Old 11-20-2012, 03:47 PM   #76
isdt BMW
willserv@aol.com
Oddometer: 145
muffler
My 57 R-50 ISDT has a single R-51 muffler and works fine. only 250cc firing at any time. My R-75 ISDT has a 1-1/2" pipe into and out of the muffler, same deal, 375cc per cylinder. The 2 into 1 y pipe is a full foot forward of the muffler. BSA and Triumph twins used a single standard muffler with 2 into1 exhausts.
isdt BMW is offline   Reply With Quote
Old 11-21-2012, 07:54 AM   #77
tdrrally
tdrrally's Avatar
Oddometer: 2,851
any pix of that r50?
it might inspire some one
2002 DRZ250 what it lacks in horse power it makes up for with traction for sale
2000 DRZ400e tagged
1980 TS125 project in the corner
200? zuma 50/70 the wifes bike
tdrrally is online now   Reply With Quote
Old 11-21-2012, 11:13 AM   #78
isdt BMW
willserv@aol.com
Oddometer: 145
R-50 isdt
There are pics here and also if you google R50-ISDT, it will show up. I do not have smugmug or any other hosting site, I will have to get one to post my R75-ISDT photos, I'm not computer savvy enough to do it myself, I'll have to ask my kids for help.
Old 11-22-2012, 10:00 AM   #79
limeymike
Who Me?
Oddometer: 484
The flatter position is the more practical, the angled position is for looks only. I prefer the flatter because I want a bike to work for what it is intended and don't care about looks all that much. I wouldn't want to work around an upswept exhaust with luggage as you won't see the exhaust anyway.
limeymike is offline   Reply With Quote
Old 11-23-2012, 03:21 AM   #80
isdt BMW
willserv@aol.com
Oddometer: 145
The high pipe bikes are for dirt/enduro/play, for touring I use a conversion /2 R90 with Hollendia sidecar rig, or R69US with Craven bags or my 78 R100S motorsport with Krauser bags. Everyone needs a BMW for each purpose.
Old 11-30-2012, 05:06 PM   #81
DiabloADV OP
Semi-Occasional
Oddometer: 1,534
I decided to save a little time (and gain some quality) so I bought these from BR Moto, who makes them for Wolfman. I have the Wolfman bags already.
Ready to weld!
'74/'70 R98/6/GS Traveling Bike (construction under way)
'91 Bill Holland Steel w/Dura Ace
DiabloADV is offline   Reply With Quote
Old 12-01-2012, 04:57 PM   #82
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 15,971
Dude, that's a neat bike.
Have you tossed your "calipers" yet. "+\- 0.1mm accuracy" (sic) is 8-thousanths of an inch. That's a mile. They're no good for measuring much of anything.
Recently bought a digital vernier for knocking around the garage (ie: I'd never take it to work) and it's accurate to within 0.0005" (1\2 a thou). I paid $15 for it. No kidding.
Keep posting pictures. You've got a really neat bike there.
Old 12-01-2012, 05:48 PM   #83
DiabloADV OP
Semi-Occasional
Oddometer: 1,534
I'm out of the business of making tiny accurate measurements! There are machine shops for that...
I've got the subframe almost finished. 90% of the time spent on this project so far has been staring at it and sipping Jack on the rocks. Pics coming...
Old 12-03-2012, 09:42 PM   #84
DiabloADV OP
Semi-Occasional
Oddometer: 1,534
Main subframe done. Took me a while to figure out a way to mount (1) muffler hanger; (2) side racks; (3) fender hanger; and (4) top rack to the subframe, and add a little extra support to the flat rear part. Solution is those side plates. Those are 1/8 plate welded to the 12 gauge tubing. The plates will be finished with holes drilled for mounting the other parts.
I got a lic plate/tail light bracket from chris at boxermetal that works perfectly.
DiabloADV screwed with this post 12-03-2012 at 09:54 PM
Old 12-31-2012, 05:47 AM   #85
hardwaregrrl
Shit for brains
hardwaregrrl's Avatar
Oddometer: 4,849
Uhmmm....Hello?!!!
Old 12-31-2012, 09:24 PM   #86
DiabloADV OP
Semi-Occasional
Oddometer: 1,534
Originally Posted by hardwaregrrl View Post
Uhmmm....Hello?!!!
The holidays got me off track! Actually -- I spent a lot of time fiddling with various ways to set up the exhaust. Current header sidepipes block the use of a centerstand. I'd need to weld longer centerstand mounts, ala the later bikes. But, since I want to do a crossover and have a single exhaust, I'd need to do that anyway...
So, I'm next going to make the exhaust merge/crossover and get my muffler can mounted. Then fab and weld new centerstand mounts.
Wheels hubs are being sent back to me from the vaporblast guy, then off to get built into wheels. If I like how the vaporblasting turned out, I'll send up the gearbox and motor cases.
Old 01-08-2013, 06:35 PM   #87
DiabloADV OP
Semi-Occasional
Oddometer: 1,534
Got hubs back from vapor blasting. I decided to have the R90 hub converted to standard sealed bearings by Woody's. No more fiddling with spacers and wedding rings and torque wrenches.
These get mailed out to Woody tomorrow, for mounting as 17x2.5 rear and 19x2.5 front, sealed for tubeless.
Also made a decision to make an under-frame crossover pre-muffler, to then allow for a minimalist single can on the left side. The mandrel-bent tube I need to do that should be here this week and I can commence that experiment.
Old 01-22-2013, 09:10 PM   #88
DiabloADV OP
Semi-Occasional
Oddometer: 1,534
Remember when you were a kid and it was easier to work on your bike if you turned it over?
Ready to start the exhaust mods and make new center stand mounts.
Old 01-23-2013, 05:18 AM   #89
Beater
Scope Creep's Victim
Beater's Avatar
Oddometer: 2,191
Yes ... and I must admit, this has NEVER occured to me.
Fred
'85 R80RT G/Sified
'91 R100GS Bumblebee
Airhead Zen: Ride-Maintain-Repair-Ride On.
Beater is offline   Reply With Quote
Old 01-23-2013, 05:34 AM   #90
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 19,847
It occured to me once, when i broke the shift pawl spring, and I thought "well, I can think of ONE way to shift gears" that was it, though.
What to do... What to do...
Stagehand is online now   Reply With Quote
Times are GMT -7.   It's 05:24 AM.
