Old 01-26-2013, 10:05 AM   #1
woodly1069 OP
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,860
"Clocking" airhead drive shaft?
Just wondering if I need to reassemble the drive shaft from my R75/5 in any relative position? See when we had it in the press and were heating it up, it went BOOM! Knocked my buddy on to the floor and then I fell down laughing at him Problem is, I guess my dumb ass must have baked the markings right off the parts... I see that there is a small hole in the largest part of the OD on the spline connection and since there is just a taper for a press fit it can line up with anything...any thoughts?
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is online now   Reply With Quote
Old 01-26-2013, 10:55 AM   #2
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,463
Correct, it can line up anywhere. Make sure you completely clean up the mating surfaces!
Big Bamboo is online now   Reply With Quote
Old 01-26-2013, 11:11 AM   #3
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,469
...and whatever you use to clean make sure it evaporates completely. Assemble it clean and DRY.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler is online now   Reply With Quote
Old 01-26-2013, 02:42 PM   #4
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,860
OK guys, how about brake clean? thanks a bunch!
Old 01-26-2013, 06:47 PM   #5
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,419
Then wipe it down with a white spirit which evaporates completely.
boxerboy81 is offline   Reply With Quote
Old 01-26-2013, 06:52 PM   #6
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,195
What is a white spirit?
---Albert Einstein
disston is online now   Reply With Quote
Old 01-26-2013, 06:55 PM   #7
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,860
MMM...moonshine!
Old 01-26-2013, 08:12 PM   #8
Big Bamboo
Big Bamboo's Avatar
Oddometer: 3,463
Acetone will work too
Old 01-26-2013, 08:27 PM   #9
jackd
Oddometer: 3,034
White spirit is camp stove fuel (otherwise known as white gas or naptha). It's a good solvent which evaporates cleanly. I first started using in an aircraft component shop that I worked in - it was recommended by manufacturers.
Old 01-27-2013, 03:27 PM   #10
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,546
If you have any of them surface preparation products, to be used "before and after sanding" to remove waxes and sillycones before painting, it is also white spirits/naphta/Coleman fuel.
Yep bought some specialized Rustoleum product before I figured it out. Well figured out that I could have used my Coleman fuel would have saved me $10.00. Only had to smell the Rusto to find out.Should have done that at the store....
Someone gave me a BMW Zippo lighter....guess what's in it? Sure ain't overpriced lighter fluid aka Naphta.
Have tools, will travel!
Old 01-29-2013, 08:35 AM   #11
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,860
OK ready to go, clean and assembled. Should l attempt to "hold" the u-joint and torque the nut in place or bolt it to the transmission first? I think bolting it up makes more sense but I don't want to damage the tranny. Of couse I would hold the drive shaft while torquing...
Old 01-29-2013, 11:50 AM   #12
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,774
Hmmm... iirc that nut takes a huge amount of torque, and I am not sure I would want to be torquing the u-joint at the other end... if you bolt up to tranny to stabilize and hold that end of the shaft, I would still immobilize the shaft somehow between the u-joint and the bell end...
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 01-29-2013, 12:09 PM   #13
Big Bamboo
Big Bamboo's Avatar
Oddometer: 3,463
Cycle Works recommends holding the yoke that is part of the driveshaft in a vice "so that the jaws close on the flat area around the holes that the cross is in".
Old 01-29-2013, 12:19 PM   #14
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,860
OK, thanks guys, guess it's a good thing I haven't put it in the bike then
Old 01-29-2013, 12:22 PM   #15
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,774
Well done! Always good to learn a little something every day.... I can have a beer with a clear conscience later
Loving the 80ST
Times are GMT -7.   It's 03:48 PM.
