01-22-2013, 07:58 AM
#91 |
Oddometer: 7,986
I put some grease on the collar and place it in the pump.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
01-22-2013, 08:01 AM
#92 |
Oddometer: 1,626
^^^What Steve said.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F |
01-22-2013, 08:03 AM
#93 |
Oddometer: 7,986
Have you seen my engine build? Although it's a XR650l the engines are basically the same. Cylinder and head torque's are different.
http://www.advrider.com/forums/showthread.php?t=713831
01-22-2013, 08:24 AM
#94 |
Oddometer: 196
I spent yesterday doing the other attachment arms between the pannier racks and the bike frame. You can see them in this picture...
Within the last few days I have also applied the Honda decals to the tank and put on a few coats of protective clear coat. So the tank is basically done. ![]() I have also been working out the pannier-to-rack attachment system. I will be using lockable draw latches, McMaster Carr part number 1406A57. The goal is for them to be super easy to use, easy on and off, and lockable to the bike.
Current Bikes: 1986 Honda XL600R, 1988 Hondasuki KLNX250R, 1988 BMW R100GS (dead) Previous Bikes: Honda XL250 (2 of them), Honda XL600R, Kawasaki KLR600, BMW K1100LT, BMW R60/6, BMW K75, Husqvarna 430XC Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com |
01-22-2013, 08:25 AM
#95 |
Oddometer: 196
Thanks Steve... No I have not read your thread... but will do so today.
01-22-2013, 11:31 AM
#96 |
Oddometer: 167
I put it in the pump assembly and carefully put the cover on. I have cocked that sleeve too in the past juggling around the kickstarter and oil tube and whatever else is in the way. Might try gluing it into place with grease for assembly.
01-22-2013, 01:16 PM
#97 |
Oddometer: 638
Looking good so far. Word of advise on the Wiesco piston. I put one in my stock engine with stock exhaust and it pinged like crazy, even with race gas. Ran much better with the supertrapp so once that motor is together don't try using a stock muffler.
01-22-2013, 07:50 PM
#98 |
Oddometer: 196
Thanks Carter. How many discs in your Supertrapp?
01-22-2013, 07:58 PM
#99 |
Oddometer: 638
I run it with an open end cap. It's loud but the muffler hasn't been repacked yet. I'm doing a few upgrades to the bike in spring and I'll repack the muffler then. I'll post up a sound clip for everyone.
01-22-2013, 08:00 PM
#100 |
Oddometer: 196
Making a new oil-tube, AKA dowel.
Turning it from a piece of 1" aluminum on my new little South Bend lathe. ![]() Here is the new tube next to the old one. 10mm OD x 8mm ID x 7mm long ![]() I also made new locator dowels for the cylinder head, as those were mysteriously absent. Made those from stainless. No pictures.
#101 |
Oddometer: 196
Like... no end on it at all?
01-22-2013, 08:18 PM
#102 |
Oddometer: 196
A few nights ago I worked out the basics of the design for the pannier attachment system. Here is the current state of the drawing:
![]() This is the view from the back, or wheel side, of the right-side case. The orange outer lines are the Pelican case itself. The black is the rack, which lives on the bike. And the green is the various parts that will bolt to the case and "clip," or attach, to the rack. I will have to make adjustments to the placement of the latches to accommodate the exhaust, but I will wait until I have the latches and cases in hand to fine tune that stuff. I already ordered two Pelican 1500 cases in silver. I might paint them... not sure. I have photoshop experiments with different paint jobs, but I think there are enough photoshop images of different colored Pelican cases in this thread already!
01-23-2013, 05:13 AM
#103 |
Oddometer: 167
01-23-2013, 06:24 AM
#104 |
Oddometer: 638
One of these guys
![]() As I stated it makes some noise, but I live in Harley country so it's tame in comparison. I still do hope the re pack tones it down quite a bit. After I put this thing on I don't run out the gears as frequently as I used to in an effort of good social manners. |
01-24-2013, 09:48 AM
#105 |
Oddometer: 196
Sorry for calling you Dave, Steve. No one likes that sort of thing. My apologies.
