Old 01-21-2013, 08:40 AM   #6631
elsalvadorklr
southern xr rider
Oddometer: 4,154
here ya go
these brakes kick ass btw as the measure of a good brake is clean fluid and new seals...there are 4 seals, inner seals and outer double lip seals to protect against moisture...
lastly the pistons expand over time as they get dirty...so polishing them makes them smooth as BUTTA
cheers
elsalvadorklr is offline   Reply With Quote
Old 01-21-2013, 08:50 AM   #6632
Royal Club
Royal Club's Avatar
Oddometer: 392
http://www.ebay.com/itm/XR600-XR600r...ec5e92&vxp=mtr
saw this on ebay, he doesn't send to EU/Netherlands so maybe one of you guys would want it??
Royal Club is offline   Reply With Quote
Old 01-21-2013, 08:54 AM   #6633
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by creaky View Post
Yes, had Eddys on 2 stock 600s and an HRC 628, big performance improvement across the board. Unfortunately, Edelbrock no longer markets these carbs and does not provide parts and support. If you can find a new or good used one (Edelbrock # 3113) for a reasonable price, they do last quite a long time with proper maintenance.
found one!
http://www.ebay.com/itm/Edelbrocks-p...d38dc0&vxp=mtr
For anyone who wants it..
Old 01-21-2013, 09:26 AM   #6634
elsalvadorklr
southern xr rider
Oddometer: 4,154
hese from TT...good guy....
dont know if the actual muffler will work for oeam stainless headers for 88-90 bikes...those headers are aftermarket forget the name...
Old 01-21-2013, 09:28 AM   #6635
elsalvadorklr
southern xr rider
Oddometer: 4,154
found one!
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa h your killing me
I know of a lot of people, or read about a lot of people who had issues with these carbs on their xrs...I think they just never took the time to tune them
they theoretically are missing a circuit, which in my eyes makes tuning easier!
man
wonder what it goes for
STEVE buy it will ya?
Old 01-21-2013, 02:00 PM   #6636
The Dogger
Oddometer: 145
man
Here's one :
http://www.advrider.com/forums/showthread.php?t=855807
Easy to adapt to an XR or not ?
Cheers, Stu
The Dogger is offline   Reply With Quote
Old 01-21-2013, 02:37 PM   #6637
elsalvadorklr
southern xr rider
Oddometer: 4,154
looks a bit different to me...wonder what size the first one on ebay is?
3113 model vs this 38?
anywho
finally got my mikuni tm38 to start great, the choke even works...maaaaaaaaaaaaaaaaaaaaaaaaaaaan am I stoked
the drop of the pilot size worked, and the new xrl boot....so stoked
there is not even the slightest hint of kickback!
see guys there is a reason I wanted a non autodecomp cam...all in the "tuning" jajajajaja
Old 01-21-2013, 07:30 PM   #6638
elsalvadorklr
southern xr rider
Oddometer: 4,154
stupid skidplate torx head screws
so my moose skiplate has a stripped bolt...the actual head, I hate torx...
whats the best way to take it off, slot the head?
Im getting some noisy creaks now and then and wanted to put more foam between it and the engine...also I wanted to flush my frame strainer...
no can do till I get some advice!
anybody????????????
thanks
Old 01-21-2013, 07:43 PM   #6639
lamebrain
Oddometer: 38
anybody????????????
thanks
Reverse cut drill bit, it usually catches and backs it out. If you dont have access to one then I would use a drill bit that's just a bit bigger than the threaded part of the bolt and pop the head off.
lamebrain is offline   Reply With Quote
Old 01-21-2013, 07:44 PM   #6640
joexr
Oddometer: 3,773
Slot it , drill it or grind it.
Old 01-21-2013, 08:21 PM   #6641
elsalvadorklr
southern xr rider
Oddometer: 4,154
thanks guys Ill use a combination of methods I guess
Old 01-22-2013, 03:30 AM   #6642
creaky
creaky's Avatar
Oddometer: 186
Dogger......the carb shown in that link is an older model with no pump. I had one of those that I used on three different bikes, a stock 95 XR00, a '98 HRC 628 and later adapted it to an '00 WR400. In each case, it was a definite improvement in performance over the stock carb. That said, the pumper version is an improvement.
'98 BMW F650
'96 XR400
'98 Moto Guzzi V11
"Once you go over the hill, you start picking up speed!"
creaky is offline   Reply With Quote
Old 01-22-2013, 09:00 AM   #6643
elsalvadorklr
southern xr rider
Oddometer: 4,154
man Im on a roll guys!!!!!!!
fixed the skidplate and took off the stripped bolt...
and added foam insulation on the front under the vent holes and under the case towards the back, that and I added more rubber strips on all the frame rails so now there is no metal to metal contact and it worked!
no creaking from the frame twisting on the skidplate! HELL YEAH!!!!!!!!!!!!
next on the list fix my floppy shifter!
soooo per many a recomendation here and on tt I put y shifter in a homemade vice and whipped out the old saw...made a nice long cut, as it took a while on the gap cleaned up the splines a bit and put teflon on the spindle...
then pressed the gap nice and tight, put on spindle, loctite the threads and bingo, bolt screws in nice and tight aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaand
no more floppy lever! bam! stoked
I was having issues going into first because if the floppiness...I also bent the shifter out just a smidge
anywhoo
Ill be riding in the afternoon...hopefully I can take some pics...
thanks for all the tips guys
christian
Old 01-22-2013, 09:05 AM   #6644
mcma111
mcma111's Avatar
Oddometer: 12,386
Christian,
You know we are still waiting for the pic of the Mrs in her bikini.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-22-2013, 10:26 AM   #6645
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by mcma111 View Post
Christian,
PREGNANT????????????????????????????????
MAN
you guys play hard I see
jajajajajajaja
Times are GMT -7.   It's 02:54 PM.
