01-26-2013, 12:26 AM
#15841 | |
Wash everything and put it back togeder with lots of grease. ![]() Get yourself a beer-buddy with extensive knowledge of the piggy, get a lot of beer and knock yourself out . I do this two times every year.This was my first guide: http://www.xr650r.us/issues/ achile screwed with this post 01-26-2013 at 12:49 AM |
01-26-2013, 01:08 AM
#15842 | |
Pumpkinhead ;-)
Oddometer: 454
Yip, spark every revolution - anyone with a Trailtech computer should know this. I also was thinking about 'off timing', although a bit unlikely I think. The XRR fires (on kicking) at precisely TDC, the CDI starts to advance at crank speeds higher than by kicking it round. "Too early" (before TDC) would cause kickbacks causing the decomp to act. Snorting into the exhaust, plus maybe coughing back into the airbox. If no decomp-system present (non-std cam but for the genuine HRC) then it might break a leg/foot, but notice you fooken will! "Too late" would cause normal starting & running but just a bit lousy, unless of course when it is heaps off the mark. Off-timing could be caused either by a worn/damaged key-match, or the trailing edge of the welded-on plate (rectangular protrusion) on the rotor/flywheel is damaged. Both not common problems - but maybe worth checking if Ist got it off anyway? |
01-26-2013, 07:02 AM
#15843 |
I've got bike ADD
Oddometer: 1,067
what's the distance on the OEM oil dipstick from the bottom of the threads to the "HIgh" oil level, maybe the "LOW" oil level too? My XR-R came with an oil sight tube, I don't have the original dipstick so I'm not sure where the oil should be in the tube? I thought I'd put a couple marks on the frame for when I forget a couple years from now.
My XR with the new 19" I built (I have a "like new" OEM 21 rim and spokes if anyone needs it)
01-26-2013, 09:36 AM
#15844 | |
Global Bummer!
Oddometer: 266
01-26-2013, 10:05 AM
#15845 |
Red Rider
01-26-2013, 11:17 AM
#15846 |
Part time adventurer
Oddometer: 92
Thanks Kiko- The footpeg has already been done and I'm hoping to be able to afford an 8" light before June.
Achile- I'm hoping to have the time for a complete disassembly. What am I looking for with the cam chain? Is it stretch? How do you tell? Thanks, Adam |
01-26-2013, 12:57 PM
#15847 |
I don't wana pickle
Oddometer: 687
Very nice clean xrr you have there
____________________________________________ bikes BMW R1100s,destroyed by deer strike. Yamaha FZR 1000 (sold) Honda Cr 500 sold |
01-26-2013, 01:15 PM
#15848 | |
The problem is that I found two pigs with seized links, but they were sitting around for a while. |
01-26-2013, 03:25 PM
#15849 |
Oddometer: 92
The problem is that I found two pigs with seized links, but they were sitting around for a while.[/QUOTE]
Got it. Worth a look. Thanks. |
01-26-2013, 11:38 PM
#15850 | |
Pumpkinhead ;-)
Oddometer: 454
When I saw that pic my first thought was "No way!!", and went checking - erm, correct, 'scuse me Squire ![]() Your markers however correspond to the "correct" level and the "end-of-dipstick" level - and calling the latter the 'low' mark is somewhat misleading I think. I'd regard "low" about where the cabletie is in your pic, and when mine is there it most certainly will get a slosh of oil added - this is (very roughly) halfway the height of the steering stem, in fact I would say this is a "too low" mark already. But PineyMR, a sight tube makes life a damn site simpler - add oil if it's not at the 'normal' mark rather than waiting until you can't see it anymore during riding. The correct qty of oil also keeps the oil hence engine cooler, pls keep in mind that the ali frame acts as a (very good) oil-cooler. |
01-27-2013, 12:23 AM
#15851 |
Kicker Brother
Oddometer: 3,060
plus 1 ...what BuRPsa said
remembering oil level will drop when on the fly so i have a mark for on the fly full ....a mark for needs oil when stopped and a mark for full best thing to add to any xrr ...i also carry 2 bolts as backup of god forbid the line splits or a fitting works loose easy to wind out the fitting and then install the bolts to get you home
01-27-2013, 02:14 AM
#15852 |
Oddometer: 88
Too much fun!!
01-27-2013, 04:23 AM
#15853 |
Pumpkinhead ;-)
Oddometer: 454
Odd post but hear me out - and YES, this most certainly is Pig-related.
Anyone knows of one or some of these, an oldish travel mug? ![]() Similar things, pref plastic wanted, and if at all possible with a Green Bay Packers logo. If you know one or some then contact Focker, administrator/site-owner of http://www.xr650rforum.com Check his post: http://www.xr650rforum.com/t1672-nee...of-these#10055 I've never seen these things but he's a good dude, so go help him if you can? |
01-27-2013, 11:44 AM
#15854 | |
Half Man Half BRP
Oddometer: 271
My Blogs: http://xr650r.blogspot.com.au/ http://dirttbikediaries.blogspot.com.au/ |
01-27-2013, 11:57 AM
#15855 | ||
I've got bike ADD
Oddometer: 1,067
Bought it last summer from an inmate in Memphis, he had it set up for dual sporting and I'm using it more for road, and with the 19 front I plan to use it for a few track days. Quote:
