Old 01-25-2013, 08:17 PM   #16
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,013
Originally Posted by DetourJournal View Post
I'll definitely try Super Clean. Is it similar to just using carb cleaner?
No. It is not a solvent. It does not contain MEK, Xylene, Methyl Chloride, Methylene Chloride or any similar volatile organic compound and therefore is not an inhalant concern.
It is considered a Hazardous Chemical due to the strength of the sodium hydroxide and is labelled as such so, don't get it on skin or clothing that contacts skin. Don't get it in your eyes. Handle it like you would caustic oven cleaner or drain opener; gloves and eye protection.
def is offline   Reply With Quote
Old 01-25-2013, 08:21 PM   #17
def
def's Avatar
Oddometer: 10,013
Originally Posted by Ayrshire Bull View Post
Mr. Clean is a wimp compared to Super Clean. Also, he's too expensive.
Old 01-25-2013, 08:29 PM   #18
Ayrshire Bull
why the hell not?
Ayrshire Bull's Avatar
Oddometer: 2,594
so are you saying Ms Super Clean, is - 'cheap'? I wouldn't tell her to her face.
"It's not what you look at that matters, it's what you see." - HDT
Ayrshire Bull is online now   Reply With Quote
Old 01-25-2013, 08:38 PM   #19
def
def's Avatar
Oddometer: 10,013
Yup and smells better too.
Soak your brake rotors in it to remove brake pad deposits. Remove them first.
Old 01-25-2013, 09:14 PM   #20
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,863
Fixed...
Originally Posted by def View Post
It is considered a Hazardous Chemical due to the strength of the sodium hydroxide and is labelled as such so, don't get it on skin or clothing that contacts skin. Don't get it in your eyes. Handle it like you should caustic oven cleaner or drain opener; gloves and eye protection.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 01-26-2013, 03:26 AM   #21
everycredit
everycredit's Avatar
Oddometer: 272
I don't think any detergent is going to work. Aircraft stripper may work (this is to repaint/refinish cylinder head covers). A wire brush may pit magnesium/magnesium alloy. I''m not too experienced working with magnesium, so I don't know how soft it is and what you can get away with.
Paint with high-temp primer and paint.
everycredit is offline   Reply With Quote
Old 01-26-2013, 06:07 AM   #22
FixxiT
Lunitic Fringe
FixxiT's Avatar
Oddometer: 954
Originally Posted by simoneau View Post
you really should remove the valve covers and eyeball the timing chain tensioners and slide rails. A friend of mine did the same overheat to his engine and his rails and tensioners warped to the point of turning 90 degrees to their respective positions. In his case, noises ensued!
^ ^ this ^ ^
If the heat melted the sight glass & toasted the paint on the head covers..I would definitly be concerned about the condition of the internal plastic parts...cam chain guides, timing chain guides, oil inlet assy...
Survivor Series:
CroMag: 04*05*09*10*11*13*14 Recompence: 10 12 13 14
FixxiT is offline   Reply With Quote
Old 01-26-2013, 10:05 AM   #23
DetourJournal OP
DetourJournal.com
DetourJournal's Avatar
Oddometer: 78
Originally Posted by FixxiT View Post
^ ^ this ^ ^
It sounds like I'm definitely going to have to go deeper than simply removing the valve covers to check those things. Or is that as far as I'll probably need to go?
DetourJournal is offline   Reply With Quote
Old 01-26-2013, 10:12 AM   #24
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,697
You'll see the cam chain tensioner and guide rails when the valve covers come off. The ends are unsupported, if they're fine, chances are very good the rest of their length is. The timing chain tensioner and guide are in the front of the motor, which you'll want to partially disassemble to inspect the HES wiring anyway. I'd also look at the belt, it may have seen damaged as well.
If you're all about the destination, take a fucking flight.
Twilight Error is offline   Reply With Quote
Old 01-26-2013, 03:18 PM   #25
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Incorrect, Super Clean is not citrus based, does not contain NH3 and contains no volatile solvents. It is inorganic.
It looks as though you are correct, I could not find ammonia in its ingediendts. But it sure has that high ammonia smell and pain in my lungs if I breath it in.
It is labeled as a level 3 health hazard and a high inhalation risk...ammonia or not. It is also listed as Citrus scented as it shows on page 3/7 of the MSDS sheet...it is listed as a hazardous material as per OSHA regs and is a HAZMAT chemical
http://www.supercleanbrands.com/site...2003-10-11.pdf
Sorry for mis-speaking. My intent was to warn the user to be careful. I may be thinking of my Super Purple cleaner I have that is citrus and ammonia....one of them. But they all tear up my lungs if I get a whiff.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 01-26-2013, 03:54 PM   #26
WindSailor
WindSailor's Avatar
Oddometer: 666
Yep.
We work with different solutions of sodium hydroxide - and it is plumb ass dangerous.
We had a pump that blew a gasket and sprayed a women who was standing near by - they rushed her to a safety shower probably within 45 seconds and during that time she lost 80% of her hair on the top of her head. Not nice stuff.
That slimy feeling when you rub your fingers together with caustic on it - is your skin melting off. It's not like an acid, with caustic you have to continue to rinse with water for 15 min.
Anyway...
WindSailor is offline   Reply With Quote
Old 01-27-2013, 04:12 PM   #27
vintagerider
vintagerider's Avatar
Oddometer: 1,967
Its the loss of temper to the input splines that you may want to look after. In spite of all the postulations on sudden input spline failure it is actually caused by the owner over-heating on the side stand. Splash lubrication of oil originating in the clutch slave cavity can't make it to the splines while on the side stand.
for sale: 1968 R 69 S-us original condition
vintagerider is offline   Reply With Quote
Old 01-27-2013, 07:36 PM   #28
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,349
Seriously? You think a motor hitting maybe 250-275 will remove the temper from the input splines?
You would have to melt the case to do that!
Jim
Old 01-27-2013, 08:03 PM   #29
def
def's Avatar
Oddometer: 10,013
Super Clean is not a detergent.
Aircraft paint strippers are hazardous and require a respirator as do the aircraft paints. Unless you are experienced and have the equipment, stay away from them.
If you want to restore the factory look and durability, have the OHV covers powder coated.
Old 01-27-2013, 08:05 PM   #30
def
def's Avatar
Oddometer: 10,013
Yes, if the splines were made of silly-putty.
Times are GMT -7.   It's 12:44 AM.
