01-19-2013, 01:56 PM
#14161 | |
Oddometer: 795
Always chase your dreams. Even if you don't catch them, you'll have a hell of a time trying. Current: 1989 Honda Transalp, 2006 Scorpa TY125F trials Past: 1999 KLR 650, 1990 Tengai 650 |
01-19-2013, 02:00 PM
#14162 |
Oddometer: 54
http://www.topsellerie.co.uk - you can design it on their website right down to the piping
Two Brits traveling overland through Canada, USA, Mexico, Central and South America by motorcycle. ![]() http://heyivegotanidea.wordpress.com/ |
01-19-2013, 06:45 PM
#14163 |
Oddometer: 4
This is my very small present side panels lights..
http://imageshack.us/a/img534/982/pa310635.jpg http://imageshack.us/a/img99/181/pb010495.jpg With all lights on... http://imageshack.us/a/img339/5742/pb010496.jpg
01-19-2013, 06:50 PM
#14164 |
Oddometer: 4
01-20-2013, 08:18 AM
#14165 | |
Oddometer: 22
what watts/amps, how much and where from? thanks
http://i589.photobucket.com/albums/s...b110/all-1.png Dirty R30 CCM Filty 404 CCM Tatty Transalp |
01-20-2013, 10:19 AM
#14166 |
Oddometer: 4
They don´t say in the package... Just say 12V Super bright led.
I bought in a local store in Lisbon, for 20€ , and i have made the support´s by myself... |
01-20-2013, 11:38 AM
#14167 |
Oddometer: 22
some progress:
CR500 forks in with Transalp springs brake calipers rebuilt '82 CR250 shock in, with Transalp spring ground out a bit added 4.5" to stand ![]() GSXR pipe and DIY linkpipe and guard (bit cr@p) Husky 250 tail wide pegs ![]() seat butchered ![]() ![]() ![]() recovered ![]() DIY forkbrace ![]() next: headlamp fairing bashplate front fender etc etc
01-20-2013, 06:32 PM
#14168 |
Chasing after theory
Oddometer: 140
OK, got some more work done between the games today and a chance to grab some pics of a couple of items. Given that the bike is still in a bunch of pieces I will hit some high lights for now.
Before the pictures a quick story, when I pulled the crash bars off, I was not planning on painting them or having to do anything to them. Well, as I was moving some parts, I kicked them and notice something chipped off???? Chipped of metal? Well, I dug a little deeper and found out the PO had used BONDO to fill in where he had not welded! Yes, bondo instead of welding on crash bars. After looking at this some more, I figured out that he tacked it in place and never did anything to finish it off except to farkle it instead of finishing the job right. So, 20 minutes of sanding four sections, quick weld job and they were as they should have been.. I tell you, when going through a previously owned bike, you have to check everything and not take anything at face value. Now to the pictures. This is the rebuilt 83' XR250 shock and spring installled ![]() Here is an overview which shows the swing arm. The dark area has been covered in heavy duty bed liner to prevent the chipping I had to clean up. ![]() This is the XR450 rear fender grafted onto the TA's previously shortened fender. I was really impressed with how easy it was able to bolt up. I did use a solid layer of adhesive which has bonded like concrete. Otherwise I was able to use the main tail light bracket to blend and hold the sections together. ![]() 16T front sprocket: ![]() The Corbin seat with her new skin. The main seat section has a non slip material (including wet conditions): ![]() There has been some debate about tire fitment and whether or not a 150 will fit...nothing like jumping in and trying. It does fit and yes, it is a little crooked as I have not tightened anything down: ![]() Here is a side view with the inverted brake set up (that was so easy even a caveman can do it)! ![]() With the new suspension in and wheels on, she sits a good 5" higher then before...oh this is so nice now!
Life is the last thing you experience before you die...living is what you do every day to get you to that point... |
01-20-2013, 11:41 PM
#14169 |
Oddometer: 64
01-21-2013, 12:33 AM
#14170 |
Oddometer: 58
tire
01-21-2013, 07:35 AM
#14171 |
Oddometer: 489
Dr E, nice work, And +1 on not taking any previous work for granted. You must have a very understanding wife.
01-21-2013, 08:02 AM
#14172 |
It's a short cut, really
Oddometer: 4,269
YAY...piccies
Thanks for the photos, DrE.
Body filler on the crashbars That's a new one. Seems like it would be more trouble than just finishing the welds....How odd.Here's a few extra things I thought of as a reward for updating us "visual learners" ....You can extend the forward part of the rear fender (down at the swingarm) by using a flap to continue the fender down past the swingarm brace section. I used some heavy rubber from a computer mouse pad....you can get them cheap and in all kinds of colors or logos. ....There has been lots of discussion on the CS sprocket. Personally, I've decided to only use the official Honda part here. The 16T CS sprocket from the Honda Hawk will fit perfectly on the TA here. It is a bit more expensive than the JT product...but...as a bonus comes with a nice rubber "noise damper" bit molded to the outside that contacts the side links of the chain. But the real reason for using this is because we as a group have never scientifically determined the real reason for the sever output shaft spline wear that is seen on some TAs. My personal opinion is that this wear comes from running the chain tension set to "street bike" standards by inexperienced owners or even shop techs. But the real reason I use the Honda part is that I've not paid a lab to do "Rockwell" hardness testing on (a) the output shaft (b) the Honda CS sprocket and (c) the JT or other oftermarket sprockets that advertise that they are "hardened". So...while a "hardened" CS sprocket would sound - at face value - to be a good thing. It is decidedly NOT a good thing if the sprocket is harder than the output shaft. If it is....wear occurs on the shaft and not on the sprocket. Obviously it is much easier and less expensive to replace the CS sprocket than the output shaft. .......so......that's why the official HONDA part at this particular location. I happily use the JT stuff on my other bikes and at the rear wheel sprocket. One more tidbit, E. The CR shock reservoir MAY interfere with the standard TA coolant tank. If it does (it did when I used the AT shock and it does with my Ricor unit too) the coolant tank can be relocated almost anywhere. Small tanks can be found at auto wreckers in may different configurations. I'm still playing with the best one for the AT nose fairing. I figure that mounting it where the pilot can see it is a good idea. Right now my DR750 is more torn down than your TA...but I'm working on it . Well see who has a running machine first. .......Thanks for the photos....
01-21-2013, 08:36 AM
#14173 | ||||||
Oddometer: 140
Estoy corriendo el Shinko 705 como un experimento. Hay mucha discusión neumático en la pizarra y varios amigos los están utilizando aquí y me gustaron mucho. Así que veremos cómo estas dos. Quote:
01-21-2013, 09:19 AM
#14174 | |
Oddometer: 489
#14175 |
Oddometer: 4,269
E,
Not really a competition ![]() Just a comment meant more to keep me motivated to foray out into a chilly garage and keep working. Painting and ceramics, huh....You renaissance men are a bit scary ![]() Just finished service on the steering head and suspension link bearings. Thankfully Suzuki uses caged needles rather than the loose ones on the TA. No chasing tiny bits of metal across the floor. Today the suspension gets reassembled and some electrical connections get cleaned up. You're making good progress so long as you're not distracted by a lump of wet clay. |
