01-20-2013, 01:06 PM
#61 |
A proud pragmatist.
Oddometer: 3,004
Looks like we lost the OP 4 pages ago.
I wonder if he took them beads off by now and either try riding without balancing or balanced with weights.
Have tools, will travel!
01-20-2013, 01:12 PM
#62 |
Rectum Non Bustibus
Oddometer: 3,643
When I balance a wheel/tire assembly with weights, I KNOW it's in balance and can prove it.
When someone pours plastic beads in a tire, they HOPE it's in balance, but can't prove it. Go to a pro race sometime and see if any of the factory tire busters use beads. They don't.
10 Ducati 1098 Streetfighter S - "Sleipnir" 09 Kaw Versys "The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher ttpete screwed with this post 01-20-2013 at 01:24 PM |
01-20-2013, 02:15 PM
#63 |
Oddometer: 623
Ok.
Since I'm on the side of it didn't work for me. How do I get the beads out of the tube to keep from buying new ones? |
01-20-2013, 07:50 PM
#64 |
Oddometer: 1,589
Well ill jump in here for the heck of it. I run dynabeads on my Tiger. Used them in a set of kenda big blocks, 150/70-17, 110/80-19. I installed the recommended amount. I never had any vibrations of any kind even at speeds of 100mph. The set of big blocks went 5000 miles and am changing them now. Even wear patterns on both tires. All that with tubeless tires.
When you're lost in the wild and scared as a child. And death looks you bang in the eye, and your sore as a boil, its according to Hoyle to cock your revolver... and die. But the code of a man says "fight all you can" and self-dissolution is barred. In hunger and woe, its easy to blow... Its the hell-served-for-breakfast thats hard........Robert Service |
01-22-2013, 08:04 AM
#65 | |
Oddometer: 1,705
I've run the beads for a few years & have been getting normal wear & smooth riding. I reuse them, they're easy to install & not so complicated from there to say , why not? As to removing them from a tube w/o a knife, you've got me there...
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85 |
01-22-2013, 08:50 AM
#66 | |
Rectum Non Bustibus
Oddometer: 3,643
Might as well cut the tube open because new tires deserve new tubes anyway.
10 Ducati 1098 Streetfighter S - "Sleipnir" 09 Kaw Versys "The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher |
01-22-2013, 09:01 AM
#67 | |
Oddometer: 7,799
I'm still running the original tubes in my Mtn. bike. It's a 1992 model. Tubes don't disintegrate after one or two uses but if you feel they do I'll gladly send you my snail mail address and you can recycle them.
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
01-23-2013, 06:47 AM
#68 |
Oddometer: 1,705
Dyna beads are stated to not work by the seller for wide/low profile tires. Many car tires these days are in that category. I remember them saying they don't disperse across the width properly for good balancing.
01-23-2013, 07:43 AM
#69 | |
Rectum Non Bustibus
Oddometer: 3,643
I can balance a motorcycle wheel in 10 minutes using weights and see no need to screw around with plastic pellets that would take longer and make a mess the next time I had to break it down.
01-24-2013, 05:55 AM
#70 |
Oddometer: 1,705
I really enjoy bead threads. They are ceramic, if "Dyna Beads" the air gun pellets are the plastic. As to making a mess, that's hardly the case as these pellets are very tiny-similar in size to maybe #12 shot like's in a .22 birdshot shell-definitely smaller than #9 shot,as an e.g.. I find it easy to recycle them. If I drop a few , no big deal & if your shop is like mine a stray ceramic bead thats around 1/32" in diameter won't cause much problem.
I reweigh what I catch(I dump them on a plastic scrap when changing tires) & use over. Takes little effort
