06-14-2012, 03:37 PM
#16 |
Sober
Oddometer: 4,808
I have a '05 TTR 125 and the clutch engagement is way out, no engagement at all until the clutch is almost fully released.
I am assuming the clutch pack is due for replacement, but am open to other ideas.
SOBER I was pwned by a liberal, ask me how. Or just click:http://www.advrider.com/forums/showthread.php?t=838351 |
06-15-2012, 07:21 AM
#17 |
pistolero
Oddometer: 1,175
I know the lever on the clutch actuator is a bit short, but that usually causes a stiff clutch pull. I have heard (think it was thumper talk) of folks extending the that little lever. It may make the throw a littler longer but it sound more like you have a worn clutch. I assume you are getting close the the end of adjustment? it's not a stretched cable is it?
84 Honda Goldwing (GL1200) 03 XR650L |
07-08-2012, 10:07 AM
#18 |
The Fireman
Oddometer: 5,792
Hey folks,
I bought an 08' for my son a week ago. It had what I thought was rocker arm noise that ended up being piston slap. So I pulled the top end and found a galded piston, well crap. The kicker is I accidently dropped the cam gear washer behind the flywheel. I pulled the side cover but could not see the washer. Using a puller I attemped to pulle the flywheel off. the puller ended up bending the threads of the crankshaft. Now I have an engine that needs a piston and a crankshaft. Is the crankshaft really that soft? Has this happened to anyone else. No aftermarket crankshafts and a new OEM one is $300 ![]() Any help would be appriceated. Ray |
01-24-2013, 08:58 AM
#19 | |
aka Birdkilla
Oddometer: 2,346
Yes, the crank is that soft. When I did it to my son's bike, I ground down the end of the crank shaft so the flywheel would slide back on easily without screwing up the tapered finish of the flywheel. I then machined down the left side of the inner hub of the flywheel so that the thread of the bolt would engage again. I believe I ended up removing something like 1/4" of steel. Bolted it back up and off we went.
Cpt. Ron Sack-O-Tomato, CA '05.5 950 Adventure S "Bad Mutha F@&ker" '04 R1150RTP "cop motor, cop suspension.." '00 XR650R Dual Sport "Lil' Mule" '75 RL250 '01 TTR90 '01 PW50 Conti TKC80 tire swing "I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P. "Without the possibility of death, adventure is not possible"--Reinhold Messner |
