Old 01-22-2013, 07:33 AM   #1
NoVa Rider OP
Oddometer: 2,870
Odyssey PC625 / 2011 GSA
My 2011 GSA oem battery was giving up the ghost, but apparently not quite dead enough for BMW to replace under warranty (although it tested at 9.8 under load). I read several threads suggesting the Odyssey PC625 was a good replacement option, so decided to give it a go. With some help from JVB, and a utility knife and dremel, the Odyssey fit right in. Needless to say, I am very glad to have this powerplant with our daytime temps hovering in the teens.
GSA battery, a stock GS battery, and the Odyssey 625.
Remove this tray and the larger standard GS battery fits.
Some trimming of the fins and the PC625 fits.
But a seat bar trimming is in order.
NoVa Rider is offline   Reply With Quote
Old 01-22-2013, 07:50 AM   #2
rocky burns
Oddometer: 74
Should have gone for the pc535, fits straight in
rocky burns is offline   Reply With Quote
Old 01-22-2013, 07:57 AM   #3
LaurelPerryOnLand
Oddometer: 3,480
100 THREADS all GS/GSA owners should read.
22. HOW TO INSTALL AN ODYSSEY PC535 BATTERY:
http://www.advrider.com/forums/showthread.php?t=320214
JVB saves the day, again.
PC 535 Specs:
535 cranking amps for 5 seconds
465 cranking amps for 10 seconds
410 cranking amps for 20 seconds
Short circuit current over 1000A
14.8 amp hours
21 minute reserve capacity with 25amp load
CCA - 200 (Is this important?)
Length 6.70"
Width 3.90"
Height 6.13"
Weight 12.0 lbs
PC 625 Specs:YB16-CLB replacement
625 cranking amps for 5 seconds
545 cranking amps for 10 seconds
480 cranking amps for 20 seconds
Short circuit current over 1800A
27 minute reserve capacity with 25amp load
Length 6.7"
Width 3.90"
Height 6.89"
Weight 13.2 lbs
LaurelPerryOnLand screwed with this post 01-22-2013 at 12:32 PM
LaurelPerryOnLand is offline   Reply With Quote
Old 01-22-2013, 08:08 AM   #4
Amania
Amania's Avatar
Oddometer: 105
Yes the 535 may fit right in but the 625 is cheaper and more powerful
Amania is offline   Reply With Quote
Old 01-22-2013, 08:14 AM   #5
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,268
Yep, just check out page #4
http://www.odysseybatteries.com/files/techbook.pdf
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake is online now   Reply With Quote
Old 01-22-2013, 08:23 AM   #6
NoVa Rider OP
Oddometer: 2,870
When I searched the threads before buying, there was some suggestion that the pc625 wouldn't fit newer GSAs with ESA.
It does.
Old 01-22-2013, 10:33 AM   #7
kimokk
kimokk's Avatar
Oddometer: 103
Lithium light weight battery?
What about the lithium starter batteries like Shorai or Mirai?
I saw the Mirai battery at the DC motorcycle show a couple of weeks ago. They only weigh 1.74 lbs and have up to 325 CCA at 0 degrees.
Here's a link:
'09 BMW R1200GSA Adventure! (gone)
IBA #49426
kimokk is offline   Reply With Quote
Old 01-22-2013, 09:00 PM   #8
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,907
Here's a link:
My only problem with the alternative batteries is that their utility seems hit and miss. The Odyssey series are well proven.
Jim
JimVonBaden is online now   Reply With Quote
Old 01-23-2013, 02:06 PM   #9
GeorgeinVA
Beemers Uber Alles
GeorgeinVA's Avatar
Oddometer: 603
Jim
Jim if large scale lithium ion batteries are good enough for Boeing's 787 why not in a bike, err I think I just answered my own question.
Beemers Uber Alles
9248 Mike Garcia Drive
Manassas Va 20109
(571) 318 2472
Indie BMW Maintenance
www.beemersuberalles.com
GeorgeinVA is offline   Reply With Quote
Old 01-23-2013, 03:01 PM   #10
NoVa Rider OP
Oddometer: 2,870
Old 01-27-2013, 10:13 AM   #11
Boondox
Travels With Barley
Boondox's Avatar
Oddometer: 3,014
Rumor has it they serve as a heat source on cold mornings...
I got a sidecar to travel with my dog. He never complains, is delighted to be with me, approves of my dietary choices, is a social butterfly who helps me meet folks, appreciates a good beer, snuggles better than my wife, and hangs on my every word as if it's the most profound thing he's ever heard. TravelsWithBarley.com
Boondox is offline   Reply With Quote
Times are GMT -7.   It's 01:02 PM.
