Old 01-17-2013, 11:17 AM   #46
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,892
Originally Posted by rboett View Post
That's what we need, a Kermit Table!
Here's ADVMax choking his chicken in my Kermit chair and 18" roll-top table.
8" seems like it'd be a little low.
Every saint has a past and every sinner has a future.
If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl.
Xeraux screwed with this post 01-17-2013 at 11:25 AM
Xeraux is offline   Reply With Quote
Old 01-17-2013, 10:29 PM   #47
Montauk
Oddometer: 280
Originally Posted by Xeraux View Post
18" roll-top table.
This table by company some like GSI or Gxx is no longer available. The stopped making them.
Montauk is offline   Reply With Quote
Old 01-17-2013, 10:58 PM   #48
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 374
To clarify, the table I modified ended up 12" high.
It is a bit low, but useful for most camp chairs.
ElMartillo is online now   Reply With Quote
Old 01-17-2013, 11:32 PM   #49
markjenn
Oddometer: 10,424
I've used one of these for years for car camping....
but carrying any table on a motorcycle seems to me to be over that admittedly gray line between carrying stuff you really need and carrying crap that mostly overloads the bike.
- Mark
Old 01-18-2013, 06:18 AM   #50
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,892
But RIO still does. It's the exact same table and roughly the same price.
http://www.amazon.com/RIO-Adventure-...837629&sr=1-39
A currently available version of the 18" GCI and L.L. Bean Table we discussed earlier.
Old 01-18-2013, 06:58 AM   #51
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,744
18" roll-top table..
What brand is your 18' table?
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 01-18-2013, 07:04 AM   #52
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,892
The one in the picture is the original GCI table, but this one is exactly like it even down to the little velcro loops for hanging a grocery bag to use for trash.
Old 01-18-2013, 07:30 AM   #53
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,744
Thanks.....
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
Old 01-18-2013, 10:22 AM   #54
meatwitheyes
Bon Vivant
meatwitheyes's Avatar
Oddometer: 1,839
I found this on Ebay and it looks very interesting. Comes in three sizes and under 2 pounds. Called the Buck703
Somebody buy one and give use a review...
http://www.ebay.com/itm/New-Black-Li...-/190709993624
Michael...... (that's a pretentious Mike)
aka beatnikmike
The Taciturn Misanthropist... Everyone seems normal until you get to know them.
All education is liberalizing
meatwitheyes is offline   Reply With Quote
Old 01-18-2013, 11:26 AM   #55
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,705
What you smoking Micheal? $50 on a table when there are rocks, stumps and dead possums laying about that will support your camp-stove and beer cozee!
West - "Oeste Sanchez"
RideAbout is online now   Reply With Quote
Old 01-18-2013, 12:15 PM   #56
meatwitheyes
Bon Vivant
Oddometer: 1,839
West:
Me! ….. It's not for me….. I would neverrrrr....... well
Many of the inmates of this asylum are forever in search of the lighter more compact gadget. So they may make their outdoor experience even more like an indoor experience. I was simply providing a service by passing on information to aid them in their quest for more and lighter stuff.
But back to me …. I am perfectly happy to set my cozeeeed beer on a dead possum in fact if said possum is not to long dead they make a mighty fine pillow and not bad smoking either…..
aka beatnikmike
Old 01-18-2013, 02:34 PM   #57
SgtDuster
SgtDuster's Avatar
Oddometer: 3,276
Talking about Ebay and chinse stuff...you can find these folding tables there too, for less than 50$:
I don't dislike the aluminium one. Not sure I'd use it but it looks cool.
2010 Buell Ulysses
1984 Suzuki GR650 "Tempter"
SgtDuster is offline   Reply With Quote
Old 01-18-2013, 07:23 PM   #58
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 374
Can you show pictures of the side angle along with new pivot point at the sides. And another showing the bottom closed and fully extended.
Thanks. I liked way you did. I don't quite like the 18" REO Roll-Top Table, it's the packing I don't like. I want to make it even smaller and low eight to fit my Kermit Chair.
Per request, here's a run-through of the 3 basic modifications to the $23 Walmart table.
First, I removed the two outer slats by drilling out the rivets underneath:
KEEP IN MIND, THE FOLLOWING PHOTOGRAPHS ARE POST-MODIFICATION.
Next, I trimmed off the slat supports, as close to the remaining slats as possible, using a file to remove burrs and sharp corners:
I then removed the leg supports by removing the round plastic buttons and drilling out the rivets. I then moved the support as close to the slats as I could with the table closed, and re-riveted. The aluminum is so thin you don't really need a drill, you can push a hole through with a punch. After riveting, replaced the plastic buttons:
After the above step, I removed the plastic "feet", and chopped the legs. Replaced "feet".
Lastly, I changed the leg pivot point. To do this you'll need to drill out the existing rivets, and replace with a coupla binding rivets. I also used nylon washers. The binding rivets can be purchased at Home Depot. This is a stock photo, they are not the length I used:
I picked a point about halfway down the new, shorter legs. You can see the old pivot holes circled in red:
Final dimensions are 18.5"w x 14.5"d x 12"h open, 18.5" x 16.25" x 2" folded.
I hope this helps!
Cheers
Old 01-18-2013, 08:02 PM   #59
Brun
Brun's Avatar
Oddometer: 193
I had been thinking about the need for a Table Shaped Object (TSO) for a couple of years whilie struggling with all sorts of makeshift arrangements. Recently I added a single seat and wooden pack rack to transform my old R90 into a sort of up-market postie bike. I also made some new soft bags to go with this setup. To mount the bags properly I then needed some Rack Shaped Objects (RSOs). At this stage it dawned on me that two connected RSOs looked pretty similar to a TSO, if a lid could be added. So here is my particular DIY solution.
The RSO / TSO sitting inverted on the wooden rack. The black stuff is rubber sheet. The lid is 9mm hardwood marine ply with a few coats of marine varnish. Legs are 6mm stainless rod, Bars between legs are 25x3 and 40x3 stainless. I ground rounded points on the feet so they can stick into the ground if necessary.
Bags hanging off the subframe with the TSO in place. There is a bit of soft grippy material to protect the rack.
Bag straps tensioned over the TSO to hold it all together, and my bedroll pack on top.
I've done about 2500kms with this setup. The TSO has proved its usefulness, but I'm now looking for a bigger bit of marine ply. The table could be somewhat larger in length and breadth.
O and here is a shot of the sort of use the table has been getting.
Cheers
Charlie, and the lovely Brunhilde (74 R90/6)
Graduate, Wallace and Gromit School of Engineering and Design (pending)
Brun is offline   Reply With Quote
Old 01-18-2013, 11:35 PM   #60
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 374
Originally Posted by Brun View Post
Nice looking setup. I like the custom wooden back rack, everything looks like it works well and is pleasing to the eye.
Cheers!
Times are GMT -7.   It's 10:12 AM.
