it to it to 14.7mm.
More photos can be found over at http://advrider.com/forums/showthread.php?t=347184.
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-17-2013, 11:16 AM   #72910
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
regards Noel
Same here.
I think both Jeff and Derek have good points and both are right.
I can say that I could never get my DR to run well shimming the stock needle with any combination of jetting.
Sure, it ran, but I knew it wasn't it's best. But I think Derek was always talking about a NON USA OEM. These have notches ... unlike USA needle which are non adjustable. I think Derek also mentioned a few KTM needles as perhaps being a good fit to the DR.
The DJ needle has (for me) made a huge difference overall. I'm sure there are better needles ... and since my DJ needle now has about 35,000 miles on it, I'd be happy to try something else. My bike has never been dyno'd so all my assessments are "seat of the pants".
Derek, I'm in the Bay area ... if you can recommend a better needle I could buy ... I would try it out.
I can see some slight wear on my current DJ needle, but bike still runs strong; starts, idles well, around 50 MPG, 102 MPH (measured) top speed (prone) and power wheelies in 2nd gear ... no clutch.
155 main, stock Pilot, open air box top, Twin Air, stock muffler, 1/2 turn out on fuel/air screw, no header weld grind .... 50,000 miles. Throttle response on my bike could be crisper ... but not sure the DR motor is really ever a "crisp" revver. It's no Triumph Daytona after all.
Old 01-17-2013, 11:34 AM   #72911
motolab
motolab's Avatar
Oddometer: 2,777
Originally Posted by Adv Grifter View Post
Same here.
Does your bike have the airbox mod? What pipe does it have?
Regards,
Derek
Old 01-17-2013, 11:48 AM   #72912
doug s.
Oddometer: 1,348
Regards,
Derek
from his post:
"...open air box top, Twin Air, stock muffler, 1/2 turn out on fuel/air screw, no header weld grind..."
doug s.
doug s. is offline   Reply With Quote
Old 01-17-2013, 11:57 AM   #72913
motolab
motolab's Avatar
Oddometer: 2,777
Originally Posted by doug s. View Post
from his post:
doug s.
Right. That's embarrassing. Anyhow...
Well I guess that disqualifies the bike from the possibility of being the "definitive" candidate for tuning demonstration. However that certainly shouldn't be a reason not to tune it if that's what Mr. Grifter would like.
Regards,
Derek
Old 01-17-2013, 12:14 PM   #72914
Adv Grifter
Oddometer: 6,128
Regards,
Derek
By my "seat of the pants" evaluation, it's tuned fairly close. But as mentioned, my DJ needle shows some wear, may need replacement?
And this bike has not been on the dyno.
Given my basic tuning set up ... what needle would you recommend to maintain status-quo or maybe go one better? I suppose I should check out your thread on Vendors?
Old 01-17-2013, 12:37 PM   #72915
TinkerinWstuff
Take it apart
Oddometer: 1,292
1999 Suzuki DR650
Times are GMT -7.   It's 11:53 AM.
