01-17-2013, 04:02 PM
#73081 |
Oddometer: 108
So there isn't a plugged vent somewhere? This is just one of those inherent things of the bike?
01-17-2013, 04:03 PM
#73082 |
Oddometer: 108
And.. I've never seen what you're talking about on the regular DR650 page of Procycle. Is it listed somewhere else? Does it have an official name?
01-17-2013, 04:17 PM
#73083 |
Awesometown
Oddometer: 331
Look again - it's there!
'76 Xl250 '04 XR250R '09 DR650 '10 TR450 |
01-17-2013, 04:26 PM
#73084 |
Oddometer: 108
FInally found it. Thank you.
01-17-2013, 06:37 PM
#73085 |
Oddometer: 25
Rear Brake Lever
Hey guys - are rear brake pedals all the same? Bent mine up pretty good and plan to put a new one on.
Thanks |
01-17-2013, 07:03 PM
#73086 | |
Take it apart
Oddometer: 1,116
This was as far as I got by 5pm today. Maybe have it wrapped up tomorrow if I'm ultra super lucky.
1999 Suzuki DR650 1998 Honda VFR800 Interceptor http://share.findmespot.com/shared/f...KJutW9osVpn3hd |
01-17-2013, 07:07 PM
#73087 |
Oddometer: 276
I've never seen an aftermarket replacement. I think it's just mild steel so you should be able to bend it back into shape. I've had to do it with my shift lever.
01-17-2013, 07:25 PM
#73088 | |
Oddometer: 2,564
). Or you could let us down and be forgotten forever. ![]() Here: Topic 12: http://www.advrider.com/forums/showp...2&postcount=32 |
01-17-2013, 07:42 PM
#73089 |
Procrastinators
Oddometer: 5,812
I bought two of the first batch Procycle made up.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
01-17-2013, 07:46 PM
#73090 | |
Take it apart
Oddometer: 1,116
I will see what I can do! I just know it should be 1ounce lighter now than it was before
01-17-2013, 09:03 PM
#73091 | |
Oddometer: 2,564
Tank ewe.
![]() Quote:
01-17-2013, 10:18 PM
#73092 | |
Oddometer: 214
Currently riding DR650 (2011) Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks
01-18-2013, 06:45 AM
#73093 | |
Take it apart
Oddometer: 1,116
But by the time you have it far enough apart to attempt to remove the jug in the frame, it's three more motor mount bolts and a couple other misc garbage to have it on the ground. Literally less than 10 more minutes to have it on the bench. Too bad my bench is over flowing with other garbage and there was no room for the motor.
01-18-2013, 07:10 AM
#73094 |
Oddometer: 1,607
Just a tad over 100 pounds.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
01-18-2013, 07:15 AM
#73095 |
Oddometer: 1,607
Yes, the top end can be serviced in the frame. It's not much more work to remove the whole thing but leaving the bottom end in the frame gives you a built in 'engine stand' to hold it firmly when installing the cylinder, rotating the crankshaft, torquing the head bolts, etc.
