Old 01-20-2013, 01:06 PM   #61
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,720
Looks like we lost the OP 4 pages ago. I wonder if he took them beads off by now and either try riding without balancing or balanced with weights.
Have tools, will travel!
Old 01-20-2013, 01:12 PM   #62
ttpete
Oddometer: 6,039
When I balance a wheel/tire assembly with weights, I KNOW it's in balance and can prove it.
When someone pours plastic beads in a tire, they HOPE it's in balance, but can't prove it.
Go to a pro race sometime and see if any of the factory tire busters use beads. They don't.
ttpete screwed with this post 01-20-2013 at 01:24 PM
Old 01-20-2013, 02:15 PM   #63
brad1098
/\ dumb
Oddometer: 845
Ok.
Since I'm on the side of it didn't work for me. How do I get the beads out of the tube to keep from buying new ones?
brad1098 is offline   Reply With Quote
Old 01-20-2013, 07:50 PM   #64
Bob Tosi
Bob Tosi's Avatar
Oddometer: 1,607
Well ill jump in here for the heck of it. I run dynabeads on my Tiger. Used them in a set of kenda big blocks, 150/70-17, 110/80-19. I installed the recommended amount. I never had any vibrations of any kind even at speeds of 100mph. The set of big blocks went 5000 miles and am changing them now. Even wear patterns on both tires. All that with tubeless tires.
When you're lost in the wild and scared as a child. And death looks you bang in the eye, and your sore as a boil, its according to Hoyle to cock your revolver... and die. But the code of a man says "fight all you can" and self-dissolution is barred. In hunger and woe, its easy to blow... Its the hell-served-for-breakfast thats hard........Robert Service
Bob Tosi is offline   Reply With Quote
Old 01-22-2013, 08:04 AM   #65
kantuckid
Oddometer: 3,104
I used to race cars & can readily attest that "they" were not a collection of all the genius's in the world!
I've run the beads for a few years & have been getting normal wear & smooth riding. I reuse them, they're easy to install & not so complicated from there to say , why not? As to removing them from a tube w/o a knife, you've got me there...
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Old 01-22-2013, 08:50 AM   #66
ttpete
Oddometer: 6,039
Race car tires and wheels need to be dynamically balanced because of their width, and you can't use a simple static balance stand.
Might as well cut the tube open because new tires deserve new tubes anyway.
Old 01-22-2013, 09:01 AM   #67
bwalsh
bwalsh's Avatar
Oddometer: 12,141
I've got two sets of tubes for my bike. The original tubes, 2004 bike, and a HD set I bought for spares. No problems in 40,000 miles...
I'm still running the original tubes in my Mtn. bike. It's a 1992 model.
Tubes don't disintegrate after one or two uses but if you feel they do I'll gladly send you my snail mail address and you can recycle them.
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 01-23-2013, 06:47 AM   #68
kantuckid
Oddometer: 3,104
Dyna beads are stated to not work by the seller for wide/low profile tires. Many car tires these days are in that category. I remember them saying they don't disperse across the width properly for good balancing.
Old 01-23-2013, 07:43 AM   #69
ttpete
Oddometer: 6,039
I was speaking towards balancing with weights, not beads.
I can balance a motorcycle wheel in 10 minutes using weights and see no need to screw around with plastic pellets that would take longer and make a mess the next time I had to break it down.
Old 01-24-2013, 05:55 AM   #70
kantuckid
Oddometer: 3,104
I really enjoy bead threads. They are ceramic, if "Dyna Beads" the air gun pellets are the plastic. As to making a mess, that's hardly the case as these pellets are very tiny-similar in size to maybe #12 shot like's in a .22 birdshot shell-definitely smaller than #9 shot,as an e.g.. I find it easy to recycle them. If I drop a few , no big deal & if your shop is like mine a stray ceramic bead thats around 1/32" in diameter won't cause much problem. I do dislike hunting for those stray bearing balls that escape from MC steering heads!
I reweigh what I catch(I dump them on a plastic scrap when changing tires) & use over. Takes little effort to lay there on a creeper & tap the clear plastic tube as they roll into the stem. My tires are smooth for the life of the tire, no matter the wear pattern.
Old 07-07-2013, 06:23 AM   #71
wayno
wayno's Avatar
Oddometer: 6,812
How about the trucker that said they use Golf Balls in the steering on their tires?????
RIDE SAFE
wayno is offline   Reply With Quote
Old 07-07-2013, 08:53 AM   #72
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Old 07-07-2013, 10:54 AM   #73
showkey
Oddometer: 1,974
I heard that mining trucks use bowling balls for balance..........
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 07-07-2013, 11:11 AM   #74
_cy_
Oddometer: 6,374
Originally Posted by tututis View Post
Hi, I've mount a Conti Trail Attack in my 12GS and I've balanced them with Dyna Beads. I put 2 Oz in the rear tyre and 2 Oz in the front tyre becuse a I read this on the web http://www.innovativebalancing.com/c...otorcycleChart
From 0 - 130Km/h I don't have problems but from 130Km/h to I have high speed vibrations like a palpitating movement.
Why ? Anyone knows the answer ?
interesting???
Motorcycles
Motorcycle applications are easy for all bikes, 2 wheel or 3 wheel
Front
80 - 120 mm tire width
1 oz
80 - 120 mm tire width (BMW Telelever only)
2 oz
130 mm tire width
2 oz
Rear
130 mm - 240 mm width
2 oz
250 mm - 360mm tire width
3 oz
195 - 205 car tires on the rear
3 oz
M Series Tires Sizes
MH – use 80 mm width
MR– use 120 mm width
MJ– use 90 mm width
MT– use 130 mm width
MM– use 100 mm width
MU– use 140 mm width
MN or MP– use 110 mm width
MV– use 150 mm width
These codes are typical for Harleys but can be for any tire. The codes do not go beyond 150mm in width. With these tires, the first number of the tire size is not the actual width, it is just a number. The M-code is what tells you the actual width.
Scooters
10" diameter wheels (scooters)
1 oz
12" & Up diameter wheels (scooters)
2 oz
Dual Purpose / Off Road with Rim Locks
Front - 80 - 120 mm tire width
2 oz
Rear - 130 -230 mm width
3 oz
Rim Locks - add one ounce over what you normaly use for that size tire to accomodate the additional weight of the rim lock. Two rim locks opposite each other don't require any more Dyna Beads other than stated above, as they have a tendency to cancel each other out.
Note: Filtered valve cores do not fit all stems. They require a seat 1-1/4" down in the stem. If you cannot use them, simply rotate the tire so the valve stem is about the 6:00 position, then give the valve stem a quick shot of air prior to checking pressure.
_cy_ is online now   Reply With Quote
Old 02-07-2014, 05:02 AM   #75
elnonio
shedding n00bness
Oddometer: 238
Originally Posted by kurtaxline View Post
I used them in my 2009 Harley Street Glide and got a real bad vibration around 60MPH and up.
I hate how I'm about to sound like another snob, but frankly, when I read this, I can't help but imagine the endless possibilities that make a Harley vibrate badly, and the tire balance is not high on that list.
I could tell you stories, but they're not dynabead related.
Antonio
elnonio is offline   Reply With Quote
Times are GMT -7.   It's 08:59 PM.
