Old 01-20-2013, 09:09 PM   #52021
ONandOFF
Must / takeit / easy
ONandOFF's Avatar
Location: Harrisonboiig; Shenandoah Valley riding wonderland
Oddometer: 4,393
Originally Posted by dancerdave View Post
anyone ever try riding double on their big red Honda?? my wife has ridden with me for over 20 years and now that i have an actual "dual sport" bike i am wondering if anyone else has tried this..
I took her for about an hour ride on some knarly forest roads that some riders won't go on - took it easy and all but she swears she'll never get on the thing again!
I've ridden on the back of my friend's, and I agree that the seat is pretty hard back there. I expect you'll need to do something about that if you expect a successful endeavor.
Let's ride!!!
- No offense, but there've been a lot of people over time who were just as sure, but got it wrong.
- Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad.
ONandOFF is offline   Reply With Quote
Old 01-20-2013, 09:15 PM   #52022
beechum1
beechum1's Avatar
Oddometer: 4,818
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
Originally Posted by flyingwombat View Post
What brake hose are you guys running with your CRF450 forks? The CRF450R hose that I have seems way too short.
ReRoute it if you need to. I've just taken mine up and over the top of errthang. I also use the XRL master. Works just fine. for me.
J
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
Old 01-20-2013, 09:17 PM   #52023
mendoteach
mendoteach's Avatar
Oddometer: 1,083
I picked mine up from Motostrano. It's a Galfer. They are a big supermo shop down the road from Steve. You need. Longer one as the stock 450 line is designed to simply cross the number plate.
mendoteach is offline   Reply With Quote
Old 01-20-2013, 09:18 PM   #52024
ONandOFF
ONandOFF's Avatar
Oddometer: 4,393
Originally Posted by mcma111 View Post
49'ers Baby
Super Bowl here we come
Ha! Saw that game and thought of you...
Let's ride!!!
Old 01-20-2013, 09:19 PM   #52025
beechum1
beechum1's Avatar
Oddometer: 4,818
CycleWizard: Motor's Ready.
beechum1:
Hone cylinder and whisker brush bore.
Cylinder head 5 angle valve seat work
Cut new faces on existing valves
New viton valve seals
New seals and gaskets o-rings bolts
New shifter shaft
New idler gear and bearing
New HRC hardweld cam #468 grind
New hardweld rockers
New CW clutch springs
New dowel pins
Under cut gears
NX 2nd gear
Head milling
Kicker install
Old 01-20-2013, 09:22 PM   #52026
mendoteach
mendoteach's Avatar
Oddometer: 1,083
I'm using an '08 CRF master cylinder. It has neat ball and socket mechanism for the lever piston interface rather than a small bolt and pin. It's like butta! That and a CRF stuff front oversize disc and it finally has enough brake.
Old 01-20-2013, 09:25 PM   #52027
mendoteach
mendoteach's Avatar
Oddometer: 1,083
Laugh
beechum1:
New shifter shaft
New dowel pins
Under cut gears
NX 2nd gear
Head milling
Kicker install
Better than when you ride it and it changes to poop. Mine will pull the wheel up at 50. And I'm putting on a bigger carb.
Old 01-20-2013, 09:27 PM   #52028
ONandOFF
ONandOFF's Avatar
Oddometer: 4,393
Originally Posted by ThumpnRed View Post
...Heck, a .243 was just about right. ...
A better way to phrase it would be a .243 is perfect :-)
Got my load dialed in and grouping quarters at 200yds.
: thumb
Let's ride!!!
Old 01-20-2013, 09:32 PM   #52029
ONandOFF
ONandOFF's Avatar
Oddometer: 4,393
beechum1:
New shifter shaft
New dowel pins
Under cut gears
NX 2nd gear
Head milling
Kicker install
Appropriate reaction, Jeremy! Anxious to hear how it works. : thumb
Let's ride!!!
Old 01-20-2013, 10:21 PM   #52030
Brown Falcon
Mossy-Back
Brown Falcon's Avatar
Oddometer: 717
: thumb
I still prefer my good ol' 30-06. Versatility at its best!
Evan
Ooh-Rah! Once a Marine, always a Marine!
'93 XR650L (Xena)
Brown Falcon is offline   Reply With Quote
Old 01-20-2013, 10:23 PM   #52031
beechum1
beechum1's Avatar
Oddometer: 4,818
I stilll have the JE 102 in there. I didn't go for the BTW motor. BUT... I can't friggin wait. I have a bunch of wiring and parts to buy and install before I can flog it to hell.
Old 01-20-2013, 10:24 PM   #52032
ShooterDave
Oddometer: 1,380
Originally Posted by fritzcoinc View Post
Could you crank out some .358 norma mags for me? 225gr boat tails please.
I will get right on it. Nosler or Barnes?
WTH are shooting at in Texas with a freakin .358 Mag?! That's a lot of kaboom for any Texas critters!
A .270 was as much gun as I ever used when I lived in San Antonio. Heck, a .243 was just about right. Several south Texas whitetails and hogs fell victim to a .243 inch "intervention"
: thumb
Wait a minute here. Are you cranking out ammo for people ThumpnRed? If so I might want to get in on this. My longest reaching at the moment is a .223, but hopefully soon I'll have something bigger.
My Lower 48+ ride on my XR650L - http://www.advrider.com/forums/showthread.php?t=565350
ShooterDave is offline   Reply With Quote
Old 01-21-2013, 12:15 AM   #52033
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,576
Fritz saw the press bolted to the bench in the picture and started wishful thinking
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 01-21-2013, 12:18 AM   #52034
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,576
I got one of them in the safe. It was my first big bang stick. I guess it's close to 40 years old now . My 22-250 is probably my favorite right now. That little sucker will flat f&^$ up a desert dog's day.
Old 01-21-2013, 12:20 AM   #52035
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,576
: thumb
Remington 700 in .243... tack driver.
Times are GMT -7.   It's 01:40 AM.
