01-20-2013, 09:09 AM
#1 |
PsyKotic Waterfowl
Oddometer: 9,970
12V 15W LED CREE Aux Lights - Anybody here have them?
These: http://www.ebay.com/itm/12V-15W-LED-...c91aa3&vxp=mtr
They look like a good bang for the buck conspicuity light. My question is can the handlebar clamp be removed and replaced with a DIY bracket for mounting them differently?
93 K1100LT, 94 K1100RS, 86-97 K75F (K75/100/1100 Frankenbrick), 91 K1, 05 KTM 450 SMR IBA #17739 (SS1K, BBG, 50CC) http://home.comcast.net/~smithduck/BMW_Tours.htm |
01-27-2013, 07:14 AM
#2 |
Gorilla Adventurer
Oddometer: 1,951
There's lots of different ones. I'm curious how they are too. I don't know if they allow you to see any better at night, or just allow you to be seen better?
http://www.ebay.com/itm/Chrome-Motor...658004&vxp=mtr
bikes |
01-27-2013, 09:37 AM
#3 |
Oddometer: 429
2allbuyer on ebay has a number of led lights with different mounting options for sale on ebay.... look very much like the lights that sanjoh sells here in the vendor section
Tiger 955i / DRZ400S < FJR1300 < DL1000 < BMW R1100RS < Ducati ST4 < DL650 *** 30+ years *** 125 Honda Elsinore < Suzuki TM250 < Yamaha 90 Enduro < Taco |
01-27-2013, 11:29 AM
#4 | |
Oddometer: 99
I had a pair of these in red. They are very directional. I know led's are directional but these were near useless unless seen from exactly the right angle. The OP choice would be better and there are several available up to 3000 lumens from different ebay sources. |
01-27-2013, 11:56 AM
#5 | |||
Oddometer: 277
I've been running a pair on my Husky and they work well. Quote:
- Matt 96 R1100RSL (red) 08 TE610 |
01-27-2013, 12:54 PM
#6 |
Gorilla Adventurer
Oddometer: 1,951
What are CREE lights?
bikes |
01-27-2013, 01:08 PM
#7 |
CREE is a type of LED emitter. The problem is there are several versions of it....and it makes a dramatic difference in both the amount of light the emitter is capabale of putting as well as the amount of heat it puts out in relation to the amount of light produced (efficiency)
"We cant solve our problems with the same thinking that created them"...Einstein |
01-27-2013, 01:32 PM
#8 |
Castle Anthrax
Oddometer: 1,198
Drake,
I think Gwen has them on the shop whore. Get in touch with da' woman. John |
01-28-2013, 04:39 AM
#9 | |
Oddometer: 99
Matt, my post refers to the lights in the quote to which I replied, not the ones to which you refer I stand by my observation on the lights I referenced. Whether spot or flood, led's are directional- spot/flood is the beam pattern, not the ability of the light to be seen from side angles. That is not a big deal if the lights are used to provide visibility for the rider. it is a huge deal if the led's are being used to be seen by others, especially brake and to some degree, running lights. nbsdave screwed with this post 01-28-2013 at 04:51 AM Reason: correct |
01-28-2013, 07:08 AM
#10 |
Oddometer: 1,094
I've bought the lights from that ebay vendor, with the longer housing that have been seen here, and he's extremely good to deal with. IIRC I got mine for about 90 for the pair delivered to Canada. He has them in different configurations (watts/.led's etc) as the rest of the people that sell that Chinese made product.
'64 BMW R50/2 - "Gone but not forgotten" '76 BMW R90/6 '02 BMW R1150 GSA |
01-28-2013, 12:18 PM
#11 | |
Lost in Georgia
Oddometer: 559
Long story is that I have multiple bikes. I ride year round to work. I get off of work at 1am. So riding home with the deer and the drunks is a challenge. Two years ago I converted my two main bikes to HID with kits from DDMTuming. The H4 hi/Lows are great. The shield makes the low pattern perfect and not blinding to oncoming traffic, yet the high gives me much more range. It went from about 9 seconds ahead at 45MPH, to about 18 seconds ahead. I have always run driving lights for daytime conspicuity and to help at night. On one bike, I run cheap 35 watt spots (weak alternator). These work fine for daytime conspicuity but were not much help at night for distance even though they are spot lights. On the other bike I had 55 watt flood lights. Those also worked well for daytime conspicuity, but because of the broad pattern, did little for nighttime distance. I have been putting off converting to LED auxiliary lights for two reasons. One, they are too bright to just leave on during the day, so I need a dimmer for them. And two, they have been stupid expensive. Well, I had been working on a dimmer, one that would run them at a low intensity when other traffic is around, and would automatically crank them to full blast when I go to high beam. I just completed the design and build for that, so I ordered some LED lights. I ordered these a couple of weeks ago for the bike with the flood lamps: http://www.amazon.com/gp/product/B00...ls_o03_s00_i00 27 watt with a 30 degree spot pattern. The reality is that it measures closer to 21 watts. I ran a 4 hour test with no air movement, and it does not over heat. The pattern is exactly what I want, a fairly bright spot with what looks like a bit more then 30 degrees, and enough light scatter to cover the sides of the road. They work with my home brewed dimmer and I'm happy with the results. As for reliability, that will take a year to find out. The thing is built like a rock though. And I can't see any way for water to get in. I wanted something significantly smaller for the other bike. Not a lot of good mounting options on it. So when I saw these, I ordered them (in the white LED version). Yes, the mounting bracket can be removed. That actually run at about 8 watts, not 15 as claimed. But then, at 8 watts for about 1 hour, they get very hot if there is no air movement, so I'm not sure much more wattage would be a good idea in that small package anyway. They are built somewhat poorly, but then for $23 I had low expectations. What is a bit of a problem though is that they are a VERY narrow spot. Much narrower then the 30 degrees on the other lights that I got. I haven't installed them permanently yet, as I need to build another dimmer, but the pencil thin beam will reach WAY out, if properly aligned. I may put a slightly frosted cover over it to scatter some light, or not. They also don't have enough water protection. Water can enter into the housing around the bolt easily, and not get out. So I could envision a housing full of water. The electronics has sealant on it, but I wouldn't want it to float in water as it is now designed. If you get these, plan to spend time water proofing it, or expect a short life. I'll report again after a few months. worwig screwed with this post 01-29-2013 at 07:37 AM |
