01-21-2013, 08:36 AM
#6631 | |
Oddometer: 3,974
the pistons are hollow made of a special plastic, they have metal caps that are removable...thats the part that contacts the brake pads...you can take them off, clean them so they are nice and flat and then glue them back on which is what I did.... to clean the pistons you can buff them with some polishing compound, but I would NOT do that unless you want to replace the seals inside the caliper. cheers |
01-21-2013, 08:40 AM
#6632 |
Oddometer: 3,974
here ya go
![]() these brakes kick ass btw as the measure of a good brake is clean fluid and new seals...there are 4 seals, inner seals and outer double lip seals to protect against moisture... lastly the pistons expand over time as they get dirty...so polishing them makes them smooth as BUTTA cheers |
01-21-2013, 08:50 AM
#6633 |
Oddometer: 314
http://www.ebay.com/itm/XR600-XR600r...ec5e92&vxp=mtr
saw this on ebay, he doesn't send to EU/Netherlands so maybe one of you guys would want it?? |
01-21-2013, 08:54 AM
#6634 | |
Oddometer: 314
found one! http://www.ebay.com/itm/Edelbrocks-p...d38dc0&vxp=mtr For anyone who wants it.. |
01-21-2013, 09:26 AM
#6635 | |
Oddometer: 3,974
dont know if the actual muffler will work for oeam stainless headers for 88-90 bikes...those headers are aftermarket forget the name... |
01-21-2013, 09:28 AM
#6636 | |
Oddometer: 3,974
I know of a lot of people, or read about a lot of people who had issues with these carbs on their xrs...I think they just never took the time to tune them they theoretically are missing a circuit, which in my eyes makes tuning easier! man wonder what it goes for STEVE buy it will ya? |
01-21-2013, 02:00 PM
#6637 | |
Oddometer: 88
http://www.advrider.com/forums/showthread.php?t=855807 Easy to adapt to an XR or not ? Cheers, Stu |
01-21-2013, 02:37 PM
#6638 |
Oddometer: 3,974
looks a bit different to me...wonder what size the first one on ebay is?
3113 model vs this 38? anywho finally got my mikuni tm38 to start great, the choke even works...maaaaaaaaaaaaaaaaaaaaaaaaaaaan am I stoked the drop of the pilot size worked, and the new xrl boot....so stoked ![]() there is not even the slightest hint of kickback! see guys there is a reason I wanted a non autodecomp cam...all in the "tuning" jajajajaja |
01-21-2013, 07:30 PM
#6639 |
Oddometer: 3,974
stupid skidplate torx head screws
so my moose skiplate has a stripped bolt...the actual head, I hate torx...
whats the best way to take it off, slot the head? Im getting some noisy creaks now and then and wanted to put more foam between it and the engine...also I wanted to flush my frame strainer... no can do till I get some advice! anybody???????????? thanks |
01-21-2013, 07:43 PM
#6640 | |
Oddometer: 38
01-21-2013, 07:44 PM
#6641 |
Oddometer: 1,059
Slot it , drill it or grind it.
01-21-2013, 08:21 PM
#6642 |
Oddometer: 3,974
thanks guys Ill use a combination of methods I guess
01-22-2013, 03:30 AM
#6643 |
Oddometer: 172
Dogger......the carb shown in that link is an older model with no pump. I had one of those that I used on three different bikes, a stock 95 XR00, a '98 HRC 628 and later adapted it to an '00 WR400. In each case, it was a definite improvement in performance over the stock carb. That said, the pumper version is an improvement.
'98 BMW F650 '92 Honda 750 Nighthawk '85 Honda VF500F Interceptor '96 XR400 "Once you go over the hill, you start picking up speed!" |
01-22-2013, 09:00 AM
#6644 |
Oddometer: 3,974
man Im on a roll guys!!!!!!!
fixed the skidplate and took off the stripped bolt... and added foam insulation on the front under the vent holes and under the case towards the back, that and I added more rubber strips on all the frame rails so now there is no metal to metal contact and it worked! no creaking from the frame twisting on the skidplate! HELL YEAH!!!!!!!!!!!! next on the list fix my floppy shifter! soooo per many a recomendation here and on tt I put y shifter in a homemade vice and whipped out the old saw...made a nice long cut, as it took a while on the gap cleaned up the splines a bit and put teflon on the spindle... then pressed the gap nice and tight, put on spindle, loctite the threads and bingo, bolt screws in nice and tight aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaand no more floppy lever! bam! stoked I was having issues going into first because if the floppiness...I also bent the shifter out just a smidge anywhoo Ill be riding in the afternoon...hopefully I can take some pics... thanks for all the tips guys ![]() christian |
01-22-2013, 09:05 AM
#6645 |
Oddometer: 8,152
Christian,
You know we are still waiting for the pic of the Mrs in her bikini.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
