Old 01-16-2013, 11:07 PM   #61
crobox OP
crobox's Avatar
Oddometer: 324
Originally Posted by dirtyron View Post
looking good christian. been considering one of these myself.if only they kicked over as easily as an xr650r.
Is this Ron DT?
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox is offline   Reply With Quote
Old 01-17-2013, 07:44 AM   #62
dirtyron
never grew up
Oddometer: 322
yeah, ron here. lets ride!
dirtyron is offline   Reply With Quote
Old 01-17-2013, 10:16 AM   #63
crobox OP
crobox's Avatar
Oddometer: 324
Hey Ron- good to see you on here! No big surprise, really.
Well it'll be a little while before I'm ready to go for a ride. I've sold 3 bikes in the last year, two of which were runners. And this bike is currently the closest thing I've got to a runner... so like I said it will be a little while. But when this bike is done, anyone reading this thread will know it!
See you around
Old 01-19-2013, 01:37 PM   #64
crobox OP
crobox's Avatar
Oddometer: 324
When I picked up my head from my buddy who did the valves we talked a bit about "gasket matching" and other ways to reduce turbulence in the intake and exhaust passages.
Here is how the intake passages matched up to the insulating spacer before I did any work:
And after some die grinder and dremel work:
I know it looks like the inside surfaces are all full of grinding marks, but they are from a pretty fine sanding drum and are quite smooth to the touch.
I did similar smoothing work on the exhausts, although I didn't do any diameter enlarging on those the way I did on the intakes.
Old 01-19-2013, 01:41 PM   #65
crobox OP
crobox's Avatar
Oddometer: 324
And after re-assembling and bolting down the head and cam, putting the crank at TDC, and pulling the forward side (the "pull" side) of the cam chain taught, I found this:
You can see that the witness marks on the sprocket do not align with the gasket mating surface. I'm pretty sure this means the cam chain is stretched. I posted this pic in the main XL600 thread for feedback, and I'm including it here just for continuity.
-Christian
Old 01-19-2013, 01:53 PM   #66
mcma111
mcma111's Avatar
Oddometer: 11,901
How about rotating the engine to see if in fact there are the three cam marks.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-19-2013, 01:54 PM   #67
joexr
Oddometer: 3,773
The surface of your intake ports should not be smooth anyway , but you should polish the exhaust ports.
Old 01-19-2013, 03:11 PM   #68
crobox OP
crobox's Avatar
Oddometer: 324
I received the 3/4" x .120 wall stainless tubing in the mail yesterday, and made some progress today on the rack / pannier mount system.
Here is what it looks like now:
The larger diameter (3/4") tubing coming out towards the sides of the bike will be one of the main supports for the panniers. This tube is supported pretty directly by the rear-most mount points of the frame (which you can see I beefed up earlier with triangulation in the sub-frame), so most of the weight on the rear rack, and much of the weight of the panniers, will go straight down into these points. There will be two other points of attachment to the bike as well. You can also see the diagonal tubing that I added, which goes from the very rear of the top rack down into this same area just discussed, the mount-points at the rear of the bike frame. I made a provision to run the turn signal wires within these diagonal tubes, which you can see mocked up (the green and orange wires disappearing into the tube). Purpose-specific tabs on the rear rack carry not only the turn signals, but also the rear fender.
Old 01-19-2013, 03:15 PM   #69
crobox OP
crobox's Avatar
Oddometer: 324
Yep, I'm gonna do that is soon as this guy lets me!
Maybe tonight.....
Old 01-19-2013, 04:50 PM   #70
crobox OP
crobox's Avatar
Oddometer: 324
how about rotating the engine to see if in fact there are the three cam marks.
nope. No third mark.
Old 01-19-2013, 04:54 PM   #71
mcma111
mcma111's Avatar
Oddometer: 11,901
Looks like you will be purchasing a new cam chain.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-19-2013, 07:44 PM   #72
davek181
Oddometer: 842
I put a cam chain in mine at 40K, and the marks still didn't line up perfectly. I wasn't too concerned since they rarely line up perfect on any bike or car I have worked on. It ran fine, and was much quieter.
davek181 is offline   Reply With Quote
Old 01-19-2013, 08:55 PM   #73
crobox OP
crobox's Avatar
Oddometer: 324
Hmmm... conflicting opinions.... what to do? what to do?
I'll take Sunday to think it over.
Seems wise to replace it. But saving money and time is always attractive.
Simply writing that last line makes me think I'll end up replacing it....
Old 01-19-2013, 09:16 PM   #74
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
I'll add my .02.
I rebuilt two XR5 RFVC engines not too long ago. One 83 and one 84. One was running and needed freshening up because it consumed some oil, the other was literally a parts bike with the engine in pieces, along with another 84 parts bike (enough parts to build the second bike).
First, the cam sprocket for these old RFVC only had two marks on them, like yours. I think the extra alignment mark came later.
When putting the top ends back on after the valve replacement, I tried to use the cam chains that I had on hand. All three of the used cam chains showed stretching just like yours.
I decided that I was only going to do the rebuild job one time (famous last words, I know ) so I bought two new chains from XRsOnly.
Both new chains lined up the marks perfectly upon installation.
The bikes do perform well after the rebuilds, which is what I was after.
Ghost_Mutant is offline   Reply With Quote
Old 01-19-2013, 10:44 PM   #75
Homerb
Oddometer: 455
Maybe tonight.....
I reckon a good doctor would be able to do something about those feet!!!
Homerb is offline   Reply With Quote
Times are GMT -7.   It's 02:03 AM.
