Old 01-25-2013, 11:16 PM   #32716
oldtrucks
oldtrucks's Avatar
Oddometer: 286
I've checked both spots, the 30 amp main is good and all of the individual fuses in the Block are fine as well
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. -Benjamin Franklin
oldtrucks is offline   Reply With Quote
Old 01-26-2013, 04:21 AM   #32717
DragonNester
DragonNester's Avatar
Oddometer: 447
Originally Posted by amtz.zero View Post
I asked this earlier but I guess no one saw my post, but can I run the stock chain if I move up to 13/46 gearing? Thanks!
Go ahead and put a 47t steel sprocket on her with a 112 link X-ring chain. It's a good dirt ratio without sacrificing the highway too much...IMO
Remember your speedometer will be way off after any final drive ratio change.
Happiness is wanting what you get.
DragonNester screwed with this post 01-26-2013 at 04:28 AM
DragonNester is offline   Reply With Quote
Old 01-26-2013, 04:39 AM   #32718
1Down-5Up
1Down-5Up's Avatar
Oddometer: 109
Fuel pump life
What's the most "mileage" anyone gotten out of a fuel pump?
1Down-5Up is offline   Reply With Quote
Old 01-26-2013, 05:29 AM   #32719
Joe Watson
Joe Watson's Avatar
Oddometer: 1,031
Well, it's time for me to sign out all! I hope you all got a little bit of info from my build. It will be in my signature for a while, so check it out. The WR250R went to a new home today, hopefully it gets may more good miles on her as it gave me.
Farewell.
Joe Watson is offline   Reply With Quote
Old 01-26-2013, 06:51 AM   #32720
japako
japako's Avatar
Oddometer: 592
Originally Posted by oldtrucks View Post
While looking for an Ignition Hot to tap into I shorted and lost power to my ignition, headlight, tail light, brake lights, horn, and dash console. The blinkers still work and the fuel pump powers up fine. I checked all the fuses and they're all good which makes me think I did something to the Relay Assembly.
Anyone know of a way to check the Relay before I spend the $
I'm pretty sure the relay for the lights is the same as the other small relay.
Try swapping the two relays.??
You can also check the continuity of the relay.
japako screwed with this post 01-26-2013 at 07:11 AM
japako is offline   Reply With Quote
Old 01-26-2013, 08:03 AM   #32721
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 577
Oldtrucks,
Did you disconnect the battery before attempting to tap the line? If not you may have fried a diode in the Starting circuit cut-off relay. You will need a volt meter with diode test capability. It is pretty hard to fry a relay without blowing a fuse so here is the tech manual on sequence to check continuity of your relays and the final check is the diodes. The photos are numbered in sequence as found in the rear of the tech manual. Have fun.
Paul
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 screwed with this post 01-26-2013 at 01:00 PM Reason: Edited for copyright purposes
pfy50 is offline   Reply With Quote
Old 01-26-2013, 08:12 AM   #32722
oldtrucks
oldtrucks's Avatar
Oddometer: 286
None of the relays I found are alike, all different shapes, sizes, and connectors. The one in question has a 16 pin connector, all the others are much smaller
Old 01-26-2013, 08:17 AM   #32723
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 577
That's should be the relay. The Start circuit cut off relay and fuel pump Page 2 and 3 above
It is #11 on the wiring diagram, you should be able to see the diodes on the schematic.
If it is the Start circuit cut-off relay(#11)I believe this is the part #
Relay Assy 5VK-81950-40-00
$36.34 @ Cheapcycleparts.com http://www.cheapcycleparts.com/model...2-electrical-2
pfy50 screwed with this post 01-26-2013 at 01:04 PM Reason: Edited for copyright reasons
Old 01-26-2013, 08:51 AM   #32724
oldtrucks
oldtrucks's Avatar
Oddometer: 286
Originally Posted by pfy50 View Post
Oldtrucks,
Paul,
Battery was in and the Key was on. I was using a test light trying to verify I had the taillight connector. Last thing I did was tell myself to not let the probe hit two posts at the same time, the rest is history
I'm in denial and was hoping it would be something simple. Thanks for the prod, looks like I'll be learning about the WR electrical system later today
Larry
Old 01-26-2013, 09:26 AM   #32725
oldtrucks
oldtrucks's Avatar
Oddometer: 286
That's the part I have in my hand, less the "-00" on the end. I'll feel a lot better ordering it once I test it and know it has a problem. Thanks
Old 01-26-2013, 10:14 AM   #32726
Off Road USA
Off Road USA's Avatar
Oddometer: 143
whats the opinion on the Flathead Racing skid plate and radiator gaurd ..????
Off Road USA is offline   Reply With Quote
Old 01-26-2013, 10:52 AM   #32727
sturgeon
sturgeon's Avatar
Oddometer: 935
You mean Flatland? I don't think a flathead would fit in the frame
So far so good with mine. The skid plate amplifies engine noise, but I think "they all do that".
Dyslexics Untie!
sturgeon is offline   Reply With Quote
Old 01-26-2013, 12:26 PM   #32728
KansasBob
KansasBob's Avatar
Oddometer: 515
Flatland racing makes all their plates and guards in Emporia Kansas. The employes running the shears, C&C machines, and welders are riders to a man. Their products are top notch, and If you have a problem they will stand behind them.
You can't go wrong with them.
KansasBob is offline   Reply With Quote
Old 01-26-2013, 12:46 PM   #32729
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 577
I guess you won't be making that mistake again. It's all part of the learning process.
Yeh, the last 2 (0-0) is added on for computer stock numbering or something like that as long as rest of it matches.
ps. Don't forget to follow the steps a-d starting on bottom of page 9 above.
Sent you a PM
pfy50 screwed with this post 01-26-2013 at 01:05 PM
Old 01-26-2013, 12:55 PM   #32730
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,908
Well that's cool, did not know that.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Times are GMT -7.   It's 12:49 PM.
