Old 01-23-2013, 05:32 AM   #1
Angryrican OP
know nothing all
Angryrican's Avatar
Oddometer: 268
Need width of F800GS with BMW Adventure Panniers mounted
Any of you guys that have these on you back can you please measure the total width?
I need to know how it compares to the the Touratech 31/38 Zega Pro option since I'm considering bumping up the size to 38/45 for trips two up.
And yes I searched an no results came up.
Angryrican screwed with this post 01-23-2013 at 05:33 AM Reason: Can't spell
Angryrican is offline   Reply With Quote
Old 01-23-2013, 07:56 AM   #2
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,665
This article says 109 cm (Zega is about 107).
If there is any chance you understand german:
http://www.motorradonline.de/gepaeck...423735?seite=3
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is online now   Reply With Quote
Old 01-23-2013, 08:33 AM   #3
puckinet
Safety third
puckinet's Avatar
Oddometer: 346
All the specs are in the sticky above
http://www.advrider.com/forums/showthread.php?t=413424
Our famous last words "It doesn't look too bad".
08 KTM 450 EXCR
2010 BMW F800GS
Rick
puckinet is offline   Reply With Quote
Old 01-23-2013, 08:33 AM   #4
Angryrican OP
know nothing all
Angryrican's Avatar
Oddometer: 268
it helps a lot, Zega Pro is 40.75" which are 103.5cm, going with the 38L/45L set up adds 3.1" giving it a total of 43.85" or 111.4cm, roughly an inch more the the BMW set up. Let's see how big my bikes butt will end up!
Old 01-23-2013, 08:36 AM   #5
Angryrican OP
know nothing all
Angryrican's Avatar
Oddometer: 268
Big help! thanks!!
Old 01-23-2013, 09:59 AM   #6
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,665
Are you able to fit a helmet in the Zegas? In the BMW you can =)
Old 01-23-2013, 10:08 AM   #7
Angryrican OP
know nothing all
Angryrican's Avatar
Oddometer: 268
I could only fit my size medium Shoei Hornet inside the BMW topcase, I'm also adding a new R1200GS down the road so I want to be able to use the cases themselves on both bikes. the BMW side cases look the same but mount differently so they are not cross compatible between both bikes besides the new R1200GS has the exhaust on the opposite side now so it will most likely be a completely new setup.
Old 01-23-2013, 10:29 AM   #8
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,665
you can also fit a helmet in the right case, the one that is 44l.
But sure thing if you get the new 12GS than you should take the Zegas. If you get an old one than you can order the Holan kit for the 800GS so that you can use the 12GSA aluminium boxes on the 800GS - so no more problems with the old 1200GS and fitting the cases.
Old 01-23-2013, 12:43 PM   #9
cchoc
Outdoor Photographer
cchoc's Avatar
Oddometer: 203
Mine is right at 42" wide with the BMW aluminum panniers.
Charlie...
Stalking Light
'13 F800GS Kalamata Metallic
cchoc is offline   Reply With Quote
Old 01-23-2013, 02:37 PM   #10
Angryrican OP
know nothing all
Angryrican's Avatar
Oddometer: 268
I couldn't fit my Shoei in it
Thanks!!
Old 01-23-2013, 05:17 PM   #11
Kaw4Life
Busted Adventurer
Kaw4Life's Avatar
Oddometer: 6,546
Get Jesse's unless you like all your stuff to turn black.
... for every mile of road, there are two miles of ditch. - MZcountryboy
... which part you focus on is up to you.
Kaw4Life is online now   Reply With Quote
Times are GMT -7.   It's 04:30 PM.
