Old 01-17-2013, 09:53 AM   #46
ShineySideUp
Oddometer: 91
Ride On
Ride On product claims that if you use their product it will balance your tires and seal them from punctures.
I've had the Ride On product in 3 of my mc tires and it seems to work as advertised. Last year I got a roofing nail in my rear tire. I don't know how long the nail was in my tire as it did not lose air. Mechanic at my stealer saw the nail in the tire during a routine service. I put new tire on and more Ride On - gives me piece of mind on the road.
Ride Free - Ride Far - But Ride
I wonder where that road goes?
ShineySideUp is offline   Reply With Quote
Old 01-17-2013, 10:14 AM   #47
Multiplicity
Oddometer: 172
Originally Posted by Megadeus View Post
In cars, which have a longer radius from the axle to the tires' edge, I find a static imbalance to emerge around 45-55 mph.
If I balance said tire and I have a vibration around 65~75 mph, I am suspect of a road force induced imbalance. A road force caused by rim run-out or imperfection in the tires' construction.
Sometimes the road force imperfection can be alleviated by reclocking the tire on the rim 180 degrees. Most of the time it's a runout issue with the rim. ie... bent lip, broken spokes, etc....
The other kick in the nuts is that if you ride a bike with an imbalance for a while, say 500+ miles, you end up wearing the tire circumference into an oblong shape. (Think egg shaped) The oblong shaped tire induces a vibration no matter how many times you put weights on it or put balancing media into it. Dynabeads only work with a good true rim and a new tire. Worn/questionable tires (track take offs) will not always balance out because you don't know if it's worn evenly.
This is why some people bitch that dynabeads didn't work for them. Their used tires are F'ed.
You know it 110% on the money
Multiplicity is offline   Reply With Quote
Old 01-17-2013, 11:12 AM   #48
bwalsh
bwalsh's Avatar
Oddometer: 11,904
Originally Posted by blackx70 View Post
When I got my bike, there were weights on the front wheel. I replaced the tire and removed the weights. I did a spin balance and could not find a heavy spot. I have been running with no weight on the front and everything seems fine.
I think, or would like to think, that tire production has evolved far enough that sometimes, most of the time, all of the time, they are dead nuts balanced when formed in the mold.
To be honest about my experience, I have never tried to balance my tires any other way, first. Hell, for all I know, all the tires I have mounted may not have needed balancing at all and I may not have needed the beads. But for less than the cost of one tire balance(You get charged for the service whether your tire needs weights or not) they have more than payed for themselves.
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 01-18-2013, 06:17 AM   #49
kantuckid
Oddometer: 3,082
Originally Posted by ttpete View Post
I've never used the beads, and I don't intend to try them. I own a Coats bubble balancer, and I can balance a wheel in about 10 minutes. Why mess with something that's worked for me for about 30 years?
As they say, you can't teach an old dog to use beads?
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Old 01-18-2013, 06:24 AM   #50
kantuckid
Oddometer: 3,082
Originally Posted by anotherguy View Post
The dot is the light side of the tire. It is to be placed at the valve stem.
I have a Snap-On computerized balancer at my disposal. I have Dynabeads in the tires.
We had a customer buy a set of wheels that were way out of balance to the point they needed 3 1/2 ounces of lead weights. He couildn't bear that ugly stuff on his shiny new wheels. So we got him some Dynabeads and installed them. Worked very well on a very shitty set of wheels. I was sold. And I was quite skeptical prior to that experience but that's changed.
Curious how many dyna beads to balance that 3.5oz out rim?
Old 01-18-2013, 06:31 AM   #51
kantuckid
Oddometer: 3,082
Your statement lacks info such as how many miles on tire at that point in it's life & if it was worn in a way that it was still concentric & also was it worn evenly vs. say scalloped or chicken stripped or worn on one side more than other-all which are common & expected- sorry to say that your scenario doesn't add information as to wheel balance issues. Not a reproach just saying nothing added to the conversation here.
FWIW, if the assy was in balance w/o weights it seems likely that after much use the tire would be worn unevenly or maybe the weights caused it to "become" concentric/in balance? You also don't say why the weights were removed?
Old 01-18-2013, 06:32 AM   #52
kantuckid
Oddometer: 3,082
Doesn't it hamper repairs made on the road?
Old 01-18-2013, 06:43 AM   #53
kantuckid
Oddometer: 3,082
Even though I worked in a tire plant & fixed the machinery therein I too would like to hear whats changed since my 1960's/70's time there? FWIW, the "G Machine" that tractor fronts were built on was patented when G. Washington was president! Large truck tires were often still built on a similar machine. The car tires were either on a newer or older machine but it was about how the tire builder got the ply stock to the build drum and had zero to do with the actual tire itself-WHICH WAS HANDMADE! Every layer of material had hands on!!! involvement in the ply & tread application & splice quality to a large extent. Variations were hidden within the tire parts prior to curing & after. I was a green tire inspector for awhile after a military stint put my apprenticeship classes out of sync. You can place a crappily built tire in the mold and it may well come out looking perfect. Human & machine inspections after curing attempt to remove the bad ones but they are handmade still as far as I know???
All I ever read in MC mags is superficial info on tires & the tire ads are sameo.
Old 01-18-2013, 08:19 AM   #54
bwalsh
bwalsh's Avatar
Oddometer: 11,904
Originally Posted by [B
blackx70]I replaced the tire
No one has included mileage numbers(except me in two posts), wear pattern info. Just whether they had a smooth ride with Dyna beads or not.
His scenario was as good if not better than others who have posted. I'm sure if someone experienced weird tire wear they would have mentioned it. To me a smooth ride=even wear...(at least that's how I see my tires wearing) unless the tire is screwed up from the factory.
Uh, maybe to have a "fresh" start on his "new-to-him" bike? Just like changing oil, cleaning the air filter, checking the tires, tire pressure, grease zrek fittings, checking the chain and all the other items folks usually check, tweak, when they buy a bike, car, whatever. I fI was putting a new tire on a rim, I'd sure start from scratch instead of with a bunch of weights on the rim, wouldn't you?
~snip~
Funny how one misused word sets people off. OK, I should have said "made" instead of "formed in the mold". Better?
Using industry specific terms doesn't add anything to the conversation. Just sayin...
Hand made, machine made, don't know, don't really care as long as they are usable when I buy them.
2004 XR650L
Old 01-18-2013, 07:39 PM   #55
kantuckid
Oddometer: 3,082
No, I was not "set off" with your choice of terms and could care less as to made in a mold,etc.. My point was pretty clear that tires -in my experience were handmade and having never read anything to the contrary since that time they really are the same other than the ply fiber materials having evolved some and tread compounds are at least "said" to be magical in there ability to keep us upright. Modern tires are better in balance? I see weights on rims all the time but only a high volume sales/mounting person can really answer that one. Relax, its a conversation about tires.
Old 01-19-2013, 08:38 AM   #56
anotherguy
anotherguy's Avatar
Oddometer: 6,605
Originally Posted by MotorradMike View Post
Just to be clear, you didn't try the wheel/tire assembly (with DynaBeads) on the computerized balancer. Correct?
No. Just saying I can balance any way I want. Even have a manual set up.
you don't see luggage racks on a hearse..........act accordingly
Old 01-19-2013, 09:42 PM   #57
brad1098
/\ dumb
Oddometer: 840
Hey experts.
3 sets of tires balanced the old way, zero issues or vibrations.
New tires and dynabeads. Major vibration at 70 plus mph?
I don't remember how many oz I put in. It was the recommended amount from dynabeads
brad1098 is offline   Reply With Quote
Old 01-20-2013, 02:09 AM   #58
everycredit
everycredit's Avatar
Oddometer: 272
I don't know why people are defending dynabeads so much.
If you ran your wheel without balancing and it's out of balance and then added dynabeads, does it run balanced? If so, go for it. If not, I would get my wheel balanced the old fashioned way.
everycredit is offline   Reply With Quote
Old 01-20-2013, 02:29 AM   #59
_cy_
Oddometer: 6,312
Old 01-20-2013, 09:14 AM   #60
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,960
Originally Posted by _cy_ View Post
Ding, ding, winner!!!!!!
I love these tire threads. The amount of bullshit being slung around by both sides of the argument is always sooooo much fun to watch.
I'm starting to believe that all Dynabead threads should be sent down to CS&M.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Times are GMT -7.   It's 09:31 PM.
