Old 01-18-2013, 08:51 AM   #1
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,933
Voltage, Temp, Time Meter
Introducing our Panel Mount voltage, temperature and time meter
This is the auto function mode
From our website:
Waterproof digital panel mount Voltage, Time and temperature meter.
Manual or automatic selection of function: manual selection using push button or auto cycle shows each function for 5 seconds.
DC 4-30v volts
12 hour clock
Temperature (F) - 2560 F maximum, 1 meter long thermocouple with stainless steel probe.
Sunlight viewable, anti-glare screen, bright red characters
Two button switch panel controls : 3.5" (89mm) leads
Three wire connection: Red power, Green voltage signal, Black ground. 5" (128mm) length leads.
Wiring allows the voltmeter to measure a different source than what is powering the meter. Connect power and ground to a switched connection and the meter will turn on with your vehicle.
Panel cutout size (width X height)-1.5" X .83" or 38mm X 21mm
Flange dimensions (width x height)- 1.6" X .95" or 41mm X 24mm
Depth is .6" or 15mm from back of flange
Overall depth is .7" or 18mm from front of flange
Old 01-18-2013, 06:14 PM   #2
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,933
Two decimal places on the Voltage
Old 01-19-2013, 09:34 AM   #3
Johno33772
Johnny Africa
Johno33772's Avatar
Oddometer: 873
These look great....next time we get togther...I will take one .
Cheers
JA
KTM 1190R / XR500 Street tracker project/ KTM 500XCW / KTM 300XCW / Sherco 2.9 / Honda ZA50,Ural Patrol
Johno33772 is offline   Reply With Quote
Old 01-19-2013, 01:21 PM   #4
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,272
I ASSume...
The temp is for eng. coolant ? A nice ambient temp would be nice. I haven't seen one yet that I'm thrilled about.
For those that fight for it, freedom has a flavor the protected will never know.
Motomantra is offline   Reply With Quote
Old 01-20-2013, 05:16 PM   #5
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,933
The temperature can be used for ambient or engine coolant, plenty of range.
Old 01-21-2013, 11:15 AM   #6
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,272
Great. Thanks.
Old 01-22-2013, 06:43 AM   #7
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,933
The meter has a very durable stainless steel temperature thermocouple.
Old 01-22-2013, 07:51 AM   #8
kbuckey
Oddometer: 808
Well, nice to have one gauge to replace three. Even though there's a fair amount of room behing that dual sport fairing! Just ordered one.
kbuckey is offline   Reply With Quote
Old 01-22-2013, 08:37 AM   #9
mwood7800
Oddometer: 612
Where can I find just a temp (water) gauge in a mini led that's in F
mwood7800 is offline   Reply With Quote
Old 01-22-2013, 09:11 AM   #10
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,933
Thanks for your business!
What time zone are you in? I'll set the time for you.
Old 01-22-2013, 10:04 AM   #11
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,475
Since the voltage signal is the same as the source power in this case is there any reason those two terminals couldn't be jumped and have a single wire coming in?
swimmer is offline   Reply With Quote
Old 01-22-2013, 10:19 AM   #12
ParaMud
ParaMud's Avatar
Oddometer: 626
Can we set the time ourselves?
08 wr250r
04 xt225
ParaMud is offline   Reply With Quote
Old 01-22-2013, 10:59 AM   #13
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,933
The meter has seperate signal and power wires. The benefit is you can connect the power wire to a switched (on/off with bike) and the meter comes on or turns off with the bike. You can connect both wires to the same source.
Yes, the meter has a small 2 button sub-panel.
Old 01-22-2013, 11:42 AM   #14
kbuckey
Oddometer: 808
Mountain.
Old 07-09-2013, 09:35 AM   #15
HSRacer
HSRacer's Avatar
Oddometer: 115
Is this still available, I don't see it on your website?
HSRacer is offline   Reply With Quote
Times are GMT -7.   It's 11:33 PM.
