01-23-2013, 01:33 AM
#16 |
Hmmmm...
Oddometer: 26
01-23-2013, 05:45 AM
#17 | |
Oddometer: 2,778
Erling |
01-23-2013, 08:18 AM
#18 | |
Almost dirt rider
Oddometer: 41
With Akra you'll not lose low-end snap as per the average of aftermarket mufflers. Have a nice mod; the best is anyway remapping BMSK: with PC, if I do remember, it's impossible to play with ignition advance timing... it tells a lot and can compensate your carbon silencer. |
01-23-2013, 08:25 AM
#19 | |
Oddometer: 2,778
Erling |
01-23-2013, 05:12 PM
#20 |
Oddometer: 34
Flow
Why not gut the cat to obtain free flow? Has factory look flows straight threw ,With no bash plate problems?
Just a thought .. |
01-23-2013, 05:40 PM
#21 |
Oddometer: 112
I thought of same thing. Remove pipes, cut cat, have shop re-weld straight pipe. Eliminate weight, gain some possible power, and a fraction of the cost
01-23-2013, 06:20 PM
#22 | |
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,967
cut and welded it up all myself though |
01-23-2013, 07:32 PM
#23 |
Oddometer: 2,778
Regarding cut and reweld....It is a tempting prospect, and several have done it. A few concerns I have, is that at that spot, or should I say bend, if you have any blow through with the weld, you have a chance for creating a hot spot. If I had a TIG, and knew how to use it, I most likely would do just that. Also having a sudden big chamber empty could mess with the pulses, as rapid expansion, and compression off the gasses on the other side..... That is just speculation, but I know how important good flow is through headers. I am stuck with a mig, and a stick. I dont trust anyone to do a good enough weld.... Second thought, I do have one guy in mind in socal, who I does some Carbon work for...... Hmmmmm..... Now ya got me thinking.....
Erling |
01-24-2013, 01:17 AM
#24 | |
Almost dirt rider
Oddometer: 41
It's hard to believe you haven't the chance to reflash... after all it's the same ECU of BMW cars.
Here http://f800riders.org/forum/showthre...ina-F800/page8 there's a friend who reflashed (by himself) via BDM port his 650GS: pls look @ post #383. Red is OEM; light blue is modified IAT and blue is remapped. Reflashing is surely the best smiles-per-buck option to gain performance: you have the convenience to investigate better to go thru this solution. Quote:
Gaspare screwed with this post 01-24-2013 at 01:46 AM |
01-24-2013, 05:35 AM
#25 | |
Oddometer: 2,778
Erling |
01-24-2013, 06:33 AM
#26 | |
Oddometer: 760
Just cut it ![]() Gut it ![]() Reweld it and enjoy whatever performance gain it provides. |
01-24-2013, 09:25 AM
#27 | |
Almost dirt rider
Oddometer: 41
Mainly is matter of experience... and availability of a bench to build up this experience. Then, in a month time I'll remap mine, and I'll tell how it is, with all the available details onto procedure... Then part II: you're right about the RAM effect... it's not speculation. |
01-26-2013, 08:24 AM
#28 |
I'm running the TWALCOM/QD headers with ADV-spec crash bars & skid plate. Skidplate had to be modified to fit. Search my username for more info.
If a man does not keep pace with his companions, perhaps it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away. -Thoreau |
01-26-2013, 09:16 AM
#29 |
Oddometer: 124
This is probably a crazy idea, but what's the composition of the material inside the cat? Would there be any way to go in thru the end of the pipe with a borescope and something like a four prong spring loaded wire pickup tool and pluck out a channel thru the cat? I'm guessing it's probably too dense and or rigid for that, but don't know. Possibly a dremel flex shaft tool might also be an option?
Jttele
01-26-2013, 09:42 AM
#30 | |
Oddometer: 760
