Old 01-26-2013, 09:05 AM   #1
woodly1069 OP
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,956
"Clocking" airhead drive shaft?
Just wondering if I need to reassemble the drive shaft from my R75/5 in any relative position? See when we had it in the press and were heating it up, it went BOOM! Knocked my buddy on to the floor and then I fell down laughing at him Problem is, I guess my dumb ass must have baked the markings right off the parts... I see that there is a small hole in the largest part of the OD on the spline connection and since there is just a taper for a press fit it can line up with anything...any thoughts?
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is online now   Reply With Quote
Old 01-26-2013, 09:55 AM   #2
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,760
Correct, it can line up anywhere. Make sure you completely clean up the mating surfaces!
Big Bamboo is offline   Reply With Quote
Old 01-26-2013, 10:11 AM   #3
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,548
...and whatever you use to clean make sure it evaporates completely. Assemble it clean and DRY.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-26-2013, 01:42 PM   #4
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,956
OK guys, how about brake clean? thanks a bunch!
Old 01-26-2013, 05:47 PM   #5
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,577
Then wipe it down with a white spirit which evaporates completely.
boxerboy81 is offline   Reply With Quote
Old 01-26-2013, 05:52 PM   #6
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,716
What is a white spirit?
---Albert Einstein
disston is online now   Reply With Quote
Old 01-26-2013, 05:55 PM   #7
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,956
MMM...moonshine!
Old 01-26-2013, 07:12 PM   #8
Big Bamboo
Big Bamboo's Avatar
Oddometer: 3,760
Acetone will work too
Old 01-26-2013, 07:27 PM   #9
jackd
Oddometer: 3,047
White spirit is camp stove fuel (otherwise known as white gas or naptha). It's a good solvent which evaporates cleanly. I first started using in an aircraft component shop that I worked in - it was recommended by manufacturers.
Old 01-27-2013, 02:27 PM   #10
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
If you have any of them surface preparation products, to be used "before and after sanding" to remove waxes and sillycones before painting, it is also white spirits/naphta/Coleman fuel.
Yep bought some specialized Rustoleum product before I figured it out. Well figured out that I could have used my Coleman fuel would have saved me $10.00. Only had to smell the Rusto to find out.Should have done that at the store....
Someone gave me a BMW Zippo lighter....guess what's in it? Sure ain't overpriced lighter fluid aka Naphta.
Have tools, will travel!
Old 01-29-2013, 07:35 AM   #11
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,956
OK ready to go, clean and assembled. Should l attempt to "hold" the u-joint and torque the nut in place or bolt it to the transmission first? I think bolting it up makes more sense but I don't want to damage the tranny. Of couse I would hold the drive shaft while torquing...
Old 01-29-2013, 10:50 AM   #12
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,824
Hmmm... iirc that nut takes a huge amount of torque, and I am not sure I would want to be torquing the u-joint at the other end... if you bolt up to tranny to stabilize and hold that end of the shaft, I would still immobilize the shaft somehow between the u-joint and the bell end...
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 01-29-2013, 11:09 AM   #13
Big Bamboo
Big Bamboo's Avatar
Oddometer: 3,760
Cycle Works recommends holding the yoke that is part of the driveshaft in a vice "so that the jaws close on the flat area around the holes that the cross is in".
Old 01-29-2013, 11:19 AM   #14
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,956
OK, thanks guys, guess it's a good thing I haven't put it in the bike then
Old 01-29-2013, 11:22 AM   #15
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,824
Well done! Always good to learn a little something every day.... I can have a beer with a clear conscience later
Loving the 80ST
Times are GMT -7.   It's 09:26 AM.
