Old 01-25-2013, 12:33 PM   #1
DetourJournal OP
DetourJournal.com
DetourJournal's Avatar
Oddometer: 78
How to Remove Heat Stains on Engine?
I did a very bad thing. I started my 1150 GS, quickly ran inside to grab something, got distracted, and 30 minutes later, I found my bike in a thick cloud of smoke. I melted the Oil-view window and a couple of very minor plastic mounts, but from what I can tell, I got Lucky. (the bike hadn't seized and plenty oil was still rushing out, Oil Pressure Sensor is still intact)
The one thing I don't know is how can I remove the heat stains on the Engine and magnesium cylinder heads?
I've heard Vinegar works for stainless Steel, does anyone have any other suggestions?
DetourJournal is offline   Reply With Quote
Old 01-25-2013, 01:08 PM   #2
STUFF2C
We Ain't Left Yet!!
STUFF2C's Avatar
Oddometer: 2,961
Daaaaaaamn!
Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything.
-- Charles Kuralt
I never plan a ride, just the destination and that's always subject to change.
STUFF2C is offline   Reply With Quote
Old 01-25-2013, 01:11 PM   #3
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,694
The discoloration you're seeing is the finish applied to the parts, not the metal itself. You're probably going to have to strip it all off and refinish them.
If you're all about the destination, take a fucking flight.
Twilight Error is offline   Reply With Quote
Old 01-25-2013, 01:31 PM   #4
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,009
Vinegar is a weak acid. It won't touch your stains but will leave an unpleasant odor everywhere.
Try Super Clean, a strong, water soluble cleaner. It is available at Wal-Mart.
Careful, wear gloves if you're going to handle the wet parts...undiluted, the stuff will remove skin. Also, keep it away from glass...it can etch glass if not removed promptly.
It contains NaOH (sodium hydroxide) and silicates (strong alkalies). The pH is about 13.
I use it for grease removal on metal parts, carburetors, cleaning plastic furniture, as a deck cleaner with the pressure washer (diluted), carpet stain remover, laundry pre-spotter, cleaning the bar-b-q smoker, cleaning concrete, cleaning the wife's gold and platinum diamond rings, etc.
Diluted, it is excellent at cleaning auto wheels, tires or white walls (remember those?).
If the stains you have are cooked on oil, this stuff will take it off.
Oh, and its cheap....~$10.00/gallon. I purchased my last gallon about two years ago and still have plenty left.
Super Clean is my regular go-to all-purpose cleaner. I have it around in spray bottles at various strengths.
Rinse thoroughly.
def is online now   Reply With Quote
Old 01-25-2013, 01:42 PM   #5
def
def's Avatar
Oddometer: 10,009
The boxer engine should never be warmed up before riding. It is best to get your gear on, mount up and start the engine. Move the bike off the center stand, engage 1st gear and ride off...no warm up.
There have been instances of boxers catching fire by owners who made the same mistake...starting the engine, leaving it running and getting distracted.
You were fortunate however, you may experience some heat related problems in the future (seals, oil leaks, wiring damaged, etc.).
I would inspect the engine oil for signs of overheating and change it if found to be suspect.
Old 01-25-2013, 01:51 PM   #6
Twilight Error
Oddometer: 22,694
When the temperature dips below 10, I'll get partially geared, start the bike on the centerstand, go back inside to put on my 'stitch and helmet, then leave. This typically is during the morning when I'm on my way to work, so the chances I'll get distracted and not leave are quite slim.
Old 01-25-2013, 01:51 PM   #7
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,863
That's burned paint, not stained metal. I'd leave it alone. Consider it a badge of honor, a warning to others, ... whatever.
Replace the oil window, oil and filter, keep your eye out for leaks from any cooked seals and if nothing bad happens, consider yourself very lucky.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 01-25-2013, 01:53 PM   #8
Twilight Error
Oddometer: 22,694
I'd replace the valve cover gaskets (all four of them), they saw a lot of heat and probably aren't as flexible as they used to be.
Old 01-25-2013, 01:58 PM   #9
BigDave75
Will Work for Food!
BigDave75's Avatar
Oddometer: 1,747
Wow, sounds like you caught it just in time!
Rangers Lead the Way, Hooah!
BigDave75 is offline   Reply With Quote
Old 01-25-2013, 02:01 PM   #10
Juan Loboe
Juan Loboe's Avatar
Oddometer: 469
Tell others that you got the "gold package" option.
My $ .02
Juan Loboe is offline   Reply With Quote
Old 01-25-2013, 03:21 PM   #11
DetourJournal OP
DetourJournal.com
Oddometer: 78
Oh I Like that! Although, while I like the badge of honor, I prefer the badges that don't scream "Hey everyone! I'm a moron."
Trust Me. I Cried. The worst part is I totally know better (In fact I just cautioned others against the EXACT SAME thing in a How to Change your Oil Video). It was pure stupidity. These bikes don't need to warm up and I only intended to run into the house and right back out.
It's good to hear that it's just the finish on the metal that's stained. I'll definitely try Super Clean. Is it similar to just using carb cleaner?
Old 01-25-2013, 05:20 PM   #12
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Super clean is just a strong citrus based cleaner with amonia in it. It is not like carb cleaner at all. You must rinse it off with water, unlike carb cleaner.
I do not think anything will fix that discoloration except repainting the painted parts. Powder coat or even rattle can will work with varying levels of quality.
If you have no other damage you are very fortunate. I would worry about ALL of my electronics like the HES.....anything in an epoxy sealed canister like resistors or capacitor stuff.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 01-25-2013, 06:04 PM   #13
simoneau
Biker/Adventurer/Retiree
simoneau's Avatar
Oddometer: 201
You really should remove the valve covers and eyeball the timing chain tensioners and slide rails. A friend of mine did the same overheat to his engine and his rails and tensioners warped to the point of turning 90 degrees to their respective positions. In his case, noises ensued!
Randy
2014 BMW R1200GSA (OLIVE)
Ride it like you stole it, care for it like you'll keep it, never let it cool down and it'll last forever!
simoneau is online now   Reply With Quote
Old 01-25-2013, 08:04 PM   #14
def
def's Avatar
Oddometer: 10,009
Incorrect, Super Clean is not citrus based, does not contain NH3 and contains no volatile solvents. It is inorganic.
Old 01-25-2013, 08:09 PM   #15
Ayrshire Bull
why the hell not?
Ayrshire Bull's Avatar
Oddometer: 2,594
"It's not what you look at that matters, it's what you see." - HDT
Ayrshire Bull is offline   Reply With Quote
Times are GMT -7.   It's 10:07 AM.
