01-21-2013, 02:53 PM
#17641 | |
Oddometer: 32
http://i65.photobucket.com/albums/h2...psc818d0dd.jpg I just noticed the link in your sig - your rebuild thread in October is part of what helped me decide to get a DRZ and rebuild it (as oppose to just getting a brand new bike). If you hadn't started your thread I probably wouldn't know jack about those pins. Funny how that works. bonekrusher screwed with this post 01-21-2013 at 03:01 PM |
01-21-2013, 03:01 PM
#17642 | |
patty cake champion
Oddometer: 3,511
So, I put them in the holes, they just sit in there? No springs or anything? Theres no magnetic pull from the engine or the other piece...
Unregistered destructive device. focallength screwed with this post 01-21-2013 at 03:07 PM |
01-21-2013, 03:03 PM
#17643 |
Oddometer: 32
I can't believe yours just fell out - I was holding my engine sideways and shaking it to get them out before I was told
by someone to use a magnet, then they came right out. Anyways - hope all goes well with the rest of your build. Edit: I think there are springs - when you put them in and depress them they should pop up a little less than a quarter inch to keep tension against the cap. bonekrusher screwed with this post 01-21-2013 at 03:10 PM |
01-21-2013, 03:09 PM
#17644 | |
patty cake champion
Oddometer: 3,511
Thanks, just ordering parts now, almost have everything, just need intake cam, head, left radiator, right radiator sensor, primary gear for the clutch, clutch plates and im going to throw on a fmf power bomb header...thats it.
Unregistered destructive device. |
01-21-2013, 03:12 PM
#17645 | |
Oddometer: 32
I'll be home in like an hour and a half and then I can take pics of all parts and the order they go in. I just checked every microfiche I can find on the DRZ and nothing shows those contacts/springs/cover or mentions neutral indicator at all. Damn. As mentioned I'll put up what I can when I get home. bonekrusher screwed with this post 01-21-2013 at 03:26 PM |
01-21-2013, 04:25 PM
#17646 |
Oddometer: 32
Ok, so I was wrong about them having any magnetic anything holding them in place - guess mine were just stuck
![]() However they are spring loaded. http://i65.photobucket.com/albums/h2...psd0d07dc9.jpg Will post spring dimensions shortly - have a question about which microfiche shows these on TT, hopefully someone responds. Ok - they are about a half inch long (uncompressed) 11.5mm and just under 3/8ths in. (4.5mm) wide. Wish I could be more help... bonekrusher screwed with this post 01-21-2013 at 04:34 PM |
01-21-2013, 04:37 PM
#17647 | |
patty cake champion
Oddometer: 3,511
01-21-2013, 04:38 PM
#17648 | |
Oddometer: 794
Sounds like a timing chain stretched to me... I wouldn't worry about the head until the valves are needing reshimmed every oil change.
Crazy_Dave just made it into my sigline, and I agree: I fall down alot. |
01-21-2013, 06:38 PM
#17649 |
Oddometer: 26
Coolant Reservoir
Anyone know where I can find a coolant overflow tank for my 2001 DRZ? I hear turkey basters work, any tips on that will get me by till I find the real thing would also be helpful.
Cheers!! BKWags |
01-21-2013, 06:44 PM
#17650 | |
Oddometer: 2,123
Sent from my Nexus 7 using Tapatalk 2
Alex Cape Coral, Fl. 2003 KLX400R tagged
01-21-2013, 06:50 PM
#17651 | |
Oddometer: 2,123
I've had my can chain loosen up a couple times over the years.... Once with a acct and a couple times since the mcct and new chain. It has never sounded like that. When my valves got tight tight many years ago it sounded exactly like that. I also had the starting problems that he mentions. Bike would run fine when warm but cold I would kill my battery at times trying to get it started. Edit: oh and... The two main weak parts of a DRZ in my eyes are the valves and the oiling system. I don't take chances with either. I use the best oil possible and of a valve gets tight I rebuild the head. I'll only shim it once on the initial rebuild, check them at 3,000 miles and never look back. I also make sure to run very clean air filters at all times to help make sure I don't have to rebuild a head again. Its worked so far. Sent from my Nexus 7 using Tapatalk 2
01-21-2013, 07:32 PM
#17652 | |
patty cake champion
Oddometer: 3,511
Got pics?
01-21-2013, 07:35 PM
#17653 |
ride2discover
Oddometer: 3,205
![]() I took the DRZ on a ride on Sunday. It was mostly washes & various terrains. Here's one of my vids. http://youtu.be/eSQRXwD_AVY
DR-Z400E 00 - DR650SE 02. Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY". DR650SEDDY screwed with this post 01-21-2013 at 08:57 PM |
01-22-2013, 04:38 AM
#17654 |
Oddometer: 438
Seat concepts which one?
I want to get a Seat Concepts seat for my DRZ 400E, but am not sure whether to get the standard height seat, or the low seat and whether to specify standard or hard foam. I have short legs, 30" inseam and weigh about 220lbs. I want to use the bike for desert trips in Oz. I have a few questions:
Is the standard height seat more comfy than the low seat? I am thinking either standard height standard foam or lower with hard foam might be the go; anyone any experience or thoughts about this? Can I specify gripper for the sides as well? Is this a good idea? Cheers, Adrian
01-22-2013, 05:37 AM
#17655 | |
Oddometer: 896
A few months ago I purchased a 2004 for $2000 8600 miles, pretty much stock except bars and case savers.
I ride not to add days to my life, but to add life to my days. Those who say it cannot be done should not interrupt the people who are doing it." "Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY." |
