Old 01-18-2013, 08:08 AM   #91
SikDMAX
Oddometer: 720
Still interested in it for my shop when the new stuff comes out....
Matt - SikMoto www.Facebook.com/SikMoto San Luis Obispo, CA
SikDMAX is offline   Reply With Quote
Old 01-18-2013, 11:15 AM   #92
aiMhi OP
Now with Titanium
aiMhi's Avatar
Oddometer: 688
Thanks for the note SikDMAX. I will reach out to you ok.
aiMhi - Honda XR650R - AMA- RMAR
aiMhi is offline   Reply With Quote
Old 01-19-2013, 12:37 PM   #93
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,364
I did not read the whole thread so I hope I'm not repeating something.
It's my understanding zinc will damage CAT converters, so if I have a late model with a CAT will it be okay?
For those that fight for it, freedom has a flavor the protected will never know.
Motomantra is offline   Reply With Quote
Old 01-19-2013, 01:26 PM   #94
aiMhi OP
Now with Titanium
aiMhi's Avatar
Oddometer: 688
You are correct that Zinc can reach toxic levels for high tech catalyctic converters especially the ones designed for cars that are made to last 150K miles, not so much for bikes. I don't know what you ride but the oil is certified to conform to JASO MA-2 API SL so check your manual and go from there.
I agree this discussion got a bit Zinc crazy but it is all about having a balanced additive package and staying within the manufacturers specifications.
Old 01-22-2013, 07:47 PM   #95
totensiebush
re-tarded
Oddometer: 97
Is the price going to increase with the reformulation? I'd like to pick up a case, and I'm assuming the new stuff will be better, but if there's a big price increase it might be worth it to pick up the old stuff instead.
totensiebush is offline   Reply With Quote
Old 01-23-2013, 04:10 AM   #96
aiMhi OP
Now with Titanium
aiMhi's Avatar
Oddometer: 688
There will be a bump in price but will also make it available in Gallon containers as well... I think that is the way to go and then if you like it get the case. The old formulation has been discontinued.
Thanks for the question.... I am just waiting for the release of the product at this point.....
Old 01-23-2013, 11:27 AM   #97
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
How are the wrist and the subframe coming along?
You gonna be ready for some spring riding?
Old 01-23-2013, 04:31 PM   #98
SikDMAX
Oddometer: 720
Got your message a few days ago - thanks. Im interested in the new formula when its ready to go - if you can forward me the dealer pricing for the new stuff if you have it I can plan a stocking order for when its ready to sell. Thanks!
Matt
Old 01-23-2013, 05:40 PM   #99
aiMhi OP
Now with Titanium
aiMhi's Avatar
Oddometer: 688
Right now just working though my bike from front to back when I can, done front bearings, steering stem bearings, replaced shock fluid, installed HDB handquards and Rox Risers, re-did wiring, need to set valves for the season and then there is the damage... ordered replacement footpeg and some other pieces...the subframe is ok, a little bent. The shift in the rear subframe was really due to the aluminium tab bending 1/2 inch inward due to the impact - I will work this weekend on heating and bending it, it if breaks then need to get the aluminium rewelded.
The broken bones in the hand is healed up and the ligament in thumb ok, a little dumb still but getting there. Separated shoulder is 99% and clavicle ok now....fun stuff - I am hoping end of April, May to get out so you have to hook us up on an evil ride!!
Thanks again for you and Blane's help getting back
Old 01-23-2013, 05:41 PM   #100
aiMhi OP
Now with Titanium
aiMhi's Avatar
Oddometer: 688
Matt
Sounds great Matt - I will work up some figures for you and get out to you. Shooting to have it to you by this weekend ok.
Old 01-23-2013, 09:26 PM   #101
Blaise W
Blaise W's Avatar
Oddometer: 679
As soon as the new formulation is available I am in for a case. I already have two cases of other oil ready to go, but I'll give Royal a shot and also use my Blackstone testing kit when I come back from my summer in Colorado. Huskys need high zddp and combining that with full synthetic is a winner in my book. Up to now it has had to be semi-synthetic to get the zinc levels I want.
Blaise W is offline   Reply With Quote
Old 02-10-2013, 01:29 PM   #102
aiMhi OP
Now with Titanium
aiMhi's Avatar
Oddometer: 688
Hi - Time to change your bike's oil and get ready for the season? Please check first post for the latest release information on the new formulation 10w-40 and 15W50 Full Synthetic 4-Stoke Motorcycle Oil.
VOA's and PDS sheet available in the next couple weeks.
Old 02-10-2013, 01:52 PM   #103
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
Glad to see 10w-40 in the line-up now!
I'll get a gallon of it in a bit and see how my DR650 shifts (a known hard shifter at times) with it. Nice work!
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 02-10-2013, 01:59 PM   #104
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
Originally Posted by DockingPilot View Post
I am ready for a oil change (1,k miles on oil) on my 2012 DR650, 7k on the clock. Amsoil 10w40 being the oil of choice. Ill run a UOA on it. Ive done prior ones.
I am going to purchase the new formulated blend here as soon as available.
Ill go the same mileage and send it out to Blackstone as well for a head to head comparo on the 10w40 blend with the thumper/shared gearbox/wet clutch mill.
If it's better, you got my business.
i'm interested in those results too Frank. i'm a Redline and Amsoil user.
Alaska
Old 02-10-2013, 02:03 PM   #105
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
Update: 01/17/12 Slight delay due to certification delays
New reformulated Full-Synthetic 10W40 & 15W50 to be released Feb 1st-8th
Have these gone through any JASO testing?
JASO - MA is what most are expecting to see (and you're hard pressed to convince the cheaper ones who buy Rotella or Rotella T at Walmart) and now that's been augmented by MA1 and MA2
http://katriders.com/vb/showthread.php?t=83732
http://www.bobistheoilguy.com/forums...Number=1883244
Alaska
Times are GMT -7.   It's 04:35 AM.
