Old 01-18-2013, 12:58 AM   #15781
atreiou
XR 650R Rider
Oddometer: 45
same issue form me in the past
, with 4.25 rims simply rotate the bolts and keep the nut outside istead inside (not very beautiful but works)
with 5" rim cut the inner plastic wall of the chain guide near the rim..
[QUOTE=bill pierce;20510943]hey guy's
I'm having some clearance issues between the chain guide and wide rims.
atreiou is offline   Reply With Quote
Old 01-18-2013, 08:15 PM   #15782
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,713
Send a message via AIM to lstzephyr
Originally Posted by lemanster View Post
Here is another option... this is exactly what I did to mine, works great.
http://www.supermotojunkie.com/showt...hain-guide-mod
That is what I did to mine and it works well. I have a xrs only chain guide too(I use it with my dirt set) and it does not fit at all with a supermoto rim. The modified stocker works better.
lstzephyr screwed with this post 01-19-2013 at 05:11 PM
lstzephyr is offline   Reply With Quote
Old 01-19-2013, 03:41 PM   #15783
Unsung
Oddometer: 52
Need a bit of help. I started working on this over a month ago but I had to leave the country. I replaced my clutch center after one of the bolts broke out and hit the cover. I finally got around to putting it all back in today, I didn't try to crank it. The clutch isn't working at all. I put it in neutral and it rolls fine, I kick it in gear and hold the clutch and nothing. The only thing I know of I did wrong was when I put the clutch push rod in, the bike wasn't in neutral. Is this most likely my problem? If I pull the cover off and the pressure plate, and move that rod around do you think it'll pop down somewhere where it should be and work? If not, I have no idea what's going on.
Unsung is offline   Reply With Quote
Old 01-19-2013, 05:10 PM   #15784
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,713
I would open it back up and check to see if you put everything in right. If you did then check the adjustment.
Old 01-19-2013, 10:38 PM   #15785
Cpt. Ron
aka Birdkilla
Cpt. Ron's Avatar
Oddometer: 2,408
When in gear and you pull in the clutch lever, you say "nothing". What do you mean exactly? Does the rear wheel not spin? The clutch rod shouldn't be affected by the transmission gear position when you install it. It just transfers the action through the motor to the clutch pack.
I'm guessing that your clutch plates are sticking a bit since it's sat for some time. With cold oil, there is quite a bit of viscosity to overcome to get the friction and drive plates to "let loose". Try putting the bike in a taller gear, pull in the clutch and then try to spin the rear wheel again. Or, put the bike on the ground (again in a taller gear), pull in the clutch AND decompression levers, and slowly rotate the kickstarter through it's range. That should break the friction and drive plates.
Cpt. Ron
Sack-O-Tomato, CA
'05.5 950 Adventure S "Bad Mutha F@&ker"
'04 R1150RTP "cop motor, cop suspension.."
'00 XR650R Dual Sport "Lil' Mule"
'75 RL250
'01 TTR90
'01 PW50
Conti TKC80 tire swing
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 01-19-2013, 11:09 PM   #15786
Sean-0
Kicker Brother
Sean-0's Avatar
Oddometer: 3,120
I have a set of these tanks up for sale ......ill show you guys first
These are very rare and not available to ya avrage punter
they hold 44 ltrs full exelent setup for long haul
these cost me 515 bucks so thats what there up forsale as
no mounting kit ..has to made by the owner ..not a real big job but skills are needed to fit them
the set i have forsale are clear IE white looking
pm me for more details ... i will post them anywhere
Sean-0 is offline   Reply With Quote
Old 01-20-2013, 04:10 AM   #15787
achile
achile's Avatar
Oddometer: 288
Send a message via Yahoo to achile
F^%$# carburetor!!!
Hey!
Sorry to bug you, but I have a problem that's driving me crazy!
I overhauled the top end of my piggy(piston rings, valves, seats, springs, camshaft bearings...you get the idea).
I dismantled the carb, cleaned it, set the level, needle setting(the needle is new)...etc.
1) the bike starts very hard
2) when it starts, the idle goes wild(from normal to 3000 revs)
3) very litle response from the air screw(new as well)
4) when I rev it, it dies after releasing the throtle
I suspect an air leak due to worn carb body and throtle valve(the only thing I didn't check). The intake boot is new.
I had this problem before the top end work, but it intensified after. More vacum/compression=more air leaking => leaner mixture??
I found crf 450 carburetors(FCR 41) on ebay. I'm thinking about buying one.
What say you?
Thank you,
Alex
achile is offline   Reply With Quote
Old 01-20-2013, 04:42 AM   #15788
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,632
Originally Posted by achile View Post
Hey!
What say you?
Thank you,
Alex
Hanging idle is usally too tight of cables or the valves are too tight. When the cables are too tight the work against each other to hold the slide up for a period of time, when it does come down the other adjustments may be off not letting it idle. Check the freeplay at the grip and make sure it will rotate back and forth a little bit (ensuring they aren't too tight) To check for a cable prob forcebly close the throttle after a rev so the push cable pulls the slide down, if the revs drops down immediately then it's a cable issue.
If the valves are too tight it makes all kinds of wierd running cond including hanging idle and failure to idle. I've seen some pretty worn carbs that had no adverse effect on the running, I'm sure that could happen esp since we can't really see how bad the carb is but it'd be very unusual.
It's not uncommon for the valves to settle in the head a good bit right after a topend job, that would cause them to tighten up relatively quickly. Tight valves = hard starting also. Im thinking that's the issue.
Chris
VIDEOS
RideFreak screwed with this post 01-20-2013 at 04:51 AM
RideFreak is offline   Reply With Quote
Old 01-20-2013, 05:24 AM   #15789
achile
achile's Avatar
Oddometer: 288
The cable is new and oiled, freeplay is fine, valve clearence is in specs, timing is fine. I started the bike with a makeshift gas tank, without the cable. The bike revs itself up, dosen't respond to air screw movement.
It's driving me crazy.
Update:
Went to the garage, took off the carb.
-the throtle valve rotates around it's center(left-right) and the lower gap changes in size
-the valve has a bit of play and can rattle back and forth
-the levers that operate the throtle valve are worn
I will take the carb apart and check the extent of the wear.
achile screwed with this post 01-20-2013 at 05:58 AM
Old 01-20-2013, 01:43 PM   #15790
jm-2008
jm-2008's Avatar
Oddometer: 322
Carby problem
ACHILE -
This make me wonder if the slide has not been placed correctly on its alignment pin.
If in the correct position you should not be able to rotate the slide.
This will effectively hold it open causing it to rev like mad and not respond to air screw.
Remove the top cover and rotate the slide till it finds the alignment pin.
If set correctly the slides cutaway will be on the intake (air filter side)
JM-2008
jm-2008 is offline   Reply With Quote
Old 01-20-2013, 03:02 PM   #15791
Cpt. Ron
aka Birdkilla
Cpt. Ron's Avatar
Oddometer: 2,408
Edlebrock pump part
There has been obvious concern with Edlebrock not providing replacement parts for their pumper carburetor. One difficult part to source is the cup on the accelerator pump, especially if the bike sits for length of time with ethanol fuel left in it. I don't have a source yet for an exact part, but I have found out that it is a 1/2" diameter cup. Similar to what is found here:
http://quadrajetparts.com/rochester-...ly-p-1056.html
Or here:
http://www.mikescarburetor.com/Holle...up_p_1060.html
Good hunting.
Cpt. Ron
Sack-O-Tomato, CA
'75 RL250
'01 TTR90
'01 PW50
Old 01-20-2013, 03:28 PM   #15792
Unsung
Oddometer: 52
I read that it should be in Neutral when installed the push rod so that it is properly seated. I put the bike in gear and pull the clutch and it will not roll. I had the clutch discs out, oiled each pieces separately and stuck them in one at a time, then poured a bit more oil at the top so it would go in between the discs.
Old 01-20-2013, 03:35 PM   #15793
larryboy
Paint it black.
larryboy's Avatar
Oddometer: 13,035
That's how a wet clutch works, go for a ride.
Old 01-20-2013, 04:01 PM   #15794
Unsung
Oddometer: 52
Thank the lord, I think that is the problem. I ran it for 30 seconds to check the oil, about to top it off. After I ran it I put it in gear and clutch it, and if I rock it twice it breaks loose and rolls good. I am trying to top this oil off, I've put 1 quart and a 1/4 in it just about, and it stays on the bottom centimeter of the dipstick. Every time I add more, it doesn't move. I think maybe if I start it I'll get better results? My question is, from the bottom of the dipstick to the upper mark, how much oil fills that gap? Another question I have is with the chain. I put a new chain on it, used a tool to rivet the masterlink in. One side of the masterlink is a little tighter I guess, because it's not letting the chain flex at that pivot point as easily as the rest of the chain, is this a problem? I can make it flex if I grab it and do it.
I've put so much new stuff on this thing, can't wait to ride it. It had a silencer in the pipe that was probably robbing it of a lot of power. I went from a 48t to a 43t rear sprocket. Has new streetable tires on it as opposed to the dirtbike ones it had before. Riding this thing tomorrow will probably feel like a completely different bike.
On a side note, I had a problem with my clutch handle sticking when I clutched it 100% sometimes, I just realised it's the handguard bracket catching the end of the lever when it's fully compressed.
Unsung screwed with this post 01-20-2013 at 04:09 PM
Old 01-20-2013, 04:31 PM   #15795
larryboy
Paint it black.
larryboy's Avatar
Oddometer: 13,035
After a quick oil/filter change I just dump in 1.5 quarts to get me started. Check the oil with the engine idling is how I do it, about .5 from the bottom mark to the top. If you really work at it you can get the full 2.1 quarts out of the thing if you don't rush the oil change.
Get a sight glass kit for peace of mind, riding down the road you can just clutch it and let it idle, glance down and check the oil level.
Times are GMT -7.   It's 12:52 AM.
