01-18-2013, 11:00 AM
#2296 |
Oddometer: 1,051
Throttle stop
Lost Rider:
Yes, I saw that throttle stop screw when I was fiddling with the air cleaner on my new CRF. Has anyone fiddled with it to eliminate stalling? Reason why I thought of this is my son's mazda 3 at 40,000 miles has developed an unstable in-gear idle...and the recognized fix for it is to clean oil and dirt from the throttle body (introduced by the PCV), then make the computer "re-learn" the closed throttle position, by disconnecting the negative post of the battery for 10 minutes, then reconnect it. Would seem the CRF's ECU probably has some "learning" capabilities. |
01-18-2013, 11:09 AM
#2297 | |
Oddometer: 1,051
#2298 |
Oddometer: 357
Hmmmmm, bike or wife, seems like you can have both, and both are keepers. Watch out, the LRP may become "her bike".
CRF250L, always cleaned while it's raining C14 |
01-18-2013, 11:12 AM
#2299 |
Oddometer: 1,051
01-18-2013, 11:35 AM
#2300 | |
Oddometer: 148
Semper Fidelis |
01-18-2013, 11:42 AM
#2301 |
Oddometer: 357
Had a SL125 (a used 71), could go through tight stuff faster than with a 250 SDR I moved up to. I think I sold it for the same price I paid for it, as was done with many bikes back then. Yes, kicking isn't fun, but if it's a Honda, I'll bet it doesn't take too many to get it running. Too bad it isn't "primary", you have to find neutral before kicking, never a problem back then, because it wasn't available.
01-18-2013, 11:56 AM
#2302 | |
Oddometer: 357
CRF250L, always cleaned while it's raining C14 SAPB screwed with this post 01-18-2013 at 12:01 PM |
01-18-2013, 12:00 PM
#2303 |
Oddometer: 300
Ed@Ford, I guess we just have hit that ripe old age and it's just fun to easy back and enjoy life. I too looked at the WR, but decided I would never ride it to its potential.
John |
01-18-2013, 12:05 PM
#2304 |
Oddometer: 357
I sat on one, was put off by the seat height, I'm 5' 9", and can nearly flat foot both on the CRF.
01-18-2013, 12:18 PM
#2305 |
Oddometer: 300
Funny story, a guy riding a WR250 came by to see me last week and look at my CRF250L. He was about your height (5'9") and when he left my house he pushed his WR over to a big rock by the driveway so he could get on. I chuckled to myself and wondered if he always needed to find a rock to get on, I thought you just used the footpeg.
John |
01-18-2013, 12:28 PM
#2306 | |
Oddometer: 357
#2307 |
Oddometer: 17
Does anybody know where i can find white plastics or the silver seat that comes on the overseas model?
Thanks |
01-18-2013, 12:53 PM
#2308 |
Oddometer: 147
Dampers
anybody have any thoughts on Dampers ?
installation pic's here the sub mount on the CRF250R looks better but I don't think its offered for the CRF250L |
01-18-2013, 01:06 PM
#2309 |
Broken Roadie
Oddometer: 2,790
Oh good they're finally out!
Best all around performance upgrade a person can do IMHO. From much better on-road handling, less head shake, etc to dirtier adventures where hitting rocks, ruts, logs, sand, riding on loose gravel, etc a damper WILL make a noticeable different for any rider and help reduce fatigue. A damper has undoubtably saved me countless times on other bikes, and can't wait for Nancy to feel the improvement. Too bad our winter budget is totally blown already, going to another bike of ours that got sick pretty bad and had to get fixed up. ![]() ASAP I will be getting one for the LRP. Scotts told me I'll still be able to run the ROX risers/bar adaptors with a ProTaper and HDB guards above the damper with their setup. |
01-18-2013, 01:10 PM
#2310 |
Oddometer: 357
Otherwise, riding a decently modded, more modern DS bike of certain models allow great trips out west in the mountains and deserts with almost guaranteed reliability and durability over many years with most service concerns involving oil changes, the occasional valve clearance check, and replacing worn tires.[/QUOTE]
TNC, I lurked on the KLX forum, and saw you did the Tubliss conversion. I have both front and rear here, waiting for the weather to be too bad for riding, before bringing the wheels in the house for conversion. Any tips that you would like to share would be much appreciated, one guy (not sure which tread) said he sloshed the crap out of it with tire conditioner, and did it all by hand, to avoid pinching the inner tube. Thinking to do it, check the pressure, then wait overnight, check pressure again before slapping the wheels back on. The video on the Tubliss site is pretty informative. Slime both inner, and in the tire? Thanks.
CRF250L, always cleaned while it's raining C14 SAPB screwed with this post 01-18-2013 at 01:26 PM |
