Old 01-19-2013, 05:00 AM   #3256
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 4,716
GPX file on GoogleDrive
Here's the GPX track, so folks can get practice loading their GPSs.
Download 2013 Middleburg Tarmac Ride GPX here
Click on download
Click Save
Open windows explorers, transfer file from your computer to your GPS SD card.
I've also put it on post #2 of this thread under rides and GPX files.
Here's the finale tally I've got
Rendezvous point #1: WaWa RT301/RT06 (departing 0840)
5362 James Madison Parkway, King George, VA
Blaster
Dorito
EOD3MC
J4S
Macorell (RT301/RT225 pickup)
RaysGSA
RaysGSA Son
Rendezvous point #2: Target on RT 17/I95 (departing 0910-ish)
25 South Gateway Drive, Fredericksburg, VA
VacCommuter (with Latte)
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito screwed with this post 01-19-2013 at 05:52 AM
Dorito is offline   Reply With Quote
Old 01-19-2013, 05:37 AM   #3257
macaroni
Oddometer: 668
Don't forget me!
Tell someone you love them today, because life is short...but shout it at them in German because life is also terrifying and confusing.
macaroni is offline   Reply With Quote
Old 01-19-2013, 05:44 AM   #3258
EOD3MC OP
What will break next
EOD3MC's Avatar
Oddometer: 4,504
Just me....no AJ
EOD3MC is offline   Reply With Quote
Old 01-19-2013, 06:08 AM   #3259
lakota
Geeser
lakota's Avatar
Oddometer: 2,820
Any idea where the lunch stop will be?
IBA #42016
my ride reports
lakota is offline   Reply With Quote
Old 01-19-2013, 06:27 AM   #3260
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 4,716
It will probably be around 1130
Red Horse Tavern LLC
112 West Washington Street, Middleburg, VA
Old 01-19-2013, 09:35 AM   #3261
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 4,716
Plan it!
Game ON!
The 2013 Pine Barrens 300, Sponsored by Cross Country Cycles, Metuchen NJ and The Ocean County
Competition Riders will take place Nov 16th and 17th.
Linky Here
Old 01-19-2013, 10:38 AM   #3262
joints4sale
No. Not "That Kind".
joints4sale's Avatar
Oddometer: 2,721
For that, I might just join the AMA.
Erik : IBA #40645
"If my life or death depends on getting Bruce or Dana on the phone then I'm gonna die." RFlagg42
2011 TC449, 2014 S1000R, 2010 R1200GSA 30th Anniversary Edition, 2003 Ktm 625sxc(gone), 1999 DR350(gone), 2007 K1200GT (traded for the GSA). 2004 R1150R (traded for the GT)
joints4sale is offline   Reply With Quote
Old 01-19-2013, 10:55 AM   #3263
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,504
Big bikes or little bikes ??
Old 01-19-2013, 11:30 AM   #3264
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 4,716
Last year, they really wanted the big bikes...and had the course designed for the pigs.
Old 01-19-2013, 11:43 AM   #3265
blaster11
Fidus et Audax
blaster11's Avatar
Oddometer: 6,206
Erik.....Dan said you are so screwed! Your 625 has a high likelihood of killing you with all the power it's making now. Oh and the suspension should work way better as well.
Bruce
“Great minds discuss ideas, average minds discuss events, small minds discuss people. ” H. Cameron
IBA # 46755
Adventures of Blaster and Dorito
blaster11 is offline   Reply With Quote
Old 01-19-2013, 11:44 AM   #3266
blaster11
Fidus et Audax
blaster11's Avatar
Oddometer: 6,206
Really does it matter....either way it should be a good time and its relatively close.
Bruce
IBA # 46755
Old 01-19-2013, 01:26 PM   #3267
Terp
Oddometer: 50
...rookie question for all you single-track riders w/ handguards. What's the best way to install the full bar type on the throttle side? I have seen some cut off the little lip on the end of the grip, roll back the rubber a little, take a sliver off the throttle tube, and install that way. However, I am worried about dirt and crap getting between the tube and the bars, given the guard bar doesn't cover the hole 100%...if that makes any sense.
Here's a shot of how I did the clutch side. I left the lip on there, heated up a socket and pressed into the center of the end cap (to score out a perfect circle as a template), and then tapped out the center with a drywall cutting tip on the Dremel. It was nerely perfect, but there was a small opening that the Cycra bar didn't cover...so I used a black neoprene washer to seal it off to help reduce the amount of dirt/water that gets in there.
That being said, I am just not seeing how to seal up the throttle side, given I can't have rubber on rubber washers binding and sticking the throttle. I am 99% sure I need to remove the rubber lip, but I just envision a big gapping hole that lets in tons of dirt between the throttle tube/bars.
Thoughts?
Terp is offline   Reply With Quote
Old 01-19-2013, 02:34 PM   #3268
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,504
Dana, if I'm reading the route right...we will pass right by Old House Winery...Karen has two bottles of wine ready for pick up...may need to make a small stop to keep MaMa happy
18351 Corkys Lane, Culpeper, VA 22701
3 miles up Stevensburg Road (Rt. 663) from Rt 3
Loading Maps....Comms gear charging... almost ready to roll
Old 01-19-2013, 02:35 PM   #3269
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,504
Agreed
wonder if AJ will have his bike by then....
Old 01-19-2013, 03:00 PM   #3270
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 4,716
Originally Posted by Terp View Post
... However, I am worried about dirt and crap getting between the tube and the bars, given the guard bar doesn't cover the hole 100%...if that makes any sense.
When I installed the Cyras on the DR, I cut off the ends orange ends of the pillow grips off each side. I seem to spend a lot of time picking it up off the ground. So far, no throttle binding to report despite snorkeling through the dirt like a submarine.
I didn't check, but it's possible. I don't really care where we go tomorrow, I just need to get off the peninsula. So, lead on wherever! [Bonus points for not breaking the bottles though]
Full disclosure, I've not "test-ridden" the route. It was a compile from two sources. We may love or hate it!
Times are GMT -7.   It's 06:49 PM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
