01-17-2013, 09:14 AM
#286 | |
Oddometer: 33
http://advrider.com/forums/showthrea...836894&page=26 Or on UKGSer. From post 12 http://ukgser.com/forums/showthread.php?t=136812
Money isn't everything. But it keeps the kids intouch
01-17-2013, 09:38 AM
#287 | |
Oddometer: 2,418
01-17-2013, 10:56 AM
#288 |
Oddometer: 9
A Humble contribution to this thread. Led daytime light, just beneath the beak.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Nothing to deal with those great works above, but I tried to do my best. Panzerkampfwagen screwed with this post 01-17-2013 at 11:13 AM |
01-17-2013, 11:21 AM
#289 |
Oddometer: 9
Sorry. Wrong post.
01-18-2013, 03:26 PM
#290 |
Oddometer: 267
I made a tail pipe extension for my 1150GS with Jesse bags.
I know there are a lot of threads out there on this, but I decided to do it myself after being annoyed by this: ![]() I got 1 3/4" ID exhaust pipe and used some throttle return springs and nuts that I had. I removed the silencer end, using 8mm socket. ![]() Then cut the pipe so it fits under my left turn light. ![]() Dry fit ![]() Measured the springs so I know where to weld the nuts to hold the springs. ![]() Welded the nuts using a cheap harbor freight welder I've owned for several years. Does the job, but not weld (please don't judge my welds--I know they suck, but they hold). ![]() Here it is fitted ![]() With my pannier back on. Need to cut the end for fit. ![]() Used an angle grinder to sharpen the edge, so in a pinch it can be used as a weapon ![]() ![]() ![]() Went for a ride, doesn't rattle or leak. Hopefully it will keep all (if not most) of the hot exhaust gasses off my pannier. |
01-18-2013, 07:22 PM
#291 | |
"Cool" Aid!
Oddometer: 41,494
![]() Jim
01-18-2013, 08:06 PM
#292 |
Oddometer: 267
05-19-2013, 11:20 PM
#293 |
Oddometer: 46
Relay controlled power outlet on my BMW R1150GS
![]() ![]() ![]() ![]() For more information about the relay controlled socket check my blog: http://www.gsrider.net/2013/05/relay...on-my-bmw.html
my blog: http://GSrider.net/ |
