Old 12-07-2012, 09:23 AM   #586
3Rrr
Read Ride Reflect recycle
3Rrr's Avatar
Oddometer: 170
Accel 152440 Stator
Anyone use the Accel 152440 Stator?
My stator is going out and I need a replacement, but was told that Electrosport would be getting there's mid-Jan.
Kyle twitter.com/ducumph
3Rrr = Read, Ride and Reflect
09 BMW F800GS
11Husqvarna TE 449
3Rrr is offline   Reply With Quote
Old 01-21-2013, 06:19 PM   #587
goldentaco
goldentaco's Avatar
Oddometer: 162
I don't have an F800 GS but for some reason I read through all 40 pages here as it was quite interesting.
Still have one question. The Series regulator talked about earlier like the Compufire is listed as ouputting 30% of the total current the OEM stator would when demand is low. I'm not sure if I misread one of the posts but wayyyy back in the pages I thought it was mentioned the series regulator will provide less power most of the time but when you need the full capacity of the stator, it will allow it to provide that.
Then later there was quite a few posts weighing the benefits or probability whether each rider could "deal" with the reduced power output of the series regulator or whether they would need more power for heated gear and gadgets.
Question is does the series regulator only always output a reduced current from the stator and thus "derating" the stator output ALLL the time? OR does it provide up to the 400 watts if needed but if not needed ramps stator output down to say 100 watts for the majority of the running time?
Reasons I'm curious the F650 Funduros are notorious for eating their VRR's ( regulator rectifiers) and my current one from an F650 GS while better, is on it's way out. Testing the stator output I noticed quite a noticeable jump in RPM's when the stator leads to the VRR are disconnected for testing. If the Series regulator like the Compufire could do similar on my application it may be worth considering...but only if at some point I'd have access to all 280w of my charging system's power.
Incidentally, I just ordered an FH020AA for my little beast. They do quite well on the Funduros and I like a safe bet.
J
1997 F650 Funduro White
Where am I SPOT
goldentaco is offline   Reply With Quote
Old 01-21-2013, 06:40 PM   #588
ebrabaek
Oddometer: 4,745
J
The difference between the two, is merely that the shunt type cooks the stator at max all the time, and the series sort of just supplies what is needed of the system. So you might think why not just use the series. That question is hard to answer. As the series unit operates all ok....all is well, but when they fail they might drag other stuff with it.... Without going into too much confusion, I will say that it could send bad filtered ( large noise....ac ripples) perhaps over volted power to the system, where as the shunt type tends to just short itself to ground, and not damaging anything else in the process. It has been a while since I have studied the series r/r circuitry, and perhaps much has changed, but I have no doubt that the sure bet is the shunt, but are cautiously optimistic that after some beta testing long term results will prove me wrong. Only reason I would jump to a series, is if it helps the stator to run cooler. In the case of the 8gs, that it does, and that is needed, as it cooks the stators after several thousand miles. I hope I have not confused you more, but that is my two cents.....
Erling
Old 01-21-2013, 06:54 PM   #589
goldentaco
goldentaco's Avatar
Oddometer: 162
Originally Posted by ebrabaek View Post
... and the series sort of just supplies what is needed of the system.
"...so you're saying there's a chance"
I get the differences, and the failures of each are definitely of concern. I don't have computers on the bike but I'm sure there are a few things that could go after a failure.
But if there was a load total <= to the rated capacity of the stator would the Series regulator provide that? Or is it always putting out less than your stator running flat out could provide?
J
Where am I SPOT
Old 01-21-2013, 07:00 PM   #590
WayneC1
Oddometer: 2,521
The lower output referred to earlier in the thread is a reference only to the stated maximum ratings of the particular model of VR and the possibility of overloading it on the F800. Overall a good series VR will provide more of the stator output to the machine than a shunt VR
In general terms the series VR open circuits the stator in the process of regulating and a shunt VR short circuits the stator to ground hence the shunt regulator applies a constant load to the stator and this increases stator temperature
The other benefit of a series VR is the lower engine load it creates and so a very small increase in usable engine power can result. BMW are using slightly different techniques on the cars to reduce fuel consumption and increase engine response by "disconnecting" the alternator output under constant throttle and acceleration. They have called it "regenerative charging" which is only slightly misleading
WayneC1 is offline   Reply With Quote
Old 01-21-2013, 07:00 PM   #591
steveWFL
steveWFL's Avatar
Oddometer: 1,344
Just as I consider adding an 800 to my garage I see threads like this
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Old 01-21-2013, 07:06 PM   #592
ebrabaek
Oddometer: 4,745
J
Yes. The series type will just supply what the system is demanding. If for example you run a 200 watt system, it will draw and supply that. The remanding capacity will simply just not be generated..... thus the stator running cooler. It will do this up to its 400 watt capacity. It is the potential failure I would be worried about. Be interesting to talk with people who have run them for long periods of time.... perhaps even seen a failure...
Erling
Old 01-21-2013, 07:07 PM   #593
ebrabaek
Oddometer: 4,745
It is a 125$ fix..... Come on board.....
Erling
Old 01-21-2013, 07:10 PM   #594
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
+1 I know a guy with a great deal on one....
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 01-21-2013, 07:24 PM   #595
ebrabaek
Oddometer: 4,745
Erling
Old 01-21-2013, 07:37 PM   #596
bross
Where we riding to?
bross's Avatar
Oddometer: 4,551
I installed a Compufire on my Honda CBF1000 after the stator fried. It's a known problem with the CBFs, with some riders on the forum on their 3rd stator. Mine went at 24,000km and that's when I installed the Compufire, rode the bike another 16,000km and two years before selling it so I can't say for sure if the Compufire "fixed" the problem on the CBF or not. From my research and a few of us with CBFs who have tried them, they seemed to work and I had more confidence in the Compufire than running another stock unit that I knew would fry at some point.
bross is online now   Reply With Quote
Old 01-21-2013, 07:47 PM   #597
Motorfiets
Motorfiets's Avatar
Oddometer: 2,997
Good to know... I have a compufire in my 800 currently
Ben
My Photo's
Old 01-21-2013, 07:50 PM   #598
goldentaco
goldentaco's Avatar
Oddometer: 162
Well that would be cool if I could somehow prevent the possible Event Horizon that may occur during a failure. Add a filter or something.
My last VR failed in a way most of our OEM's didn't...one diode shorted hard to the VRR chassis. The other diodes would short in a thermal runaway scenario. Acted like battery was dead. Once cooled, it would behave for a while until the next failure ( about 30 mins).
J
Where am I SPOT
Old 01-21-2013, 08:00 PM   #599
goldentaco
goldentaco's Avatar
Oddometer: 162
I'm most interested in it from an engine load point of view. With the possible freeing up of a pony or two or more like better fuel mileage it is enticing. Obviously other bikes have used it and with Harley's looking like they should literally shake themselves to a pile of bolts, the Compufire is targeted to that market. A failure would likely leave an imprint on the net I would guess.
Wayne, you're familiar with the F650's...would this be worth considering? Or is a perfectly well running bike that most definitely not erupt in flames a better option?
J
I know it's not that simple and sorry for steering this thread off the mark but I figure at 40 pages a page or two of nonsense won't hurt.
Where am I SPOT
Old 01-21-2013, 08:13 PM   #600
ebrabaek
Oddometer: 4,745
Indeed that is great to hear...... Thanks.
Erling
Times are GMT -7.   It's 11:59 AM.
