Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 01-22-2013, 01:37 PM   #8551
Miguel Sanchez
Whatever...
Miguel Sanchez's Avatar
Oddometer: 1,137
Originally Posted by oldmonkeybut View Post
Got Gas?
Got Spark?
Got Compression?
Exhaust not plugged?
Timing Right?
Still won't run?.........Those things have a habit of breaking the Rotary Valve. I had a KE175 in my shop that drove me nuts. That was the problem.
If the Planets are all lined up. Moon in proper phase. Relative Humidity in check. Relative Humility in check. You may still be fucked if the Whizzenator fails to circumnavigate the Motengable within the predescribed Longitudinal Orbit with respect to Bergundian Pitch and Yaw of course. According to the Visagothian Rule of Engagement make positive that you have not disrupted the Contact Flange Grommet. You must also acertain that your Phaleolithic Carbon Extract has not become Tainted
Be Brave, Go Forth
Hmmm, posted 2 minutes apart... Do great minds really think alike, or izzit just genetic?
- Miguel
01 GS1150, 02 WR426F, 04 XR650L, 04 315R, 04 CRF230F, 81 R100RT (S), 56 G80CS, 87 MT11, 71 TS185, 74 98SR, 74 99RT, 76 TL250, 70 MX125, 80 DR400, 80 RS175, 80 RS250, 78 XR75, 74 RD350, 70 CT70, 06 Monster 620 Dark, and about a dozen more I can't think of right now...
Miguel Sanchez is offline   Reply With Quote
Old 01-22-2013, 04:13 PM   #8552
peterman
cop magnet
peterman's Avatar
Oddometer: 13,642
no kicking,,key on,,
,,,then start out with the bike at the verrry top of a reeeeally long hill,,,it's all downhill from there!OR,,you could drag it around behind a cage,,but, if the reed is busted, you'll need another clarinet,,
peterman
___________________________
"Your God, your rules,,YOU go burn in hell!" LLV
peterman is offline   Reply With Quote
Old 01-22-2013, 04:26 PM   #8553
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,706
Originally Posted by Miguel Sanchez View Post
....or izzit just genetic?
Probably......
. .......... do I hear banjo music?
West - "Oeste Sanchez"
RideAbout is offline   Reply With Quote
Old 01-22-2013, 04:43 PM   #8554
pHelix
Eternal n00b
pHelix's Avatar
Oddometer: 1,242
Originally Posted by RideAbout View Post
Probably......
Kevin
just beneath the surface of the mud, there's more mud here... Surprise.
'07 R1200GS, '03 DR-Z400
pHelix is offline   Reply With Quote
Old 01-22-2013, 05:39 PM   #8555
Superpacman13
Superpacman13's Avatar
Oddometer: 252
Jeebus, it won't rev up and now will only idle for about a minute. It gets boggy from 1/2 throttle up and puts the smoke cloud down. I have new points, new coil, new ignition(key), the exhaust is not plugged, I have put the needle in every position possible, tried every increment on the fuel screw. The rotary valve looks ok, but that doesn't mean anything because I don't know what its supposed to look like. Since its none of those, it must be that the schewgner valve being installed in the counter-clockwise plane.
KTM's:14' 150XC 08' 450SX-F 06' 560SMR,'77 RD 400, 73' G3SS-C
Superpacman13 is offline   Reply With Quote
Old 01-22-2013, 06:03 PM   #8556
oldmonkeybut
Digital Emigrant
oldmonkeybut's Avatar
Oddometer: 2,585
Probably......
It may be Genetic or it may even be Generic or possibly even Geriatric but I didn't want to confuse the issue. I know Superpac is a nice guy and all young and tender. He hasn't reached the advanced level of depravity that some of us operate at. I hate working on Kawasaki's, they are so complicated. If you want to get all technical there is a possibility that in the process of fiddling he may have gotten the Transgender Labia Diffuser out of Sync which would among other things cause a disruption in the Androgenous Metamorphic Classification. As you know the only way to tell if this happened is to hook it to a Hermaphroditic Defibrillation Scope which are extreemely hard to read unless you are flatulent in at least three languages. There is a translation module available however it is rarely cost effective. Some people have been known to just Man up and reach down into the problem but you run the risk of ending up with much more of a handful than you were expecting. That is the Horror that I was trying to save Superpac from. Such a thing could scar him for life. All this time you were thinking "It's just a little bike. Pour gas in turn on switch kick over...Suck, Squeeze, Bang, Blow...and away you go". It's much deeper than that. Banjo's just make it hard to concentrate.
Sand in the Vaseline
oldmonkeybut is offline   Reply With Quote
Old 01-22-2013, 06:09 PM   #8557
oldmonkeybut
Digital Emigrant
Oddometer: 2,585
Have you pressurized the Crankcase to make sure you don't have a failed Crank Seal ? It doesn't take much Gear Oil to make a hell of a cloud and you will never Jet that problem away.
Old 01-22-2013, 06:29 PM   #8558
Superpacman13
Oddometer: 252
I didn't even think about it. That gives me an experiment to do tomorrow.
Old 01-22-2013, 08:41 PM   #8559
Road Rash
Infamous
Road Rash's Avatar
Oddometer: 18,679
Hmmm, posted 2 minutes apart... izzit just genetic?
Probably......
Yep.............I hear it too
Izzat you peterMAN?
"A man can never have too many motorcycles, like any good craftsman you need the proper tool for the job at hand. A man needs more tools than a hammer, the same goes for bikes." ~Mr. Cob~
My Ride Through Roatan
Road Rash is offline   Reply With Quote
Old 01-22-2013, 08:43 PM   #8560
*REGO*
Commited Adventurer
*REGO*'s Avatar
Oddometer: 96
Where is it to be?
Gentlemen, Is there a consensus where we will meet tomorrow?
"obstacles are those frightful things you see when you take your eyes off your goal."- Henry Ford
*REGO* is offline   Reply With Quote
Old 01-22-2013, 09:02 PM   #8561
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,706
Linda and I are in Anacortes dealing with a dying Momma.... won't be in town. Have fun.
Old 01-22-2013, 09:12 PM   #8562
Miguel Sanchez
Whatever...
Oddometer: 1,137
So sorry to hear that dude... Thatsa shitty part of life, I got one down and one to go. If yer back in town by Saturday night, I'll buy ya a beer to cry in.
- Miguel
Old 01-22-2013, 09:12 PM   #8563
peterman
cop magnet
peterman's Avatar
Oddometer: 13,642
[QUOTE=Road Rash;20553663]Yep.............I hear it too
"I saw , my eyes burned, my mind reels at the remembrance of the horrid event,,the laughing Santa Claus bent over the helpless undersized 2 stroke,it's tiny airway penetrated time and again,or was it more than 2 strokes?,,poor, poor Santa,,,
And,,, all he brought us was the KTM-MAN,,,no rudolph, no elves,,just a big KTM wind up toy!
black and orange Man!,,hat, shoes, socks, belt, hubcaps, black truck with orange wheels,with ktm hubcaps,,,
ktm shirt, ktm pants, ktm cup holder, ktm sunglasses,(in the frikken dark), and just guess what he wants to rave about?!
I have never laughed so much in my entire life as that night,,I swear before noon!
2 really high highpoints in my ADV life,,
Best heart feeling/life boost = Raindog's Bash
Best goofy laugh until yer sick = Wibby's birthday at John's Peak
I can tell ya stories that will crack you up laffing, but only around a campfire,,we are not safe here.
peterman
Old 01-22-2013, 09:15 PM   #8564
Miguel Sanchez
Whatever...
Oddometer: 1,137
Hey! That there was a consensual encounter, plus it was in the hills outside Grass Pants, so it was prolly even normal!!
- Miguel
Old 01-22-2013, 09:29 PM   #8565
Miguel Sanchez
Whatever...
Oddometer: 1,137
Crank seal(s) like my genetic/geriatric/gentle/genital/genial/gelatin cousin said. Do a leak down test. Also, check the inner rotary valve cover seal - this separates the slick stiff from the combustible stuff. Pull the carb, then pull the cover the carb hooks to - it ought to have a good gasket seal all around it to keep oil out and air/fuel in.
If you took the rotary valve apart, it is possible to put the plate back in upside down and backwards on some of the Cow-a-socky models. Never worked on an 80, though.
Sounds a lot like an induction problem to me. Either it's sucking gear oil in a big way or the rotary valve doo-hicky ain't valving like ought to be.
I assume you have good compression and didn't bust a (the?) ring?
All else fails, get a Hodaka!
- Miguel
Times are GMT -7.   It's 05:12 AM.
