Old 10-09-2012, 09:29 AM   #181
BillyD
BillyD's Avatar
Oddometer: 635
Rather Switch than Fight...?
With the sporadic performance of the stock 990 fuel pump and filters, I’ve often wondered why people do not upgrade the whole set up.
In addition to being over priced, the stock filters get plugged up very easily thanks to their exceedingly small surface area. This, in turn, causes the Keihin pump to cavitate (especially at tank lower fuel levels), which at very least causes fuel starvation above 5,000 RPM under load. If left uncheck, the pump will over-heat and fail. Not a good situation.
By comparison, I have changed the fuel filter once in 20 years and never had any problem with the pump on my 1991 Ducati 851. It too operates at 50 PSIG and has injector orifices just as small those on the 990. The stock 851 uses an automotive spec in-tank fuel pump about the size of a can of Red Bull and an in-line filter about the size of an 8 oz coffee cup. Turns out the filter is the same as used on a 1986 Mustang. There is no filter on the inlet.
If I were to convert the 990 back to injection, I would replace the in-tank pump and filter with a Safari blank off plate, put an in-line pump like the Edelbrock #3594 (~US$200) in the 950 pump location and figure out somewhere to mount a much larger fuel filter and regulator between the pump and injectors. Since I don’t have ABS, I would probably mount both under the seat for easy access. Per the Ducati, I wouldn’t use a filter on the pump inlet.
At 50 PSIG, the Edelbrock #3594 flows more than enough fuel. It is also about the size of a small Redbull can, so I’m pretty sure it would fit in the stock 950 location.
What am I missing here???
US$120 for two crappy filters and an o-ring on a system that seems prone to failure, especially when fuel is less than pristine, just doesn’t make sense on a true “Adventure” bike.
Bill
KTM '08 690 RFR, '08 990Adv S (carbs), '07 640Adv, '03 540EXC, Ducati 851, Moto Guzzi 850 Lemans, Ercole & 2VT and Yamaha RD350.
BillyD screwed with this post 10-09-2012 at 11:43 AM
BillyD is offline   Reply With Quote
Old 10-09-2012, 10:34 AM   #182
fast4d
Oddometer: 2,436
looks like your typical walbro pump.
is that a 'returnless' type pump?
they also make intank pumps with more or less the same capacity. I'm sure you can make it work if it fits and have the correct capacity (not too much or little)
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is offline   Reply With Quote
Old 10-09-2012, 11:08 AM   #183
BillyD
BillyD's Avatar
Oddometer: 635
Good question... I don't know.
If it is a "returnless" type pump, I would put the regulator in-line with and downstream of the filter.
If it is NOT a "returnless" type pump, I would instead tee-in the regulator downstream of the filter with a return back from the regulator to a fitting on the Safari blank-off plate.
For grins, I would probably put gauges on: one between the pump and filter and one downstream of the filter just before the supply line split to the injectors.
Bill
Old 01-22-2013, 02:32 PM   #184
l0st
Oddometer: 20
double post
l0st screwed with this post 01-23-2013 at 11:50 AM
l0st is offline   Reply With Quote
Old 01-22-2013, 02:39 PM   #185
l0st
Oddometer: 20
Just got my 990 ADV 2007 home and got one question for you guys. When I turn the key to ON position, I hear a very ugly noise and I'm pretty sure that the fuel pump is making it. Seller left the gas tank completely dry, so I thought this may be the problem. So I put in gasoline to top and let the bike run for 10min, but the ugly buzzing from pump is still the same. I changed my CBR600RR 06 for this 990 and I'm used to clean bzzzz instead of bzshchszshzzshc, or is that normal? You can hear the buzzing on video below, volume up
http://www.youtube.com/watch?v=zBF5IaHQpX8
Thanks.
Old 01-22-2013, 02:43 PM   #186
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
Thanks.
the sounds is a little muffled but yes it seems normal
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 01-22-2013, 03:16 PM   #187
EZ300
EZ300's Avatar
Oddometer: 1,112
Thanks.
Sounds normal to me.
,.... oh and I have never had a fuel pump issue. (31,363 miles on a 2007 KTM 990) (Waterpump seal failed around 27,000 miles)
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 01-23-2013, 11:49 AM   #188
l0st
Oddometer: 20
Thankyou both for your opinion. On video it doesn't sound so bad, also the bike is running OK, but it's very weird sound to me, so I will check the fuel pump anyway :)
Old 01-23-2013, 02:19 PM   #189
tunp
tunp's Avatar
Oddometer: 288
Yes,
11 ADV spring of 12 w/ 4600 miles pump went bad, not delivering enough pressure to keep bike running.
Replaced under warrenty.
Ridin w/ a smile
Tony A
02 FLHT, 11 990 adv,13 TE449,
tunp is offline   Reply With Quote
Old 01-23-2013, 03:34 PM   #190
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 524
08 990 adv 15,000 miles and no problems with the fuel pump.
Hey,
Lots of dirt riding. My stock air filter was packed with dust. I haven't looked at the fuel filter yet. Just did my valve check, all in spec, and have the tanks off.
Question: Would turning the tanks upside down and dumping the fuel clean up the tanks? Flushing with fresh gas too. If there is junk from whatever wouldn't that take out the offending grunge and give a longer life to the pump filters? Just wondering as I haven't heard that mentioned. KJ
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe screwed with this post 01-24-2013 at 09:59 AM Reason: clarification
knobbyjoe is offline   Reply With Quote
Old 01-30-2013, 03:37 AM   #191
Ale_Ray
Oddometer: 6
2012 990 Adventure
Yes?
I've just clicked 4k km and have all the symptoms. Feels a bit sluggish and generally not great. Cuts out heaps while hot.
Called the guys at KTM in Perth. Didn't have much to say 'cept bring it in.
Will pull the tank and check the filters this weekend....
Ale_Ray is offline   Reply With Quote
Old 01-30-2013, 08:02 AM   #192
wreckah
Oddometer: 63
09 990 SMT.
60.000kms - no problems.
gonna change out the filter set (paperfilter, + bag + seals) inside the tank now though, i think it hasn't been done yet. 90 EUR for the set...auch.
'09 990 SM-T
'09 690 enduro R
wreckah is offline   Reply With Quote
Old 01-30-2013, 08:24 AM   #193
catalina38
Contrarian
Oddometer: 1,645
3 years and no issues. Replaced fuel filters as part of my routine maintenance. I carry a spare filter set on the bike and could easily change them on the road if required.
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 01-30-2013, 09:09 AM   #194
ElRod
4<2
ElRod's Avatar
Oddometer: 293
No. 11K. '08 ADV
ElRod is offline   Reply With Quote
Old 02-03-2013, 12:33 PM   #195
vonotto
vonotto's Avatar
Oddometer: 250
990 2011 10K miles; No problems with fuel pump
"It flicked me pretty high and I landed back on the bike so hard I thought I'd swallowed my own nuts!"
vonotto is offline   Reply With Quote
Times are GMT -7.   It's 11:31 AM.
