Old 01-25-2013, 07:18 PM   #17701
Gadget678
Gadget678's Avatar
Oddometer: 778
Originally Posted by coarsegoldkid View Post
Anyone out there have pics of your Rollie bags utilized as tank paniers? I just might need to load even more weight upon my diminutive dual sport. Here it is with the rear paniers.
Try 59DEN's bike
http://advrider.com/forums/showthread.php?t=761487
He'll even give you CAD drawings for how he gets them to stay there.... if you ask nicely
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 01-25-2013, 07:18 PM   #17702
GrayEagleRider
Oddometer: 58
Originally Posted by Mediocre View Post
I have quite a few drz400 videos on my channel, check it out! If any wants coordinates on the ride locations just shoot me a message.
http://www.youtube.com/watch?v=J-wSOpekaSQ
www.youtube.com/wrath666child
That looks like a ton of fun! I really miss my thumper... and a place to ride it.
GrayEagleRider is offline   Reply With Quote
Old 01-26-2013, 12:03 PM   #17703
blaster11
Are you a Sheeple?
blaster11's Avatar
Oddometer: 4,696
Send a message via Skype™ to blaster11
A small upgrade
So I got the DRZ up on the lift and decided it was a perfect time to increase the footprint of the kickstand just a bit. For all the effort maybe I should have made it larger but then again I didn't want anything huge.
So I started with a big washer that I picked up at Tractor supply.
Then cut it out with the plasma cutter and dressed it up with a die grinder and welded it on from the bottom.
Then took the angle grinder to it and made it flat again.
Sandblasted it a bit to get the burned up paint off and then shot a little semi-gloss black on the bare metal...I will install it later.
This should work just fine!
Bruce
IBA # 46755
Adventures of Blaster and Dorito
blaster11 is offline   Reply With Quote
Old 01-26-2013, 08:21 PM   #17704
Buckeye105
Buckeye105's Avatar
Oddometer: 9
Question leaky water pump
I noticed this small leak coming from the water pump yesterday. I ride a 04 S with only 8k miles on it. Strange thing is it only leaks a little bit when the bike is running hot. Should i even worry about this or should i just go ahead and try the water pump fix i see on TT?
Buckeye105 is offline   Reply With Quote
Old 01-26-2013, 08:26 PM   #17705
focallength
patty cake champion
focallength's Avatar
Oddometer: 3,411
$25 gets you a new seal, just order a 08/09/12 seal, leave the ductape/bailing wire fixes for baja...
just keep in mind everyone at TT will tell you youre bike will fly out of control and spontaneously combust taking out a nunnery if you dont do the mandatory fixes...
Unregistered destructive device.
focallength is offline   Reply With Quote
Old 01-26-2013, 08:43 PM   #17706
Buckeye105
Buckeye105's Avatar
Oddometer: 9
Haha, thanks for the tip.
Old 01-26-2013, 08:48 PM   #17707
Steinbuck
Oddometer: 28
Why not just weld on the whole washer from the top? You'd end up with more bottom surface area (good in sand) and it'd look a lot more "commando", to boot!
Not everyone who wanders is lost. (J.R.R. Tolkein)
Steinbuck is offline   Reply With Quote
Old 01-26-2013, 09:08 PM   #17708
955616846
Oddometer: 1,692
Funny and good advice...
Cheers, Numbers
05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800
Founding member Longtails SC
955616846 is offline   Reply With Quote
Old 01-26-2013, 09:10 PM   #17709
jordan p
projects > time alloted
jordan p's Avatar
Oddometer: 79
Exactly what I was thinking
jordan p is offline   Reply With Quote
Old 01-26-2013, 09:25 PM   #17710
955616846
Oddometer: 1,692
That bottom irregularity makes no difference on soft ground. Surface area is the same.
Cheers, Numbers
Old 01-26-2013, 09:32 PM   #17711
jordan p
jordan p's Avatar
Oddometer: 79
Would it not be stronger on solid ground with a full washer though?
Old 01-26-2013, 10:10 PM   #17712
955616846
Oddometer: 1,692
Stronger as in what it takes to bend the foot? Maybe...
The only scenario that I can think of where the strength of the foot could make a difference is when regularly pivoting the bike on the side stand. This foot isn't exactly huge in comparison to the original so should be okay... and even if it does curl up a bit should still be okay on soft ground.
FWIW, mines a 65x4mm disk and the original foot was completely removed so that its replacement could be welded directly to the leg. A ball was welded to the end of the foot so that it wasn't tearing up the workshop floor every time the bike needed to be pivoted on the stand.
Cheers, Numbers
Old 01-26-2013, 10:14 PM   #17713
jordan p
jordan p's Avatar
Oddometer: 79
Nice!
Old 01-27-2013, 05:22 AM   #17714
blaster11
Are you a Sheeple?
blaster11's Avatar
Oddometer: 4,696
I have a done a few of these and one of them I did was like you said...just putting the washer on the bottom and welding on the top. It's not what I wanted to do but that's what he wanted. It looked terrible and every time I see it I want to cut it off and do it right... KLR owner. I prefer my stuff to be a bit more clean of an installation, I did another one on the wife's DR200 where I cut it out but welded from the top, not as clean looking.....I may redo it one day it's not about strength it's all about surface area so it really doesn't matter. As long as it helps to keep the bike upright in soft surfaces I will be happy.
Bruce
IBA # 46755
Old 01-27-2013, 09:27 AM   #17715
Starchamp
Starchamp's Avatar
Oddometer: 229
I agree with welding from the top, if only because it looks like 75% of the weld on the bottom was ground off to regain the flat surface. You can see places where it looks like the washer and stand are no longer welded together.
Starchamp is offline   Reply With Quote
Times are GMT -7.   It's 09:37 AM.
