Old 01-23-2013, 08:42 AM   #16
FT-WA-MD-GS
FT-WA-MD-GS's Avatar
Oddometer: 9
Avner recommended that we get a Booster Plug temp sensor for our bikes on our recent ride in WV -- Gracias Avi!
http://www.boosterplug.com/shop/frontpage.html
We recently installed them on my F8 and K's F650GS. It almost entirely fixed this phenomenon! Rarely get a backfire now! Just pop off the faux tank cover and it slips into the Air Intake Temp sensor plug without a fuss; then used a zip-tie to affix the temp probe to the right side air snorkel. I think it was well worth the cost [~$150 via air mail from Denmark].
Sláinte! (Gaelic)
Phil & Karen
2010 F800GS,
2009 F650GS,
2009 Kawasaki KLX250S,
2008 Honda CRF230L, and
1975 R90S.
FT-WA-MD-GS is offline   Reply With Quote
Old 01-23-2013, 04:41 PM   #17
IL adv OP
Oddometer: 20
Sláinte! (Gaelic)
Phil & Karen
2010 F800GS,
2009 F650GS,
1975 R90S.
Does it also make it accelerate harder and stop the surging at low speeds like the info on the site says?
IL adv is offline   Reply With Quote
Old 01-23-2013, 05:32 PM   #18
FT-WA-MD-GS
Oddometer: 9
I'd have to agree with the web site, although I've only had it on for a couple of weeks. The throttle is more dependable now -- less hesitation is how I'd put it. We're both much happier with the performance of late. Just waiting for some warmer weather to get out on an extended excursion.
Sláinte! (Gaelic)
Philip & Karen
10 F800GS,
09 F650GS,
75 R90S.
Old 01-23-2013, 07:21 PM   #19
IL adv OP
Oddometer: 20
Thanks alot for your feedback. I will look into it forsure and check back with you to see how your feeling about it when you are able to get it out more.
Old 01-24-2013, 03:37 AM   #20
Steveman
Steveman's Avatar
Oddometer: 471
All of them do it, so its normal. Mine does it since day one and both bikes of my mates do it. Nothing to worry about.
cheers Steve
Sent from Samsung w. Tapatalk
Steveman is offline   Reply With Quote
Old 01-24-2013, 07:54 AM   #21
sorebutt
Oddometer: 1,930
My 2011 has never done it. Is there something wrong with it. Maybe I should take it to the dealer and complain it doesn't backfire.
sorebutt is offline   Reply With Quote
Old 01-24-2013, 02:49 PM   #22
FT-WA-MD-GS
Oddometer: 9
Quote from the 'What did Your Evil Twin Do Today" thread
Originally Posted by CanadaBiker View Post
I installed the Booster Plug on my 09 F650 Twin. Pretty easy. I'n my opinion, it's made a big difference. This is my first FI bike, and I wasn't digging the throttle response. I tried to get used to it, but after almost 4k kms, it was still an issue.
The change was instant with the BP. It really slowed down the way it rolls on. Almost stalled the bike at first. It also feels better coming out of a slow corner. Hitting the throttle half-way and the bike just chugs out really nice and strong. rear tire even broke loose, but there was no panic, just nice and even pulling through.
It also sounds just a tiny 'thicker' on the low rpms, but that could also be my imagination.
Anyway, happy with it.
FWIW, another vote for the Booster Plug...
Old 01-28-2013, 12:33 PM   #23
RheinGold
Weniger aber besser.
RheinGold's Avatar
Oddometer: 36
My 2012 with nearly 12,000 miles does it too. I's due to the lean fuel air mixture but also because the header and muffler pipe are a slip fit (held in place only by a small spring) and I think some of the popping may be due to gasses coming out of the joint too.
www.irahaskellphotography.com
RheinGold is offline   Reply With Quote
Old 02-04-2013, 09:23 PM   #24
LJRAT
LJR Adventure Tours
Oddometer: 60
I have a full exhaust balanced with a free flowing foam filter and the booster plug! NO POP!
LJRAT is offline   Reply With Quote
Old 02-04-2013, 10:10 PM   #25
GoneAgain
Huh?
GoneAgain's Avatar
Oddometer: 1,603
both of my 800's (09 and 12) did/do it....
but not enough... i love it... wish it would do it more often!
GoneAgain is offline   Reply With Quote
Old 02-05-2013, 11:19 AM   #26
itsatdm
itsatdm's Avatar
Oddometer: 4,979
I don't think that is the case, I sealed mine with no change. I suspect it is caused by the secondary air injection required for emissions. Joel explained it here: http://www.advrider.com/forums/showthread.php?t=637370 Does the F658gs do it? They do not have the air injection valve. In fact I suspect it may be USA specific as it does not show up in the universal repair CD.
Whether it is added oxygen caused by the air valve or just the normal lean idle of the ECU, it is the result of a lean mixture. It is normal.
The Booster plugs can help, as that rich ens up the fuel mixture as designed and there is some residual effect going back to closed loop (map) as the oxygen sender signal to the ECU does not result in an immediate change. If it is bothersome, don't snap the throttle closed.
It is there, but more easily heard with the aftermarket straight through mufflers. The ECU also adapts to the muffler change. Not as noisy as when first added.
I notice that in California, where they are always changing gas formulas, that it is more pronounced in summer than winter. The booster plug seems more effective in winter also, so they are doing something that effects burning rates of fuel.
itsatdm screwed with this post 02-05-2013 at 01:37 PM
Times are GMT -7.   It's 05:51 PM.
