Old 01-23-2013, 08:51 PM   #73126
neo1piv014
ADV in training
Oddometer: 627
Originally Posted by shaddix View Post
I make 18/hr. New harness is like 300 bucks. Best bet is to just buy and replace it myself?
Can we get a picture of what your wires look like? If they're all totally trashed, then yeah, you might have to just buy a new wiring harness (check ebay and local wrecker yards first), but if it's only one or two problem wires, soldering and shrinking is going to be fine.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 01-23-2013, 09:23 PM   #73127
neo1piv014
ADV in training
Oddometer: 627
In between studying for some IT exams at work, I finally got the top off my carb again, which would be vastly easier if the seat, side panels, tank, throttle cables, and choke cable didn't have to come off with it. Thanks to all the helpful folks on here, I realized that my white spacer was in the completely wrong place, and I had an unnecessary washer shimming things up as well. I pushed the spacer up to where I had the clip (position 3), made sure everything was snug, and set the washer aside. I put everything back together and let it idle for about 5-7 minutes in the garage just to get up to a temp where it didn't need the choke to maintain smooth idle.
After that, I started playing with the throttle position to see if there were any quickly detectable rough spots. The thing revved like it wanted to be a sport bike and sounded much, much better. There didn't seem to be nearly as much of a hesitation in the throttle, either. Assuming that this fixes the bogging, surging, and extremely poor mileage I've been getting, I'll call it a success. I'm definitely expecting to see some mileage improvements, since the spacer was essentially simulating a needle with the clip at the 75th position or so
Here's to hoping I'm done posting about carbs except to say "hey guys, I finally ordered that TM40"
my specs:
-12,500 miles on carb and engine
- K&N air filter
- Stock exhaust
- Cut airbox
- Non-USA OEM needle from motolab with clip on third position
Ride videos
'01 DR650
Old 01-24-2013, 01:14 AM   #73128
BergDonk
BergDonk's Avatar
Oddometer: 3,929
Electrical Repairs
It can be difficult to get replacement metric smoke because its so rarely needed, but the Imperial Lucas product is readily available at your local British bike or car shop. It just needs to be suitably massaged to adapt it to the metric application.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 01-24-2013, 01:20 AM   #73129
1989THEARK
1989THEARK's Avatar
Oddometer: 379
You make 18 an hour and will be paying 600 dollars if you dont find the problem the FIRST time.
i've replaced a few wiring harnesses myself in cars.
if it turns out the charging system is what melted the wiring harness in the first place you run the risk of not only burning a few wires.
but setting the bike on fire.
your choice. But if you set the bike on fire. can i have your foot pegz?
1989THEARK is offline   Reply With Quote
Old 01-24-2013, 05:53 AM   #73130
shaddix
Oddometer: 647
The harness is all melted together in two places, I can take pics this weekend
Yeah I'm just gonna take it to a dealer ._.
shaddix is offline   Reply With Quote
Old 01-24-2013, 07:14 AM   #73131
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 929
Ah Lucas, Prince of darkness!
Carl Childers is offline   Reply With Quote
Old 01-24-2013, 07:53 AM   #73132
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,740
Originally Posted by TIGERRIDER007 View Post
Do these last for a while? I'm looking hard at those Mezteler Unicross tires too...thanks!
I ride a mix of true offroad trails and gravel roads. 80 -90% And the rest tar. I typically trailer my DR650 to the area I'm gonna ride. I get about 2500 miles out of the Kenda Trakmaster rear and maybe 3500-4K from the ED-03.
I also had a wire harness fire. ended up putting in a used harness. (check ebay or other DR forums first) It was not to hard, but a bit of advice. I started at one end of the bike and worked my way to the other end unhooking and re-connecting as I went, so I could replicate the routing, which is important because of things like where the tank goes etc. best of luck. you can do it!
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 01-24-2013, 09:10 AM   #73133
Richguzzi
Richguzzi's Avatar
Oddometer: 63
Bring plenty of lube....
You should at least investigate whether those two spots are completely melted together or the sheathing is just melted all up due to one or two wires overheating. Could be an easy and far cheap solution to splice in some new wires and connections.
2012 DR 650
1986 Cagiva Alazzurra Tracker/Fighter/Cafe/Brat/Bobber project
1971 Moto Guzzi Ambassador
Slow old grey haired guys with arthritis and other ailments rule!
Richguzzi is offline   Reply With Quote
Old 01-24-2013, 11:13 AM   #73134
Rusty Rocket
Life behind "Bars"
Oddometer: 9,740
There are several DR650 wire harnesses on ebay. Ex: http://www.ebay.com/itm/Wiring-harne...020ca2&vxp=mtr
2009 DR650
Old 01-24-2013, 02:05 PM   #73135
Sic Semper Tyrannis
Oddometer: 641
You have comp on your insurance? Fire is a covered loss in most policies. The original individual part that failed likely won't be covered but all the resulting damage would be.
Sic Semper Tyrannis is offline   Reply With Quote
Old 01-24-2013, 02:13 PM   #73136
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,095
Originally Posted by sic semper tyrannis View Post
you have comp on your insurance? Fire is a covered loss in most policies. The original individual part that failed likely won't be covered but all the resulting damage would be.
+1
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 01-24-2013, 02:28 PM   #73137
MikeyP
Oddometer: 21
Originally Posted by motolab View Post
Well I guess that disqualifies the bike from the possibility of being the "definitive" candidate for tuning demonstration.
I hate to kick up a contentious subject once it's started to calm down a bit but in catching up with everything I've missed over the past couple weeks while work took over my life, I noticed that there was talk of Derek looking for a local candidate for some DR650 tuning tests. In case my reply was missed when this was discussed in December:
"I'm not sure what tests you'd like to run, but I'll offer up my bike in the name of science. I live only a short drive away in SF and I have ~16K miles on the odo, GSXR exhaust, Kientech midpipe, stock header pipe with ground weld, open top air box with K&N filter (also have the stock filter on hand), relatively fresh spark plugs, fuel filter, DJ kit, and only ~1500 miles on the slides in the carb. I bought those from you just a few months ago Derek at the same time I did a complete carb rebuild. I also have on hand an mx_rob FCR that I've been trying to find time to install. I could bring that along or come back after I install it to see what numbers change if that interests you."
The only thing I'd add based on recent discussions is that I do not have a non-USA OEM needle available.
-Mike
MikeyP is offline   Reply With Quote
Old 01-24-2013, 03:45 PM   #73138
Carl Childers
Oddometer: 929
HP / Torque Gain?
I've finished my header grind, GSXR muffler conversion and my stock carb Procycle jet and needle kit with air box cut out, oh yeah and a K&N filter. What are the stock numbers for the bike and what should I see typically with these mods? A better carburetor is on my list for the future but out of the budget for know.
I'm still snowed in so I can't go out and do my "seat of the pants dyno" ride I usually do after work like this and the suspense is killing me!
Old 01-24-2013, 05:00 PM   #73139
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 1,095
Thanks to all the info on tires, I've decided to get the Metzeler Unicross and keep the Bridgestone as a backup plan.
I appreciate the help and will be posting soon...I hope!
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is online now   Reply With Quote
Old 01-24-2013, 05:40 PM   #73140
805gregg
Just Stroming along
Oddometer: 1,595
Dual Star
Any DR guys know what happened to Dual Star motorcycle parts from Washington? Their website is still up but the phone number is out of service, just wondering, i bought lots of good quality parts from them in the past.
805gregg is offline   Reply With Quote
Times are GMT -7.   It's 02:06 PM.
