Old 01-16-2013, 07:40 PM   #3466
tslewisz
tslewisz's Avatar
Oddometer: 2,382
Did some preventative maintenance.
Mighta scorched the bench...it'll buff out!
tslewisz is offline   Reply With Quote
Old 01-16-2013, 07:54 PM   #3467
Pcfly
Dude?! Seriously??
Pcfly's Avatar
Oddometer: 1,135
That's not preventative.......it's a MUST DO!!!!!!
2011 Husqvarna TE-630 The Red Raptor
2012 Yamaha 50th Anniversary Badass-Sounding R1
2008 BMW 1200GS The Blue Rhino (SOLD)
Pcfly is offline   Reply With Quote
Old 01-18-2013, 03:32 PM   #3468
Goat_locker
Oddometer: 122
My Husky TE630 is for sale...
It's in the Flea Market forum. 2011. 698 miles on it. Practically new. Check it out.
2006 Triumph Scrambler, 1971 Triumph T120RV Scrambler, 2007 BMW R1200GSA Scrambler , 1976 Honda XL350
Goat_locker is offline   Reply With Quote
Old 01-18-2013, 04:23 PM   #3469
Blaise W
Blaise W's Avatar
Oddometer: 680
Tslewisz, wash your new aluminum with white vinegar, spray it with self etching black primer, then top coat with semi-gloss black. It will look factory!
Blaise W screwed with this post 01-18-2013 at 07:29 PM
Blaise W is offline   Reply With Quote
Old 01-18-2013, 07:12 PM   #3470
tslewisz
tslewisz's Avatar
Oddometer: 2,382
Originally Posted by blaisew View Post
Tslewisz, wash your new aluminum with white veniger, spray it with self etching black primer, then top coat with semi-gloss black. It will look factory!
Thanks for the tip.
Old 01-20-2013, 03:02 PM   #3471
tslewisz
tslewisz's Avatar
Oddometer: 2,382
When I was putting the subframe back on today, I noticed that I couldn't get the crankcase vent to reach its home in the airbox. I needed a hose several inches longer. WTF? I couldn't see where routing would make any difference...I don't think it was EVER in its home. Anybody else see this? Maybe I'm just an idiot.
tslewisz screwed with this post 01-21-2013 at 06:04 AM
Old 01-20-2013, 03:31 PM   #3472
Blaise W
Blaise W's Avatar
Oddometer: 680
I never disconnected my airbox from the hose; just pulled it forward and tied it off so the hose had a nice smooth curve. Unless you cleaned the airbox you should be able to tell from the outside if the hose was connected. If not look inside. You should be able to see residue around the connector. Routing should be dead simple so 'can't help there.
Old 01-20-2013, 06:57 PM   #3473
tslewisz
tslewisz's Avatar
Oddometer: 2,382
Routing should be dead simple...
Yeah, that's the thing. (sigh) It's right now, at least.
Old 01-22-2013, 03:35 PM   #3474
jtemple
jtemple's Avatar
Oddometer: 574
Mine did that when I tore it apart to replace the clutch spring cups and cam chain. I just figured the rubber shriveled up because I had it torn apart for so long.
jtemple is offline   Reply With Quote
Old 01-22-2013, 04:35 PM   #3475
Blaise W
Blaise W's Avatar
Oddometer: 680
You nailed it. Some plastics/rubber compounds are bad about shrinking as they age. Next time mine is off I will see about using a different kind of hose.
Old 01-23-2013, 05:16 AM   #3476
jtemple
jtemple's Avatar
Oddometer: 574
You can probably use some kind of heater hose.
Old 01-23-2013, 04:39 PM   #3477
tslewisz
tslewisz's Avatar
Oddometer: 2,382
That's what I used. The OEM hose had a spring in it to prevent collapsing in the turn to the front so I transferred that over, too.
Old 01-23-2013, 05:34 PM   #3478
sTE610vE
sTE610vE's Avatar
Oddometer: 2,068
A pic from a great ride on a warm January Day in Kansas....it's almost Dual Sport heaven
TRAIL STAND (advrider thread)- Dual Sport Portable Jack Stand www.endurostar.com
Husqvarna TE630
Cagiva Gran Canyon
sTE610vE is offline   Reply With Quote
Old 01-23-2013, 05:44 PM   #3479
codys
Lost in the Vizcaino
codys's Avatar
Oddometer: 1,261
It was pushing near 60 here today.
Abandoned rail through the valley. Hope no UP/BN people are looking at this thread.
05 ktm 950 adventure
11 Husqvarna TE630
codys is offline   Reply With Quote
Old 01-23-2013, 08:09 PM   #3480
DYNOBOB
lucky dog
DYNOBOB's Avatar
Oddometer: 1,111
You guys are killin' me, didn't even hit 20 here today. Stayed in Salida a couple yrs ago, must be awesome to live there.
Finished my Safari install last week.
TE630.KLX250S.GL1800.CBR900RRturbo.919
HoW (ForeverWest) 2014 CO/UT 2013
Northern Rockies 2013 IBA Key West 2014 Tentspace
DYNOBOB is offline   Reply With Quote
Times are GMT -7.   It's 01:30 PM.
