01-21-2013, 04:19 AM
#7576 |
Oddometer: 51
Bring me your tired, worn and broken.
Hey KLX250s owners, I am in the need of a set of used plastics. You know...when you've just bought a shiney new set of aftermarket shrouds, fenders and side covers and the old ones go in the trash? Please let me recycle it by putting it on a new KLX that a friend just aquired and needs a beat up set for it's work duty (hauling materials for a trail building crew). Then the OEM new stuff goes back on when the bikes returns to street or play mode. Thanks!
01-21-2013, 08:09 AM
#7577 | |
Occasional Venturing
Oddometer: 659
01-21-2013, 09:29 AM
#7578 |
Bike-curious
Oddometer: 35
_____________________________________________ Motorcycles - Dooming relationships since 1885 |
01-21-2013, 10:05 AM
#7579 | |
Oddometer: 659
01-22-2013, 09:35 AM
#7580 |
Nobody's Robot
Oddometer: 1,327
If anyone is upgrading their KLX this winter, I've got a bunch of parts (IMS tank, suspension, wheels, rack, etc) in the flea market:
http://advrider.com/forums/showthread.php?t=856784 |
01-23-2013, 10:14 AM
#7581 |
Have ya got a helmut?
Oddometer: 149
Yes, chapter 2, Fuel System, 'Service Fuel Level Inspection' and 'Service Fuel Level Adjustment'. This is one of those things that, done yourself, you will be sure it's right. If you bring it somewhere and they tell you they did it right, you will really never know. I suspect this is the source of a lot of fueling issues on KLXs.
"You do your own thing in your own time, you should be proud." 2004 KTM 950 ADV 1998 Triumph Tiger 1999 KTM 640 ADV 2007 Kawasaki KLX350S 1996 Yamaha XT350 |
01-27-2013, 05:07 PM
#7582 |
Oddometer: 164
Axle pinch bolt part number?
I was looking over a family members newly acquired 07 klx (neat bike!) and ran into a minor snag that I'm hoping someone will be able to shed some light on...
One of the axle pinch bolts has been snapped off leaving only three nuts on the remaining three bolts. I unscrewed the snapped bolt out of the fork and checked out bike bandit for a replacement. Wrong!! Parts fiche just shows a part number for the axle pinch bolt nut, but not the bolt... Question: Any one have a part number (or a compatible bolt) for the bolt that the axle pinch nut threads onto? |
01-28-2013, 04:27 PM
#7583 | |
Oddometer: 2
01-28-2013, 08:01 PM
#7584 | |
Zip it
Oddometer: 152
Kawi klx250sf, Harley Iron 883, Isuzu Vehicross Owner |
01-28-2013, 08:10 PM
#7585 |
Zip it
Oddometer: 152
I prefer the "cover the exhaust hole" when cranking...thats after the shake method of course. The slow pull choke technique hasn't worked for me and the "empty the bowl" is too much of a PITA. Ive fired mine up in the low 20's.
01-29-2013, 07:38 AM
#7586 |
Oddometer: 659
^ But have you tried a vacuum on the exhaust?
01-29-2013, 01:33 PM
#7587 |
Oddometer: 475
I must be doing something wrong. I turn the gas on, pull out the choke, turn the key and it starts. Maybe living at 7700 feet helps. Dunno.
01-29-2013, 01:35 PM
#7588 |
Bits. Bytes. Bikes.
Oddometer: 72
This also works for me at ~200 feet.
2010 KLX250 2011 WeeStrom |
01-29-2013, 01:51 PM
#7589 |
Oddometer: 1,150
01-29-2013, 02:25 PM
#7590 |
Oddometer: 49
As long as it's above 30, it works for me at 600'. Below 30 she needs some coaxing.
Blissfully misdirected on an adventure with no known destination - NO! I am not lost, I'm exploring! |
