Old 01-17-2013, 01:56 PM   #72916
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,524
Originally Posted by TinkerinWstuff View Post
Looks like TinkerinWstuff is tinkering with stuff again. Hope you didn't get a hernia lifting that motor out.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 01-17-2013, 02:08 PM   #72917
rpet
Awesometown
rpet's Avatar
Oddometer: 820
It's pretty clear that Motolab's use of the word "tune" is much narrower than other dudes' in this thread.
To generalize a little further, I think a lot of DR dudes are just happy with a bike that runs smoother than stock and subjectively seems faster.
For myself, I like to see posted dyno charts with thorough explanations of the set-up and tune that made them. That helps me make what I believe to be more informed purchases. However I probably won't ever be dyno'ing my personal ride, so strictly speaking, won't ever have an optimally-tuned bike.
Keep at it boys!
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 01-17-2013, 02:55 PM   #72918
motolab
motolab's Avatar
Oddometer: 2,775
Originally Posted by Adv Grifter View Post
By my "seat of the pants" evaluation, it's tuned fairly close. But as mentioned, my DJ needle shows some wear, may need replacement?
In the pics, the DJ needle looks like it's made out of stainless steel, so it won't wear all that rapidly, but that does mean that if wear is visible, other parts, such as the emulsion tube, slide guide and slide are likely to have borne the brunt.
And this bike has not been on the dyno.
Would you like it to be?
Given my basic tuning set up ... what needle would you recommend to maintain status-quo or maybe go one better?
If you want to maintain the status quo, put another DJ needle in it. If you want better, try the non-USA oem needle or the KTM needle. However I would inspect the carb and replace any other worn parts first. If you do go with other than the DJ needle, be prepared to start over with your tuning.
Regards,
Derek
motolab is online now   Reply With Quote
Old 01-17-2013, 03:17 PM   #72919
Trbig67
Oddometer: 108
Problem... I rode the bike one day and everything was fine. Next day when I started it, it was puking oil out everywhere. I found out that the seal around the shaft the front sprocket is on has popped out. I tapped it back in place.. seemed like a nice tight seal, started it up and watched it get slowly pushed right back out again and oil dump all over. Why is the crankcase building up this much pressure? Plugged hose/vent somewhere? I don't know where the vent is on this thing.
Thanks.
Trbig67 is offline   Reply With Quote
Old 01-17-2013, 03:57 PM   #72920
BergDonk
BergDonk's Avatar
Oddometer: 3,790
Thanks.
This is not unknown. It happened to me on a cold start so I made a mechanical retainer. I ended up making and selling a stack more. I don't do them anymore, but Procycle does. Get one, bolt it on and problem fixed. And for others out there, do it before its a problem as insurance, because when it happens it really is a PITA.
My story starts at #197 here:
http://www.advrider.com/forums/showt...646076&page=14
There is more over on DRR:
http://drriders.com/topic5922.html
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 01-17-2013, 04:02 PM   #72921
Trbig67
Oddometer: 108
So there isn't a plugged vent somewhere? This is just one of those inherent things of the bike?
Old 01-17-2013, 04:03 PM   #72922
Trbig67
Oddometer: 108
And.. I've never seen what you're talking about on the regular DR650 page of Procycle. Is it listed somewhere else? Does it have an official name?
Old 01-17-2013, 04:17 PM   #72923
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Look again - it's there!
Old 01-17-2013, 04:26 PM   #72924
Trbig67
Oddometer: 108
FInally found it. Thank you.
Old 01-17-2013, 06:37 PM   #72925
Load Clear
Oddometer: 35
Rear Brake Lever
Hey guys - are rear brake pedals all the same? Bent mine up pretty good and plan to put a new one on.
Load Clear is offline   Reply With Quote
Old 01-17-2013, 07:03 PM   #72926
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,292
that thing isn't too bad.
This was as far as I got by 5pm today. Maybe have it wrapped up tomorrow if I'm ultra super lucky.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 01-17-2013, 07:07 PM   #72927
LucasLeader
LucasLeader's Avatar
Oddometer: 293
I've never seen an aftermarket replacement. I think it's just mild steel so you should be able to bend it back into shape. I've had to do it with my shift lever.
LucasLeader is offline   Reply With Quote
Old 01-17-2013, 07:25 PM   #72928
ER70S-2
ER70S-2's Avatar
Oddometer: 6,891
The question has been asked: "How heavy is the DR engine?" You could tell us here AND post it up in Krusty's DR Index (Hiya Krusty, thanks again for the DR650SE INDEX ). Or you could let us down and be forgotten forever.
Here: Topic 12:
http://www.advrider.com/forums/showp...2&postcount=32
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 01-17-2013, 07:42 PM   #72929
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,840
I bought two of the first batch Procycle made up.
Old 01-17-2013, 07:46 PM   #72930
TinkerinWstuff
Take it apart
Oddometer: 1,292
Here: Topic 12:
I will see what I can do!
I just know it should be 1ounce lighter now than it was before
1999 Suzuki DR650
Times are GMT -7.   It's 08:51 AM.
