Old 01-20-2013, 11:17 PM   #1
Pistolero OP
W. F. O.
Pistolero's Avatar
Oddometer: 709
Cam chain replacement question.
Any tips on getting this little bastard out? I'm doing my cam chains am I'm stuck here. I can't get it out.
Pistolero is offline   Reply With Quote
Old 01-21-2013, 05:31 AM   #2
Blackbert
Factory Rambler
Blackbert's Avatar
Oddometer: 1,058
Don't know what you allready tried, but basically it's an allen bolt, RH thread. I don't know the size of the allenkey from the top of my head. IIRC, the frametube is not blocking access.
Honestly, have you ever heard of somebody looking back on his life thinking: "Oh, I should have travelled less and mowed the lawn more often"? (Pumpy)
want to save on Smugmug? use this code (VoUO8M1ukmnMY)
Blackbert is offline   Reply With Quote
Old 01-21-2013, 07:39 AM   #3
Pistolero OP
W. F. O.
Pistolero's Avatar
Oddometer: 709
Well I got the bolt out. That's the needle bearing that supports the gear that the timing chain rides on
Old 01-21-2013, 02:25 PM   #4
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,585
Have you removed the tensioners yet?
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 01-21-2013, 04:12 PM   #5
Katoom72
Katoom72's Avatar
Oddometer: 900
Thanks to my good memory i knew i commented on the same problem before.
Behold the solution. (i hope ) Post #5 and onwards.
Katoom72 is online now   Reply With Quote
Old 01-21-2013, 04:54 PM   #6
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,585
a flat blade screw driver that fits into the bore, then torqued out of alignment to grab the part, then pulling out will also work, provided the chain has zero tension on it.
Old 01-21-2013, 07:38 PM   #7
Pistolero OP
W. F. O.
Pistolero's Avatar
Oddometer: 709
yep the chain is loose. I'll have to wait a few days to get back in there due to school and work
Old 01-21-2013, 07:40 PM   #8
Pistolero OP
W. F. O.
Pistolero's Avatar
Oddometer: 709
I tried that but I was a little nervous haha
Old 01-21-2013, 08:30 PM   #9
Pistolero OP
W. F. O.
Pistolero's Avatar
Oddometer: 709
Thank you for your help .. Where would I go about finding one of those contraptions? Google search time. I actually tried that with a bit of hose but i could not get it to stick well enough.
Old 01-22-2013, 02:25 AM   #10
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,319
Even cheaper...
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is offline   Reply With Quote
Old 01-23-2013, 03:32 PM   #11
Katoom72
Katoom72's Avatar
Oddometer: 900
Any store that sells DIY stuff. Don't know how the DIY stores in the US are called. The above method is frankly the same. Even a tube, like u mentioned, should work if it's the inside right diameter so it can expand enough to put pressure and grip.
And no thx, just a beer and some adventure stories wil do.
Times are GMT -7.   It's 07:23 PM.
