Old 01-17-2013, 02:33 PM   #15766
bill pierce
I don't wana pickle
bill pierce's Avatar
Oddometer: 741
hey guy's
I'm having some clearance issues between the chain guide and wide rims.
Its kinda hard to see in the picture but the nut is dangerously close to the tire. Is there a aftermarket chain guide that gives more clearance? Is the chain guide needed for mostly street/forest service roads?
Better picture of the whole bike.
bikes
BMW R1100s,destroyed by deer strike.
Yamaha FZR 1000 (sold)
Honda Cr 500 sold
bill pierce is offline   Reply With Quote
Old 01-17-2013, 02:46 PM   #15767
PeteN95
PeteN95's Avatar
Oddometer: 2,780
Bill, if you have more room on the other side, you can adjust the spokes to move the rim to the right side. Just loosen the spokes on the left one turn each, tighten the spokes on the right one turn each, and repeat until it is centered.
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 01-17-2013, 03:17 PM   #15768
Bpeters
Oddometer: 1
Originally Posted by bill pierce View Post
hey guy's
Quick fix: flip the bolts around so the nut faces to the outside of the swingarm
Bpeters is offline   Reply With Quote
Old 01-17-2013, 03:40 PM   #15769
bill pierce
I don't wana pickle
Oddometer: 741
I looked at that, the problem is the heads are counter sunk on the wrong side. I can counter sink the other side and use big washers on the nuts. Just not a real clean solution.
bikes
Honda Cr 500 sold
Old 01-17-2013, 04:50 PM   #15770
hontri
Global Bummer!
hontri's Avatar
Oddometer: 304
Here is what i did.4 years and no problem!
My buddy just left his off altogether. No problems either.
hontri is offline   Reply With Quote
Old 01-17-2013, 04:54 PM   #15771
bill pierce
I don't wana pickle
Oddometer: 741
hey thanks, that looks like a good solution.
bikes
Honda Cr 500 sold
Old 01-17-2013, 05:24 PM   #15772
mattc
mattc's Avatar
Oddometer: 451
Also make sure that the wheel spacers are in the correct side. Just realized after having the same problems with my Warp9's that the spacers are different offset, so I swapped them, and no more issues.
mattc is offline   Reply With Quote
Old 01-17-2013, 05:42 PM   #15773
lemanster
lemanster's Avatar
Oddometer: 87
Here is another option... this is exactly what I did to mine, works great.
http://www.supermotojunkie.com/showt...hain-guide-mod
00 XR650R Cali plated motard/trail pig
04 CR250R
lemanster is offline   Reply With Quote
Old 01-18-2013, 12:58 AM   #15774
atreiou
XR 650R Rider
Oddometer: 61
same issue form me in the past
, with 4.25 rims simply rotate the bolts and keep the nut outside istead inside (not very beautiful but works)
with 5" rim cut the inner plastic wall of the chain guide near the rim..
[QUOTE=bill pierce;20510943]hey guy's
atreiou is offline   Reply With Quote
Old 01-18-2013, 08:15 PM   #15775
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
That is what I did to mine and it works well. I have a xrs only chain guide too(I use it with my dirt set) and it does not fit at all with a supermoto rim. The modified stocker works better.
lstzephyr screwed with this post 01-19-2013 at 05:11 PM
lstzephyr is offline   Reply With Quote
Old 01-19-2013, 03:41 PM   #15776
Unsung
Oddometer: 60
Need a bit of help. I started working on this over a month ago but I had to leave the country. I replaced my clutch center after one of the bolts broke out and hit the cover. I finally got around to putting it all back in today, I didn't try to crank it. The clutch isn't working at all. I put it in neutral and it rolls fine, I kick it in gear and hold the clutch and nothing. The only thing I know of I did wrong was when I put the clutch push rod in, the bike wasn't in neutral. Is this most likely my problem? If I pull the cover off and the pressure plate, and move that rod around do you think it'll pop down somewhere where it should be and work? If not, I have no idea what's going on.
Unsung is offline   Reply With Quote
Old 01-19-2013, 05:10 PM   #15777
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
I would open it back up and check to see if you put everything in right. If you did then check the adjustment.
Old 01-19-2013, 10:38 PM   #15778
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,296
When in gear and you pull in the clutch lever, you say "nothing". What do you mean exactly? Does the rear wheel not spin? The clutch rod shouldn't be affected by the transmission gear position when you install it. It just transfers the action through the motor to the clutch pack.
I'm guessing that your clutch plates are sticking a bit since it's sat for some time. With cold oil, there is quite a bit of viscosity to overcome to get the friction and drive plates to "let loose". Try putting the bike in a taller gear, pull in the clutch and then try to spin the rear wheel again. Or, put the bike on the ground (again in a taller gear), pull in the clutch AND decompression levers, and slowly rotate the kickstarter through it's range. That should break the friction and drive plates.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 01-19-2013, 11:09 PM   #15779
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,429
I have a set of these tanks up for sale ......ill show you guys first
These are very rare and not available to ya avrage punter
they hold 44 ltrs full exelent setup for long haul
these cost me 515 bucks so thats what there up forsale as
no mounting kit ..has to made by the owner ..not a real big job but skills are needed to fit them
the set i have forsale are clear IE white looking
pm me for more details ... i will post them anywhere
Sean-0 is offline   Reply With Quote
Old 01-20-2013, 04:10 AM   #15780
achile
achile's Avatar
Oddometer: 289
F^%$# carburetor!!!
Hey!
Sorry to bug you, but I have a problem that's driving me crazy!
I overhauled the top end of my piggy(piston rings, valves, seats, springs, camshaft bearings...you get the idea).
I dismantled the carb, cleaned it, set the level, needle setting(the needle is new)...etc.
1) the bike starts very hard
2) when it starts, the idle goes wild(from normal to 3000 revs)
3) very litle response from the air screw(new as well)
4) when I rev it, it dies after releasing the throtle
I suspect an air leak due to worn carb body and throtle valve(the only thing I didn't check). The intake boot is new.
I had this problem before the top end work, but it intensified after. More vacum/compression=more air leaking => leaner mixture??
I found crf 450 carburetors(FCR 41) on ebay. I'm thinking about buying one.
What say you?
Thank you,
Alex
achile is offline   Reply With Quote
Times are GMT -7.   It's 01:11 AM.
