Old 01-22-2013, 08:04 PM   #8461
DominoTree
EX250 Warrior
DominoTree's Avatar
Oddometer: 95
Originally Posted by operaflute View Post
Quite happy with my Wolfman Enduro. Fits nicely, don't have to remove to fill up, small but not unusable.
Unrelated: all the webpage buttons on this site ("reply" "quote" "login" etc.) have disappear a couple days ago (when using Firefox). Using IE to reply. Harrumph.
Same here, but in Chrome. If you click to the bottom of a post, on the right side, you'll get "reply with quote" so you can just delete the quote :P
"At each stop, fill up the oil, and make sure to check the gas."
2006 Yamaha XT225
Gone but not forgotten:
1990 Kawasaki ZX6D, 1990 Honda VFR750F, 2008 Kawasaki EX250J, 2005 BMW F650GS (Single)
DominoTree is offline   Reply With Quote
Old 01-22-2013, 08:38 PM   #8462
Dirt2Street
Oddometer: 53
Originally Posted by DominoTree View Post
Well, I bit the bullet and did it. Not too loud at all! I haven't taken it around the block, but it seems like it started much more easily and has better throttle response when I rev it.
What size jetting did you go with?
"Live for nothing or die for something...your choice." -Sylvester Stallone
Dirt2Street is offline   Reply With Quote
Old 01-22-2013, 08:51 PM   #8463
DominoTree
EX250 Warrior
DominoTree's Avatar
Oddometer: 95
I haven't actually opened up the carb but it's working wonderfully. It is a used bike, so it's possible the PO had done something. I was having issues with it stalling and being difficult to start that seem to be alleviated now. I'm gonna dig into the carb in a couple days and I'll post what I find.
2006 Yamaha XT225
Old 01-23-2013, 01:23 AM   #8464
Crazy Canadian
All who wander r not lost
Crazy Canadian's Avatar
Oddometer: 2,028
I've wondered about anyone doing this... Found this on the facebook XT225 site.
https://sphotos-a.xx.fbcdn.net/hphot...74655397_n.jpg
I've learned to give "impossible" the finger as I pass it by.
The only way to get through life is to laugh your way through it!
Day by day, nothing seems to change. But pretty soon, everything is different.
Crazy Canadian is offline   Reply With Quote
Old 01-23-2013, 08:03 AM   #8465
operaflute
Starving Artist
operaflute's Avatar
Oddometer: 139
Right. The buttons are "there," but invisible. So it'll work if you know where said invisible buttons are hiding! Weird!
Clicky for Ride Reports (and other things): Eating On Two Wheels
operaflute is offline   Reply With Quote
Old 01-23-2013, 10:15 AM   #8466
DominoTree
EX250 Warrior
DominoTree's Avatar
Oddometer: 95
Apparently the overseas XT225s had rear discs for most of their run.
I guess just get on eBay and look for a rear wheel with rotor, swingarm, master cylinder and calipers.
Other people have converted a KLX wheel to work but it was a HUGE endeavor.
2006 Yamaha XT225
Old 01-23-2013, 12:00 PM   #8467
Crazy Canadian
Oddometer: 2,028
I am headed to Japan on buisness in March. Gonna see if i can bring the parts home with me.
Old 01-23-2013, 12:56 PM   #8468
DominoTree
EX250 Warrior
DominoTree's Avatar
Oddometer: 95
Looks like it's an issue with certain ad blockers. Disabled mine and it works fine again!
2006 Yamaha XT225
Old 01-23-2013, 10:31 PM   #8469
Crazy Canadian
Oddometer: 2,028
For those looking...
http://cgi.ebay.com/ebaymotors/Yamah...#ht_500wt_1182
Old 01-23-2013, 11:43 PM   #8470
JerryH
Oddometer: 5,069
My XT is built out of 3 different XT225s, and a lot of aftermarket parts. One of the pipes had the "Z1" mod done by the PO. I could not tell any HP increase over stock, but liked the sound. It ran lean, so I went up one size on both the main and pilot jets, and turned the pilot screw out 2 1/2 turns. Now runs perfect and plugs look good. I have a Keintech pilot screw.
As far as a tank bag, I have the Tusk tank panniers from rockymountainatv.com, and they work great. Under $20, and VERY well made. I can easily get four 1 qt. Gatorade bottles in them, which can be used to carry liquid, or you can cut the tops off them and use them to carry tools that might otherwise poke through the bag. They have an extra pocket on the outside that works perfect for a bicycle water bottle. The yoke has a hole in it that fits over the gas filler, you just remove the cap, put the panniers on, and put the cap back, so they cannot come off.
K&N filters are garbage. They will stop gravel, bugs, and maybe really coarse sand, but certainly not dust. I use stock filters kept soaked in oil. Nothing has ever got through them. I have had my oil checked a couple of times, and even on a 30,000 mile engine, it came back good. My airbox is completely stock, with the snorkel still in place. HP is not my main concern, it has plenty stock, though I did spend a fortune on suspension.
JerryH is offline   Reply With Quote
Old 01-24-2013, 06:44 AM   #8471
greasespot
Oddometer: 43
Hey, Jerry H:
Do those tank panniers flap around?
greasespot is offline   Reply With Quote
Old 01-24-2013, 09:34 AM   #8472
JerryH
Oddometer: 5,069
Originally Posted by greasespot View Post
Hey, Jerry H:
They do if they are empty, but they have Velcro tape to hold them to the tank. They don't move at all if they have much weight in them. I usually carry around 5 pounds on each side, and they don't budge. I never put the Velcro on my Clarke tank.
Old 01-24-2013, 09:56 AM   #8473
operaflute
Starving Artist
operaflute's Avatar
Oddometer: 139
Sure enough! Thanks.
Old 01-24-2013, 10:07 AM   #8474
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,226
I have the same Tusk ATV tank bags. They are ok for the money. With the stock tank they aren't secured very well since the gas cap isn't as large as an ATV gas cap, or probably the Clarke's gas cap. I didn't use the little velcro strips either, because I didn't want to stick them onto the tank. I tried off-roading on some steep, rough terrain and the bags cam off the gas cap & slipped forward onto the steering column a number of times.
I have had better results, especially when they're empty, placing the tank bags across the seat and sitting on top of it. But that doesn't work very well either off-road because you need to stand up quite a bit.
They aren't the best bags around, but they are well worth the $20. I find that they are handy and add a good bit of capacity along with my other "cheap bags", the Mountain Smith large "dog bags" that are about $38-$40. I highly recommend the dog bags for the price.
http://www.firedancersglass.com/ PM me for "ADV discount"
GlennR is offline   Reply With Quote
Old 01-27-2013, 10:59 AM   #8475
Dirt2Street
Oddometer: 53
Awesome! I've been wanting to mess around with the air box to get the noise difference but I don't want to mess with the carb at all so hearing that gives me a little hope!
Times are GMT -7.   It's 01:46 AM.
